LaserdiscDVD Combo Player 480p? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-10-2019, 07:02 AM - Thread Starter
Liked: 0
Are there any Laserdisc/DVD players that can play laserdiscs and can also output DVDs in Progressive Scan? If so, what are the model numbers of the units that can do that? Thanks in advance.
masquarr is offline
post #2 of 2 Old 08-13-2019, 11:42 PM
Kurtis Bahr's Avatar
Quoted: 77 Post(s)
Liked: 31
The DVL-91, DVL-909 and DVL-919 do have component outputs for the DVD player but it only outputs the DVD in its recorded format, it does not upscale to any other format. For LD players the unit does not process the composite signal into component so laserdisc is composite or S-Video only.
Kurtis Bahr is offline
Reply DVD Players (Standard Def)
