My Auto Masking - AVS Forum | Home Theater Discussions And Reviews
 13Likes
  • 10 Post By Mopar_Mudder
  • 1 Post By Mopar_Mudder
  • 2 Post By ScottJ0007
post #1 of 17 Old 01-05-2016, 02:04 PM - Thread Starter
Mopar_Mudder's Avatar
Quoted: 44 Post(s)
Liked: 45
My Auto Masking
Well it has been a long road and a couple of different versions but I am finally I think done with my masking and control system. I think mine is a little different then anyone else's in that my masking will fully close to cover the entire screen when it is not in use, this makes it surprisingly more difficult. The entire thing is ran by a single cable that is controlled by one AC gear motor. All tension on the masking is done by counter weights, so their is not springs or anything to wear out over time and change the tension. Equal pull is exerted on the masking in both directions so they offset each other, this way it does not take a very big motor to move it.
I have manual controls on the screen wall itself that are just mechanical switches, one to open, one to close and one that will kill power to the entire system.
The automation is controlled by a micro control called an Arduino, it is cheap and pretty easy to program. I had never programed one before this and caught on pretty quick. Their are micro switches at each spot the screen stops: Closed, 4:3, 16:9, 1.85, 2.35, 2.40, and Full Open. I though about using some sort of encoder to track the motor position but decided that the switches were more going to be more reliable in the long run as no calibrating or anything has to be done. BUT I think I may play around with adding one as the Adruino is capable of excepting input from one. The Arduino gets a signal from my Harmony remote as to witch position it needs to go to. I also have manual controls on the remote so you can move it to anywhere you want.
This is the motor control with the 3 buttons to run it manually. Their are three relays, one turns the motor one, one puts the motor in reverse, and the other locks out the manual buttons when the Arduino is controlling it. The Arduino simply triggers the correct relays to get the motor to go in the correct direction until the correct micro switch is triggered by the masking.
Link to the Arduino site : https://www.arduino.cc/
Here is a video of it in action
ID:	2638272   Click image for larger version
ID:	2638274   Click image for larger version
ID:	2638276   Click image for larger version
ID:	2638278   Click image for larger version
Mopar_Mudder is offline
post #2 of 17 Old 03-28-2016, 08:35 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 45
Here is a Sketch Up file showing the design if anyone is interested.
Screen Masking Take 2.zip
post #3 of 17 Old 03-28-2016, 08:40 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 45
Here a some pictures of the design:
ID:	2638260   Click image for larger version
ID:	2638262   Click image for larger version
ID:	2638264   Click image for larger version
ID:	2638266   Click image for larger version
Beerce likes this.
post #4 of 17 Old 02-25-2017, 02:22 PM
madermat's Avatar
Quoted: 73 Post(s)
Liked: 34
very cool
madermat is offline
post #5 of 17 Old 03-08-2017, 08:57 AM
SXRDISBEST's Avatar
Quoted: 119 Post(s)
Liked: 67
This is very impressive. Did you fabricate all of it? Those arduinos are cool. I've used one before. Although the programming still confounds me!
SXRDISBEST is offline
post #6 of 17 Old 03-17-2017, 04:43 PM
arpatel's Avatar
Quoted: 14 Post(s)
Liked: 4
Looks very impressive :
arpatel is offline
post #7 of 17 Old 03-20-2017, 10:44 AM
ScottJ0007's Avatar
That is very impressive! The Arduino is very cool. I am curious where you sourced the components. Specifically I noticed at the very start of your second video that you have a conical shaped cable take-up pulley. Where did you get that? (In my design I had to use multiple layers of tape to try to replicate the conical shape).
I think your design is the best DIY masking setup I've seen. Congrats!
Josh Z and mtbdudex like this.
ScottJ0007 is online now
post #8 of 17 Old 04-13-2018, 03:03 PM
ScottAvery's Avatar
Quoted: 833 Post(s)
Liked: 238
It is similar to a vertical lift cable drum from a garage door assembly, but less extreme. I too would like to know the source of some of these components.
ScottAvery is online now
post #9 of 17 Old 04-13-2018, 06:22 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 45
Sorry I didn't get notices that their were questions on this thread until today. Yes I fabricated everything myself. I make the conical pulley from scratch, took a bit of math to figure out the small and large end to make a pattern. Still working great other then when the power goes out it confuses the Arduino, I think I can fix that just haven't taken time to get into the programming of it. I see some pictures are not working, I will try to fix the links.
post #10 of 17 Old 11-07-2019, 04:11 PM
umjs78's Avatar
Quoted: 26 Post(s)
Hi, Just found this post while looking for masking system.
Can I get sketch up file? or any detail information would be great help.
Thank you!
umjs78 is online now
post #11 of 17 Old 11-08-2019, 09:44 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 45
Thank you!
PM me your e-mail and I can send you the shetch up file.
post #12 of 17 Old 11-08-2019, 11:11 AM
ScottAvery's Avatar
Quoted: 833 Post(s)
Liked: 238
Good to hear from you again! I am also interested in the sketchup file as the old link seems to be invalid. Will send a PM.
Could you provide any more detail on parts you used?
post #13 of 17 Old 11-08-2019, 11:43 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 45
Well I wish I would have documented it better and taken more pictures as I did it, but its too late now.
As far as all the parts go I really made most all of them by hand other then the trolley wheels and cable, just lots of fabricating.
I will send the Sketch-Up file to anyone that wants it. All the parts I made we built off from the file so they are all exactly to scale.
If you have any questions on specific parts just let me know and I will try to answer.
post #14 of 17 Old 01-28-2020, 10:18 AM
sbazzle's Avatar
Liked: 7
A couple things: I'd like to get a copy of the Sketchup file. Do you have it linked somewhere? Also, the link to photos of your theater build in your post signature isn't working. Any chance of fixing that? Thanks!
sbazzle is online now
post #15 of 17 Old 01-29-2020, 02:37 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 45
I think I got the links working again. Should beable to download the Sketchup file from the link in the post above.
post #16 of 17 Old 01-30-2020, 10:05 AM
sbazzle's Avatar
Liked: 7
Perfect. Thank you!
post #17 of 17 Old 02-02-2020, 09:46 AM
sbazzle's Avatar
Liked: 7
From watching your two videos posted to show the masking in action, I'm curious about the system's noise. Sounds like a lot of it is coming from the cables. Have you tried to quiet the system at all since you built it? These kinds of engineering projects fascinate me.
Reply DIY Constant Height
