480p conetnt NOT 480p?? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By markmon1
post #1 of 4 Old 06-20-2019, 03:51 AM - Thread Starter
TECH198's Avatar
Quoted: 33 Post(s)
When watching iTunes content parasitically shows like "The Simpsons" allot of the early ones Seasons 1 though 19 at least are SD.. And while Fox did a "remake" of some on Season 20 in HD, the earlier seasons still shows at 16:9 for some reason ..
https://www.imdb.com/title/tt0096697...ef_=tt_dt_spec
why would this be? Downloading these earlier ones from iTunes and looking at resolutions displays clearly 480p (actually 840 x something), so it must be the TV set that is ''changing them to 16:19"
Its not zoomed, because no cropping occurs.. so I'm confused.. If these were indeed "remastered" Seasons 1 though 20 on iTunes the resolution would be 720 or 1080p wouldn't it?
I thought SD was always cropped, as if it's 4:3 resized to 16:9, that would be zoomed in which would result in cropped image (which i do not see)
By the way, i only notice it on this, not on other SD content as they all have black bars..
You can't add pixels which ain't there.
TECH198 is offline
post #2 of 4 Old 06-20-2019, 05:03 AM
markmon1's Avatar
Quoted: 5066 Post(s)
Liked: 3290
DVD resolutions are considered "SD" and those are 16x9. SD doesn't mean 4x3. and the 16x9 resolution for 480p is 848x480.
wmcbrine likes this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #3 of 4 Old 06-20-2019, 05:15 AM
wmcbrine's Avatar
I can't comment on The Simpsons, but aspect ratio and resolution are independent.
In addition to DVDs, you can nowadays often find OTA subchannels in 16:9 480i (while others remain 4:3).
Although 4:3 HD is rare (maybe found on some Blu Rays? never on broadcast).
57 channels and nothing on
wmcbrine is offline
post #4 of 4 Old 09-11-2019, 11:29 PM
Purple X's Avatar
Quoted: 173 Post(s)
Liked: 195
Just read the review comments in iTunes....It seems the correct 4:3 SD episodes were replaced with "improved" 16:9 cropped versions sometime last year...
[edit] and there was plenty of 16:9 SDR content made in the transition period to widescreen starting in in the late 90s
Purple X is offline
Reply Video Download Services & Hardware
