Pioneer LD-707 - Tray won't open - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-28-2019, 01:45 PM - Thread Starter
Liked: 0
My dad just gave me his LD-707 with the sound processor DA-1 but the tray won't open when pressing eject. It sounds as if the motor is trying to open the tray but nothing happens. I took the casing off but I have no clue how to get to the motor because it is below the tray. I have found service manuals online for $5 but I'm not sure if it's even worth trying to fix since I don't see any parts online. I really want to get this fixed or just buy a new one and was wondering if anyone had some suggestions. I have a Sony 4K TV that surprisingly has a composite/component input. Crossing my fingers Kurtis Bahr responds lol.
walshs00 is offline
post #2 of 4 Old 12-29-2019, 10:22 PM
Kurtis Bahr's Avatar
Quoted: 81 Post(s)
Liked: 33
With I bought my manuals from a service center I did not get the older players like the LD-707. I cannot help with this one as I have never worked on one. The tray opening is usually more involved with the older players.
Kurtis Bahr is offline
post #3 of 4 Old 12-30-2019, 01:51 PM - Thread Starter
Liked: 0
Do you have any advice on another one? I've looked on eBay to see what's available and seems a lot are the models designed for educational purposes with lower quality video/audio.
walshs00 is offline
post #4 of 4 Old 12-30-2019, 04:23 PM
Quoted: 81 Post(s)
Liked: 33
It depends on what you want spend for a laserdisc player. There are higher end units and lower or more of the entry units. I do refurbish units and sell them but I don't have any below the $200 price point.
The cheapest unit that will give you an AC-3 RF output and optical digital audio output along with playing both sides is the CLD-D406. But it needs the upgraded laser movement motor swapped in to have longevity of life.
Reply DVD Players (Standard Def)
