Pioneer Elite CLD-99 Laserdisc Player won't stay powered on - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-16-2020, 05:40 PM - Thread Starter
Liked: 0
Hi,
First post, so go easy on me. I have a Pioneer CLD-99 Laserdisc player that won't function. When I plug it into the electricity, the red power light comes on and stays on. As soon as I press most buttons on the front panel, the red light immediately goes off and won't come back on until I plug it back in. It doesn't do anything else. I suspect it may be related to a power supply or fuse issue, but I am unsure where to start looking or whether I need to order parts. Can the power supply or fuse on these be swapped without soldering similar to a PC?
Thanks in advance.
ID:	2671032   Click image for larger version
Gdale1 is offline
post #2 of 3 Old 01-16-2020, 06:15 PM - Thread Starter
Liked: 0
An update, I opened the player up, I broke both of the warranty seals on the back, so the player had never been opened since leaving the factory. I removed and inspected the fuse, there doesn't appear to be a break in the fuse, so it seems ok. The power supply board says "VWR1200-D" on it. The power board is listed on the pioneer website and shows the compatible models, but does not show as being in stock. Not sure what I should look for next or whether this unit is repairable. Any help would be appreciated.
Gdale1 is offline
post #3 of 3 Old 01-16-2020, 07:21 PM
Kurtis Bahr's Avatar
Quoted: 82 Post(s)
Liked: 33
The quick way to check the power supply is unplug the two ribbon cable and the connector for the spindle motor. Take a 1K resistor between the ever +5V and Power On where the smaller ribbon was connected and then measure the switched +5V, -5V, +12V and -12V outputs and see if they are OK. If this is good you have to start looking at the other boards for a short.
Kurtis Bahr is offline
Reply DVD Players (Standard Def)
