Esinkin Wireless Audio Receiver for Music Streaming  - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-20-2020, 08:22 AM - Thread Starter
Quoted: 60 Post(s)
Liked: 0
Hello All,
I have a quick question. So I got myself a Esinkin Wireless Audio Receiver for Music Streaming. Now there are two ways of connecting it between AUX or RCA.
Which way gives out a better sounds quality please advice. Thank you and Happy Father's Day to all.
ML
Musiclovers2 is offline
post #2 of 8 Old 06-20-2020, 08:56 AM
rocky1's Avatar
Quoted: 623 Post(s)
Liked: 207
Aux is an input analog just connect rca cables..
Sony XBR65A1E,(Pioneer 500m relocated), AppleTv 4K,Marantz sr7012, System Audio Loudspeakers( sa1750 mains), ML Grotto.
Eastern Electric Minimax cd, Oppo UDP-203, Toshiba HD, Pro Ject 1expression Carbon TT.
rocky1 is offline
post #3 of 8 Old 06-20-2020, 09:14 AM
Ratman's Avatar
Quoted: 2869 Post(s)
Liked: 2913
Both are analog outputs. They do the same.
Use either. Cables are supposedly included. According to the manual.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #4 of 8 Old 06-21-2020, 11:20 AM
bluewizard's Avatar
Quoted: 2412 Post(s)
Liked: 1592
Originally Posted by Musiclovers2 View Post
Hello All,
I have a quick question. So I got myself a Esinkin Wireless Audio Receiver for Music Streaming. ...
ML
So you got an Esinkin BLUETOOTH Receiver .... correct?
Something like this?
https://www.amazon.co.uk/Bluetooth-S...0/?tag=av0c-21
Very likely inside the device, the AUX and the RCA are the exact same point. Use either one depending on the types of cables you have or the type you can get easily.
I don't think it matter which you use, as long as you only use one.
What are you connecting it to?
Steve/bluewizard
bluewizard is offline
post #5 of 8 Old 06-21-2020, 05:03 PM - Thread Starter
Quoted: 60 Post(s)
Liked: 0
I'm more concerning as sounds quality. Just trying to get the best quality sounds that's all.
Btw I'm using a vintage receiver listening as stereo hifi.
post #6 of 8 Old 06-21-2020, 05:18 PM
Ratman's Avatar
Liked: 2913
both outputs provide the same signal, same quality. That's all.
post #7 of 8 Old 06-22-2020, 09:54 AM
bluewizard's Avatar
Liked: 1592
As others have said, it doesn't matter which connector you use.
As I said, what cable you use will depend on what you are connecting to, and how long the connecting cable will need to be.
Give that you have RCA Outputs available, and more likely your Amp has RCA Inputs, an RCA-to-RCA Cable makes the most sense.
https://www.amazon.com/KabelDirekt-A...dp/B00DI89I04/
But those cables can be a bit bulky, so there is nothing wrong with using a 3.5mm Stereo to 2xRCA Cable.
https://www.amazon.com/KabelDirekt-S...00DI89MSM?th=1
These are not especially expensive.
In the long run, which connector you use doesn't matter.
Steve/bluewizard
post #8 of 8 Old 06-22-2020, 10:40 AM
Ratman's Avatar
Liked: 2913
As stated earlier... if we are discussing the same product, both type of cables are included.
Reply 2-Channel Audio
