Dim Denon Display - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-03-2018, 09:50 AM - Thread Starter
w4xtc's Avatar
Liked: 0
Dim Denon Display
I have 2 Denon DN-V310 DVD players. Both work great, but the digital display on one of the players is much dimmer (by about half) than the other. I've been through the manual and found no way to adjust the brightness. Is there any way to set the bright/dim on the LED's or is it a hardware problem?
It's a nit-pick, I know, but it would be nice to have the two units matching since they're racked together.
Thanks in advance.
w4xtc is offline
post #2 of 2 Old 03-16-2020, 10:48 AM
Quickster2's Avatar
Quoted: 33 Post(s)
Liked: 45
Not sure if this helps but on my 3930CI the dimmer button is on the remote.
Quickster2 is offline
Reply DVD Players (Standard Def)
