Screen Mirroring Issues LGV20- Amazon Prime/Netflix/Youtube - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-07-2019, 10:33 AM - Thread Starter
Liked: 5
Not sure if this is the correct area but this issue has been happening for awhile now.
I have an LG V20 phone, using the most current update, and a Sony UBP-X700 blu ray player that has an issue when screen mirroring (or called miracast). When I have it connected to my blu ray player, i get intermittent popping sounds from my home theater speakers. It isn't constant but it happens every 60 seconds or so. Sometimes less, sometimes more. It is incredibly annoying.
The only way to get less popping is to put my phone in airplane mode or turn my data off. But in both cases the popping still happens.
I do not have wifi, so i can't use the built in apps. So i download shows onto my phone to watch when i am home.
This happens no matter the content i stream. If you need any more info, i will do my best to provide it
Has anyone else experience this issue? Or have any suggestions?
peekatoad is offline
post #2 of 2 Old 06-05-2020, 07:06 PM
Ivanolson's Avatar
Liked: 0
I am also having this problem, have you solved it?
Ivanolson is offline
Reply Video Download Services & Hardware
miracast
