Pioneer CLD-D99 LD Player "U2" Error - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-01-2019, 11:06 AM - Thread Starter
Liked: 2
Hello, I am seeking a little advice on fixing my Pioneer CLD-D99 LD Player, recently purchased from a seller on the internet. It was claimed that it can be powered on but can't play disks.
Upon turning it on, strange things happened. First all the LED segments on the display panel were lit by a few seconds, followed by displaying seven zeros "00 00000". No response by pressing most of the buttons on the remote, including the "open tray" button. By pressing certain buttons on the remote, "00 00000" on the panel display was changed to "U2", which means "communication error" between the mode controller and the mechanism controller after googling. When powering it off, the "-OFF-" message keeps blinking and the unit does not turn off. I'd like to seek anyone for comments if you have encountered the same issue before. Thank you!
Name:	1. All LEDs Lit.jpg
ID:	2597096   Click image for larger version
Name:	2. Seven Zeros.jpg
ID:	2597098   Click image for larger version
Name:	3. U2 Error.jpg
siutakkei is offline
post #2 of 4 Old 08-01-2019, 11:18 AM - Thread Starter
Liked: 2
Amendment: First, all the LED segments on the display panel were lit, then when any buttons are pressed, the panel display was changed to "00 00000".
Remark: The TV screen remains black all the time (I use composite signal for connection)
post #3 of 4 Old 08-01-2019, 10:10 PM
Kurtis Bahr's Avatar
Quoted: 78 Post(s)
Liked: 31
I would ask the seller what they meant by "it can't play discs" This looks like a controller issue. Buying bad players is not recommended, this is not a typical error. I usually find someone opened the player, couldn't fix it or made it worse and then sells the player hoping to get their money back.
Kurtis Bahr is offline
post #4 of 4 Old 08-02-2019, 02:04 AM - Thread Starter
Liked: 2
Dearest Kurtis, thank you so much for your precious comments. Therefore, I think what I can do now is to keep the parts inside for possible future service of another unit.
Reply DVD Players (Standard Def)
laserdisc , Pioneer
