Convert old VHS to digital - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Ken.F
post #1 of 5 Old 03-24-2020, 10:40 AM - Thread Starter
av409's Avatar
Hello not sure if this is the proper place to ask the question if not I suppose one of our moderators will move it to the appropriate section
what is the best way to convert old VHS tapes to digital format
I’ve been watching YouTube videos which detail using a video capture device to computer.
If this is in fact a viable option any recommendations on the best capture device, I know quality what varies widely.
Additionally is it better to put the VHS directly to digital on a PC or record to a DVD ?
I have access to an old DVD recorder by Magnavox don’t know if it’s worth the effort or if DVD is a moot point today
av409 is offline
post #2 of 5 Old 03-26-2020, 02:25 PM
Ken.F's Avatar
Quoted: 2346 Post(s)
Liked: 2695
I've done it both ways, capturing it on the PC using a Hauppauge TV tuner card and by recording with my Magnavox HDD/DVD recorder. The quality ends up about the same both ways so do whatever is the most convenient for you. I can't recommend any hardware since my Hauppauge 2250 and Magnavox recorders have been out of production for years.
Ken.F is online now
post #3 of 5 Old 03-27-2020, 02:32 PM - Thread Starter
av409's Avatar
ok thanks
if i do try recording via the DVD is there any one particular type of disc that would be preferred?
av409 is offline
post #4 of 5 Old 03-27-2020, 03:03 PM
MRAYB's Avatar
Quoted: 427 Post(s)
Liked: 1184
I bought a used Magnavox VCR to DVD recorder about 10 years ago on Ebay. After I was done transferring all my tapes it sat in a closet for 5 years. Don't recall the model, but I ended up selling it on my local Craigslist. There are still today loads of used ones on Amazon and Ebay for $100-$300+. As for discs, the best I ever used were "Verbatim DVD+RW". I used these for the ability to re-write over and over. Always worked great. Stay away from Memorex. 2 or 3 out of 10 will be bad.
MRAYB is online now
post #5 of 5 Old 03-27-2020, 04:14 PM
Ken.F's Avatar
Liked: 2695
ok thanks
If you plan on storing the DVDs the Verbatim AZO discs are good ones. My go-to discs were Taiyo Yuden Premium DVD-R TYG02 back in the day but I don't think they make them anymore.
I never used RW discs for long term storage. It might be OK to do that but it just feels wrong to me.
jjeff likes this.
Ken.F is online now
Reply DVD Players (Standard Def)
