Laserdisc Tray Not Opening CLD-2850 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-19-2019, 03:46 PM - Thread Starter
Liked: 0
Wondering if someone could help, i have brought a cld-2850 player, it powers on but when press open button it says open then changes straight to close without opening. Any help would be greatly appreciated
LDnewbieUK is offline
post #2 of 7 Old 06-20-2019, 02:43 PM
Kurtis Bahr's Avatar
Quoted: 75 Post(s)
Liked: 31
You have to take the top off and see what the tray is hitting when trying to open which results in it changing to close.
Kurtis Bahr is offline
post #3 of 7 Old 06-20-2019, 03:08 PM - Thread Starter
Liked: 0
I have done that & not sure what to look for
ID:	2582492   Click image for larger version
ID:	2582494   Click image for larger version
post #4 of 7 Old 06-20-2019, 03:28 PM
Quoted: 75 Post(s)
Liked: 31
When you press open the tray should raise up and then a second motor should push it out. You need to watch it the tray is being fully raised to start the slide out step. You can help raise the tray by pressing forward white plate forward to assist the motor or just manually press it forward and then once up you can push the tray forward. You could have a slipping or broke belt.
post #5 of 7 Old 06-21-2019, 12:14 AM - Thread Starter
Liked: 0
They tray isn't lifting & i can't hear a motor.
post #6 of 7 Old 06-21-2019, 12:45 AM
holl_ands's Avatar
Quoted: 926 Post(s)
Liked: 500
Fol. Service Manual Download costs $4.99, but perhaps you can find one on-line for Free:
https://www.manualscenter.com/brands...ld,_clx/page-2
Owner's Manual Download & Review of A/V limitations...and available upgrades....suggest you do further research:
http://www.laserdiscarchive.co.uk/la...r_cld-2850.htm
holl_ands is offline
post #7 of 7 Old 06-21-2019, 08:49 AM
Quoted: 75 Post(s)
Liked: 31
You need to unplug the unit then push the white plate of the left side forward to raise the tray and then push it out. Then plug in the unit and see if it will pull the tray back in and drop it. There are too many different things that could be bad, motors, power supply, logic boards, switches, etc. that could be bad or maybe manually opening it will get it going.
If you cannot do this then I’d return it.
Reply DVD Players (Standard Def)
