Curved screen for gaming? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-23-2010, 08:29 AM - Thread Starter
m.hoffman5's Avatar
I hope this isn't too off topic. However, would it be possible to make a curved screen for gaming? I'm thinking of the screen being a 225 degree arc then using 3 projectors hooked up to a triple head to go device for one continuous image. This would greatly enhance the immersion factor. I've seen some comercial applications but they are way over my budget.
Thanks for any input you may have!
m.hoffman5 is offline
post #2 of 6 Old 04-27-2010, 06:59 PM
CAVX's Avatar
Quoted: 372 Post(s)
Liked: 179
Would you actually want one curved screen or three flat panels where the two outer ones have their out edge moved forward?
What might work for gaming is a weak fish eye lens with a curved screen.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #3 of 6 Old 04-28-2010, 06:40 AM
petew's Avatar
Quoted: 29 Post(s)
Liked: 69
Something like this Would be cool!
Can you warp the projected images electronically (in the video card drivers) to make the "seams" line up? Shouldn't be too hard to build the screen.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #4 of 6 Old 04-28-2010, 04:25 PM - Thread Starter
m.hoffman5's Avatar
That's exactly what I was thinking. By using a PC, Triple Head to go, and 3 projectors. The triple head to go is designed to attach 3 monitors to one graphics card in the PC. The game would also need to support very wide resolutions. A 1900 bit screen x 3 would be 5700 across.
post #5 of 6 Old 04-30-2010, 03:16 PM
petew's Avatar
Quoted: 29 Post(s)
Liked: 69
Does the Triple Head video driver allow you to warp the geometry to make things line up between the three images, adjusting for optical distortion? I vaguely remember seeing something in an nVidia driver somewhere in my foggy past.
petew is offline
post #6 of 6 Old 04-30-2010, 07:35 PM
Flips's Avatar
What games? I have a tripple head setup (just monitors) and I use SoftTH.
http://www.kegetys.net/SoftTH/
There's LOTS of options in the setup. It's cheaper than buying a TH2GO box, but game compatibility is limited. They have something called cyclindrical distrotion (which is looks like he removed in the latest beta), not sure if that does what you are looking to do.
Like Mark said you will need a lens or else you will be out of focus I would think. I gotta think someone out there has done a diY version of this. Might want to look at sim racing or sim flying sites.
flips
Flips is offline
Reply DIY Constant Height
