Unwanted Tidal Volume Changes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-20-2020, 10:16 AM - Thread Starter
Liked: 0
I have an issue while listening to music from Tidal and I am looking for some input. My volume raises or lowers all by itself randomly. I’ll be listening to a track and all of a sudden the volume will increase or decrease, then a few minutes later it will go back to the original volume setting while never touching the remote. The problem only occurs while listening to Tidal, while watching a blu ray or tv the problem never occurs. I have contacted Tidal several times and they requested I take a video to show them when it happens, only problem there is it might happen within five minutes or within five hours or not at all. I have uninstalled the app and reinstalled it and then it works fine for a while but it comes back then I repeat the process and it’s okey for a while. With Tidal I have the loudness normalization on and have a hi fi subscription. I stream using an ipad thru my Denon X6300H AVR. As I said I never experience volume changes while watching tv via cable box or while watching blu rays via my Oppo 203 so I’m thinking it’s probably not the Denon. Any suggestions would be appreciated, thanks in advance for any help.
Nytrojake is offline
post #2 of 10 Old 06-20-2020, 11:48 AM
Ratman's Avatar
Quoted: 2931 Post(s)
Liked: 3000
Maybe it's an IPad problem?
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 10 Old 06-20-2020, 03:27 PM
RayGuy's Avatar
Quoted: 3579 Post(s)
Liked: 3396
Sounds more like loudness abnormalization! If you turn that option off, does the problem remain?
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #4 of 10 Old 06-21-2020, 04:50 AM - Thread Starter
Liked: 0
Yes it does still happen on or off
post #5 of 10 Old 06-21-2020, 09:58 AM
RayGuy's Avatar
Liked: 3396
I'd start by replacing the cable that connects the computer to the audio system. You might also try a different port on both sides of the cable, if that is also an option.
RayGuy is offline
post #6 of 10 Old 06-21-2020, 12:21 PM - Thread Starter
Liked: 0
Computer is not involved or connected to system. I turn on my Denon, turn on my ipad, stream Tidal thru Apple Play thru the Denon out the Klipsch speakers.
post #7 of 10 Old 06-21-2020, 02:29 PM
Ratman's Avatar
Liked: 3000
Maybe IPad, Apple Play or Bluetooth setup/settings?
Ratman is offline
post #8 of 10 Old 06-22-2020, 08:41 AM
RayGuy's Avatar
Liked: 3396
If you stream from anywhere other than Tidal, or if you just play some MP3s on your ipad, does the problem occur? If so, it's something to do with the computer/receiver interface. If not, it's Tidal.
RayGuy is offline
post #9 of 10 Old 06-22-2020, 11:25 AM - Thread Starter
Liked: 0
Thanks for all the input, I’m not sure if it’s a computer/router or ipad or Tidal issue, there are really no adjustments on the ipad for bluetooth or AirPlay and there really aren’t any adjustments on Tidal for playback except for normalization and the Denon doesn’t exhibit the problem anytime except while streaming Tidal from the ipad. It also happens when I use my wireless Klipsch bluetooth speaker. If I playTidal on my desktop it never happens but the computer is connected by an ethernet cable from the router so I don’t know if it’s like a handshake problem, router or an ipad or tidal issue, just annoying more than anything else but I certainly can live with it. I only stream from Tidal, I basically just use the ipad to stream Tidal. The thing that gets me is if I delete and reinstall the Tidal app the problem goes away for a few weeks then it starts again..
post #10 of 10 Old 06-22-2020, 11:32 AM
Ratman's Avatar
Liked: 3000
Probably related to "wireless" whether WiFi, BT or a combination of both.
EDIT:
IMO, that narrows it down to Tidal or the IPad.
Ratman is offline
Reply 2-Channel Audio
