Panasonic DVD players made region/macrovision free without physical mods (some) - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 168 Old 11-29-2003, 04:24 PM
bannani's Avatar
Hi everyone,
my name is Bruno an I am writing to you from France. I intend to buy a RP 91 or rp 82, do not know where to buy it. Since I am living in france I try to find a place to buy it! or someone xould kindly sell me a player?
I was quite impressed by your search?
I also have to make my dvd player region free and macro off since I get one!
Hope reading you soon.
Regards
Bruno
bannani is offline
post #32 of 168 Old 12-05-2003, 07:39 AM
dragonbud0's Avatar
Quoted: 236 Post(s)
Liked: 136
I post another thread Under "RP56 and DTS". Did anyone out there with the RP56 has similar problem after updating the firmware but "lost" the DTS capability? Any fix?
lenny
dragonbud0 is offline
post #33 of 168 Old 12-08-2003, 07:52 AM
dragonbud0's Avatar
Quoted: 236 Post(s)
Liked: 136
Sango advised me to reset the audio for DTS using the "Action" button on the remote. Duh!
lenny
post #34 of 168 Old 02-12-2004, 10:57 PM
whotony's Avatar
Quoted: 22 Post(s)
just found this thread. it seems to have become way off topic.
if anyone who origionally posted about getting the service disk #2, did you get it and did it work for the rp-91?
if it did i would like to know how to get one and do this to my -91.
whotony is offline
post #35 of 168 Old 02-13-2004, 06:32 AM
alv
alv's Avatar
I just did the macrovision part on an RP-91 and it worked great. I just reduced the overscan on my set and in the progressive mode I found wavy lines in the top part of the picture (<5% overscan). Turning off the macrovision made them go away.
alv is offline
post #36 of 168 Old 02-13-2004, 07:50 AM
OARon's Avatar
I'm in the same boat. I followed directions to order the service disk and never got a response.
Any updates on a source?
R
OARon is offline
post #37 of 168 Old 02-13-2004, 08:45 AM
samgt's Avatar
I would love to have access to this service disk as well. Anyone who has it feel generous and share with us?
samgt is offline
post #38 of 168 Old 02-13-2004, 10:12 AM
Chung's Avatar
buddies,
CAn RP82 show blacker than black line inside Video Essentials?
Chung is offline
post #39 of 168 Old 02-16-2004, 07:59 PM
Imp66's Avatar
Using a friend in Australia, I acquired the disc, and received it Saturday. I just tried it on my RP-91 and I have been unsuccessful. Maybe I'm doing something wrong, but it seems pretty straight-forward.
Has anyone else had success using this service disk to get region-free capability on the RP-91?
Imp66 is offline
post #40 of 168 Old 02-17-2004, 07:25 AM
mrwilson's Avatar
Imp66, what firmware version are you running on your RP91?
mrwilson is offline
post #41 of 168 Old 02-17-2004, 04:49 PM
Imp66's Avatar
Firmware 2.59. FYI, I tried this on two different RP-91's, both with 2.59 firmware, but different mfg dates.
Imp66 is offline
post #42 of 168 Old 02-17-2004, 05:07 PM
mrwilson's Avatar
Bummer, I was gonna buy another RP91 to do this too.
Is it an original Panasonic disc or a copy? If a copy it has to be on an 'authoring' dvd-r and not a 'general' dvd-r. Big difference.
mrwilson is offline
post #43 of 168 Old 02-17-2004, 05:11 PM - Thread Starter
Sango's Avatar
Quoted: 42 Post(s)
Liked: 24
The official copy Panasonic Service disc is made using the typical stamping process.
In this case, disc must be copied using an authorized burner and media because it's region information which cannot be copied using general purpose(it doesn't pick it up).
Attemping to do so using general purpose and attemping the unlock procedures to your unit, will make your player end up in the Panasonic Service Center for repair because your firmware essentially gets corrupted.
Sango is offline
post #44 of 168 Old 02-17-2004, 09:07 PM
Imp66's Avatar
The disc I used came directly from Panasonic Australia. I have a friend in Australia, so I emailed Panasonic and gave them his address. He then mailed it to me.
ALV posted:
I'd like to hear from him/her about how they got it to work.
I mean, if there is something else to do except run the disk, I'd like to know. There are no new options in the menu or anything. Inserting a Region 2 disc gives me the same message as always.
Imp66 is offline
post #45 of 168 Old 02-17-2004, 09:08 PM - Thread Starter
Sango's Avatar
Quoted: 42 Post(s)
Liked: 24
Hi Imp66
The Service Disc should work with 2.59 firmware. Maybe you didn't preform it correctly, but there is instructions inside the cover since you have the official disc so you may want to check again. Also I heard firmware 2.59 isn't that good and one of the versions is better preferred - I don't recall but it's 2.50 or something like that, please correct me.
Hope this helps
I have taken digital camera shots for of what you get when obtaining the official disc from Panasonic Australia.
http://home.comcast.net/~fu_family/svdisc.zip
Sango is offline
post #46 of 168 Old 02-17-2004, 09:12 PM
Imp66's Avatar
SANGO:
Have you actually tried this? After entering the password, both my units go to a black screen, flash the screen a couple of times, then say "READ" on the player for a second, then it goes to the typical DVD screen and says STOP.
Is there anything else that should be happening?
Imp66 is offline
post #47 of 168 Old 02-17-2004, 09:19 PM - Thread Starter
Sango's Avatar
Quoted: 42 Post(s)
Liked: 24
Hi Imp66
Yes, I have done this before because I've done it to my RP-56 (I've mentioned in the starting post of the thread). The flashing black screen is normal. After it saids "STOP", the modifcation is complete.
Make sure you did the modification in the right order: 3192 then 3193.
If done incorrectly, you have to do it again in the right order because the macrovision will be on again because of the region modification being last.
Sango is offline
post #48 of 168 Old 02-18-2004, 05:41 AM
alv
alv's Avatar
I just followed instructions - too less than one minute. As soon as I finished I tested for the wavy lines and they were gone. I don't have any non region 1 disks so I didn't try to see if that took but I assume it did. I have software version 250. I don't play MP3's so I didn't upgrade to 259.
alv is offline
post #49 of 168 Old 02-18-2004, 10:40 AM - Thread Starter
Sango's Avatar
Quoted: 42 Post(s)
Liked: 24
Yeah it's 250 which I think is preferred by members so Imp66, you could reflash to that version and attempt the service disc and see how that goes.
alv - The region should be free now so there is no need to worry since I have R3 dvd and I tested it on my RP-56 to double check when I did my modification using the official disc. Glad to hear you already obtained the disc and modified it =).
Sango is offline
post #50 of 168 Old 02-18-2004, 10:52 AM
OARon's Avatar
Sorry for the off-topic post but it's been awhile since I looked at firmware upgrades for the RP-91.
Can someone point me towards the ISO. Also, any threads that talk about the reasons people prefer one version over another would be much appreciated.
OARon is offline
post #51 of 168 Old 02-18-2004, 08:42 PM
Imp66's Avatar
I went here:
http://home.cogeco.ca/~hdtvguy/firmcheck.htm
to get the firmware 2.50 (they also have 2.59), but it will not install an older firmware apparently. If anybody has any clues on how to force it, I'd be happy to listen.
Imp66 is offline
post #52 of 168 Old 02-18-2004, 09:38 PM
sonick182's Avatar
haha, i was just curious and clicked into this thread (i dont even have a panasonic DVD player), and guess what...
Im from RICHMOND too!! Small world lol... We should hav a Richmond AVS Meet
sonick182 is offline
post #53 of 168 Old 02-18-2004, 10:54 PM - Thread Starter
Sango's Avatar
Quoted: 42 Post(s)
Liked: 24
Hmm I guess maybe so! Maybe if you obtain the good Panasonic units then I can be of some assistance! =)
Sango is offline
post #54 of 168 Old 03-23-2004, 11:37 AM
BuGsArEtAsTy's Avatar
Quoted: 715 Post(s)
Liked: 349
Anyone in Toronto have this disc? I have an RP91.
BuGsArEtAsTy is offline
post #55 of 168 Old 03-25-2004, 06:49 PM
topsound's Avatar
Hi Sango,
Do you succeed? Is the disk #2 useful?
topsound is online now
post #56 of 168 Old 03-25-2004, 07:18 PM - Thread Starter
Sango's Avatar
Quoted: 42 Post(s)
Liked: 24
Sorry, but I don't understand what you're trying to say.
Sango is offline
post #57 of 168 Old 03-26-2004, 11:00 AM
redinger's Avatar
So, it looks like the consensus is that the disc doesn't work on the RP-82? I'm sure I know the answer to this - but has anybody gotten it to work on a CP-72? I was going to go beg DrJoe to see if I could borrow his disc, but it doesn't sound like it's worth it now.
redinger is offline
post #58 of 168 Old 03-26-2004, 09:18 PM - Thread Starter
Sango's Avatar
Quoted: 42 Post(s)
Liked: 24
Redlinger:
If you read the starting thread, that will tell you if the unit is even capable of using the disc or not.
Sango
Sango is offline
post #59 of 168 Old 03-27-2004, 12:12 PM
Vtb2's Avatar
Sango, since i have a denon 1600 i entered into the setup menu, and all i can see is: 'menu perference" with 4 options, "english, french, spanish and other" choosing "other" requires the user to enter a 4 digit password, i didn't have to enter the sequence of number you listed. I believe this to be the avenue to load the disc. So there is no way to make a copy of the disc without the dvd burner you describe, Have you tried using dvd decryptor to rip the files to the hard drive then burn to disc. I am sorry if i am missing something about copying the disc.
blair
Vtb2 is offline
post #60 of 168 Old 03-27-2004, 02:11 PM
Furious's Avatar
Sango do you have the part number for service disc 2? I could check with our Panasonic rep to see if they have it under their parts & services division. Thanks.
Furious is offline
Reply DVD Players (Standard Def)
