DVD sending PCM audio instead of DTS? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-23-2015, 03:28 PM - Thread Starter
Quoted: 18 Post(s)
Liked: 0
So i have the Panasonic DVD-S52 and it can do DTS and Dolby. For some reason it doesnt send DTS or Dolby audio, instead its sending PCM audio according to My receiver (Yamaha RX-675).
I have turned on DTS Digital Surround to Bitstream and Dolby Digital to Bitsteam, and i have turned off PCM Digital Output. Is there anyway i can fix this?
Here are some Pics:
KrypteriaIV is offline
post #2 of 2 Old 01-27-2015, 04:41 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 467 Post(s)
Liked: 12242
Any modification to the audio requires the compressed audio to be decompressed/decoded and then modified. That may be why PCM is being output. Try turning off Dynamic Range Compression, Sound Enhancement, Dialogue Enhancer, H Bass, and Advanced Surround. Your receiver may be able to do those things or something like it.
larry
You've had too much to think.
PooperScooper is offline
Reply DVD Players (Standard Def)
Dolby Digital , Dts , dvd player , Panasonic , pcm
