Pioneer DVL-909 LD and DVD player Comp to HDMI solution? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-16-2018, 01:53 PM - Thread Starter
Liked: 0
So I found a DVL-909 locally on CL. This one plays DVDs and LD's and is from 1998. Comes with S video and component out, and coaxial and fiber optic audio out. Yes!! To be brief I like vintage and obscure formats on occasion, such as LD.
Will a direct component to HDMI cable work if plugged directly into the below receiver, or would I still need an analog to digital converter box? Thanks in advance!
The receiver I am using is a Sony STR-DN1080
Trying to avoid plugging in another cheap Chinese converter box which will fry in two months..
Rick Valenta is offline
post #2 of 3 Old 05-17-2018, 04:24 PM
Kurtis Bahr's Avatar
Quoted: 78 Post(s)
Liked: 31
The digital outputs only output audio bit streams. The LD playback will only be on the composite and S-Video outs, the Component output is designed for DVD playback, DVD also comes out the composite and S-Video. Video is only analog. HDMI is only digital.
Kurtis Bahr is offline
post #3 of 3 Old 04-26-2019, 09:59 AM - Thread Starter
Liked: 0
Got it! Ran S-Video into an upscaler which converts to HMDI; seems like an okay solution for now.
Also found a modulator box so i'm getting dolby 5.1 out of laserdiscs which is pretty cool in 2019!
Still really enjoying the LD player; the movies are basically early DVD quality which is not bad.
Reply DVD Players (Standard Def)
