Best dedicated streaming player for.audio quality? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By andyross63
  • 1 Post By Wendell R. Breland
post #1 of 24 Old 02-20-2018, 03:19 AM - Thread Starter
blake18's Avatar
Quoted: 638 Post(s)
Liked: 356
I've noticed my old Roku 3 sounds nowhere near as good as my Xbox One with Netflix and Amazon, both are set to 5.1. I really like using my Roku, as it has channels my Xbox just doesn't. Would the Roku Ultra be closer to the sound quality of my Xbox One? If not, which streaming player would?
Lumenlab "Community driven video lab".
blake18 is offline
post #2 of 24 Old 02-20-2018, 06:36 AM
andyross63's Avatar
Quoted: 338 Post(s)
Liked: 128
I'd think most streaming devices should simply pass on the digital audio to your TV or receiver. The device should have no effect on the audio quality.
mailiang and Brian Conrad like this.
andyross63 is offline
post #3 of 24 Old 02-21-2018, 12:57 AM - Thread Starter
blake18's Avatar
Quoted: 638 Post(s)
Liked: 356
That's what I would have thought, but Netflix sounds WAY better on my Xbox One than on my Roku 3.
blake18 is offline
post #4 of 24 Old 02-21-2018, 12:29 PM
mailiang's Avatar
Quoted: 1196 Post(s)
Liked: 773
Question Set Up
Need more info. What type of audio equipment are your using for each player and what type of connections are you using? (ie: optical, HDMI). My Roku stick is connected to my AVR's HDMI input and the DD plus audio is excellent. Watched Justice League on Vudu the other night and my twin Velos were shaking the room.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #5 of 24 Old 02-21-2018, 02:52 PM
Brian Conrad's Avatar
Quoted: 2415 Post(s)
Liked: 2046
Yup, if one wants good audio quality then use an AV receiver to decode. Quality depends on how much you want to spend on the receiver and the speakers. The bitstream remains the same as it comes off the source server (CDN).
Brian Conrad is offline
post #6 of 24 Old 02-21-2018, 04:24 PM
mailiang's Avatar
Liked: 773
The question remains, why does his Xbox sound better?
Ian
mailiang is offline
post #7 of 24 Old 02-22-2018, 05:24 AM - Thread Starter
blake18's Avatar
Quoted: 638 Post(s)
Liked: 356
I am certainly not lacking in quality in those areas.
blake18 is offline
post #8 of 24 Old 02-22-2018, 07:58 AM
andyross63's Avatar
Quoted: 338 Post(s)
Liked: 128
Ian
Does the XBox have some option where it decodes the audio, makes some 'enhancements', then passes that on to a receiver or TV? Or maybe the TV or receiver has a different audio setting on that input by mistake?
post #9 of 24 Old 02-22-2018, 11:47 AM
Liked: 2046
Ian
It would take an engineer for both platforms to figure that one out. Are they both optical connected or SPDIF? Shouldn't make any difference since these should be just passing on the bitstream.
The other possibility is the service is sending a different audio stream to each device and one might be at a lower bitrate.
post #10 of 24 Old 02-22-2018, 11:55 AM
IAH
IAH's Avatar
Quoted: 135 Post(s)
Liked: 94
Doesn't the Shield pass lossless audio?
IAH is offline
post #11 of 24 Old 03-31-2018, 10:43 AM
Wendell R. Breland's Avatar
Quoted: 519 Post(s)
Liked: 263
AFAIK, no A/V (i.e., Netflix) streaming provider uses lossless audio. In many cases lossless audio bit rates would be almost what the video bit rates are. If you want lossless then Blu-ray or UHD Blu-ray disc is about it. If money is not a problem then Kaleidescape does offer downloads they claim to be equal to BD.
Wendell R. Breland is offline
post #12 of 24 Old 04-27-2018, 11:25 AM
REDdawn6's Avatar
Liked: 24
Used Ps3 and turn the hidden video playback volume up the 4 or 5 notches!!!
REDdawn6 is offline
post #13 of 24 Old 04-27-2018, 11:28 AM
REDdawn6's Avatar
Liked: 24
I have my VuDu on my Roku premiere plus and my friend's on my ps3. Ps3 is louder and fuller sound. I have to go to - 12.5 on my receiver to match the ps3 volume at - 22
REDdawn6 is offline
post #14 of 24 Old 07-20-2018, 08:44 AM
kkpro's Avatar
Quoted: 203 Post(s)
Liked: 94
Louder doesn't equate to better.
kkpro is offline
post #15 of 24 Old 07-20-2018, 10:50 AM
DaveFi's Avatar
Quoted: 861 Post(s)
Liked: 280
http://www.bigpicturebigsound.com/Ci...nd-Sound.shtml
Cinemanow were using some form of DTS-HD like 5yrs, but I have no idea how/what they were doing.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is online now
post #16 of 24 Old 07-21-2018, 08:11 AM
Quoted: 519 Post(s)
Liked: 263
IIRC, DTS-HD is the competitor to Dolby Digital+, IOW, a lossy low bit rate audio format.
mailiang likes this.
post #17 of 24 Old 07-21-2018, 09:11 AM
DaveFi's Avatar
Quoted: 861 Post(s)
Liked: 280
Interesting. Do any receivers decode it? I've never seen it used in any content before.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
post #18 of 24 Old 07-21-2018, 10:25 AM
mailiang's Avatar
Liked: 773
Most late model AVR's. They usually include DTS lossy and lossless processing.
Ian
mailiang is offline
post #19 of 24 Old 07-22-2018, 03:44 PM
Quoted: 519 Post(s)
Liked: 263
My Yamaha CX-A5100 AVP does, can not speak for others. From the 5100 manual:
DTS-HD High Resolution Audio
DTS-HD High Resolution Audio is a compressed digital audio format developed by DTS, Inc. that supports 7.1-channel and 96 kHz/24-bit audio. DTS-HD High Resolution Audio remains fully compatible with the existing multichannel audio systems that support DTS Digital Surround. This technology is used for audio on BD (Blu-ray discs).
Don't recall ever seeing a BD title with it, with BD there is no need since they can do lossless DTS and Dolby with ease. It appears Dolby Digital + pretty much dominates the streaming market.
post #20 of 24 Old 07-22-2018, 04:11 PM
mailiang's Avatar
Liked: 773
As with Dolby Digital, all DTS encoding is backwards compatible to the core. Unless you have a very old receiver that only decodes 'plain wrapper' lossy DTS or 6.1 DTS ES, you shouldn't have an issue with receiving DTS HD audio.
Ian
mailiang is offline
post #21 of 24 Old 07-23-2018, 08:20 AM
andyross63's Avatar
Quoted: 338 Post(s)
Liked: 128
I've seen several BD's with DTS-HR. I think I had a recent Disney movie where it defaulted to it instead of the normal DTS-MA 7.1 (many Disney titles default to lower audio resolutions for some stupid reason.)
post #22 of 24 Old 07-23-2018, 10:01 AM
Quoted: 519 Post(s)
Liked: 263
The only time I specifically have to select audio tracks is with some older titles with DD and LPCM, they will default to DD and I have to select LPCM. For most they default to the best track, be it DTS-MA, Dolby TrueHD, Dolby Atmos, DTS:X, etc. There may be a few titles other than LPCM ones that I specifically have to select audio tracks but it must not happen often as I can not remember the last time I did it.
post #23 of 24 Old 07-23-2018, 12:25 PM
Liked: 2046
It looks like a recent Roku TV update seems to be turning all the non DD+ streams usually AAC stereo into DD. My Yamaha receiver on streams like these used to vacillate between DDPrologic II and NeoDigital 6.0. Now it just says Dolby Digital. I haven't noticed any 5.1 on these streams like those from Hulu but that might depend upon the title. I believe that Dolby Digital (A52) is supposedly out of patent.
post #24 of 24 Old 02-19-2019, 09:50 AM
Photokid1970's Avatar
Quoted: 68 Post(s)
Liked: 50
Like the OP, my Xbox One X seems to have louder audio for me. I don't know that it is 'better', but I noticed this last week when testing the surround setup with S1 E5 of Daredevil (where the camera pans around and the guy in the backseat of the cab is singing in Mandarin.) I watched that scene on my Xbox One X, my Oppo Blu Ray, and the Apple TV 4K. The Oppo was much louder than the other two, and I realized that my Xbox was set for HDMI audio and not for the DD bitstream. I changed that, and the audio got MUCH better. I checked the Apple TV too, and it seems to be set correctly - but it's just not as loud as the Xbox or the Oppo.
Photokid1970 is offline
Reply Video Download Services & Hardware
