Channel Master CM-7000 Digital to Analog Converter - Page 50 - AVS Forum | Home Theater Discussions And Reviews
post #1471 of 1489 Old 09-25-2013, 06:50 AM
Floydage's Avatar
Quoted: 172 Post(s)
Liked: 86
Originally Posted by seatacboy View Post
My RCA U-remote had a specific CM converter box code. Is the Pioneer code one for a cable-TV box or something like that - I know there was not a Pioneer CECB (or "DTC" as RCA calls it).
Yes, would be under cable box rather than converter box. I think really more for older u-remotes that don't have converter box programming. Also requires turning on the Pioneer cable box function in the CM's menu (sounds like you could get in the user menu with the RCA). You could try it if you have an older u-remote or maybe even try it with the RCA via programming for a cable box.
That seems weird though as a converter box-dedicated u-remote should have good functionality. Does the mute function work? Also try the arrow keys rather than the volume keys. I'll have to try mine again when I get a chance but currently have jury duty (I don't have it programmed anymore as I got an HD tuner).
Edit P.S. Also watch for pass-thru or punch-thru function on the RCA that makes the TV take priority on the volume control. Check you RCA manual.
Floydage is offline
post #1472 of 1489 Old 09-26-2013, 04:23 PM
Floydage's Avatar
Quoted: 172 Post(s)
Liked: 86
Update: They plead out so I'm done! smile.gif My modern Philips u-remote (i.e. utilizes converter box codes) controls the volume no problem; it is capable (with a program setting) of setting the TV to punch-thru though which would cause your problem. My ancient RCA u-remote (Pioneer cable box code) does not control the volume as it has a fixed punch-thru for the TV.
Floydage is offline
post #1473 of 1489 Old 10-22-2013, 08:59 AM - Thread Starter
seatacboy's Avatar
Quoted: 46 Post(s)
Liked: 29
Thank you! Using a $6 Philips u-remote from Big Lots solved the problem, it controls the volume and other features that the RCA u-remote could not.
seatacboy is offline
post #1474 of 1489 Old 02-17-2014, 12:10 AM
hitbyambulance's Avatar
this box was a pile of disappointment. out of three purchased, two died (capacitors) and one sometimes reboots when it's first powered on.
hitbyambulance is offline
post #1475 of 1489 Old 02-17-2014, 07:45 AM
jjeff's Avatar
Quoted: 867 Post(s)
Liked: 334
Yes it's really bad that CM apparently took the low road and used sub standard capacitors :( Knock on wood mine are all still working(4 but only 2 in use) but it sounds like it's just a matter of time......when it works, as mine does, it has the potential to be one of, if not the best CECB made, again too bad so many seem to be failing. Unless one really wants the quality of the S-video output(as I do) or nice guide, I think one of the Zenith/Insignia CECBs are probably a better choice.
jjeff is offline
post #1476 of 1489 Old 02-17-2014, 09:04 AM
Floydage's Avatar
Quoted: 172 Post(s)
Liked: 86
Was this capacitor problem only certain manufacturing dates? My two boxes are still going strong (knock on wood) although I just use them for recorder tuners. Yet the first years of CECB-time it was my main tuner (acquired an HD tuner on the cheap a couple of years ago). I say "it" because one was used for the main TV and one for the bedroom TV (light use), and I would swap them after several months to even out the use.
I have experienced a problem where they the pic goes 'off in the weeds' infrequently which requires me to pull the cord live to give it a hard reset (normal power toggling doesn't work). When it does this it produces really bad interline twitter. Of course this really sucks when a box does this as a recorder tuner, I need to get in the habit of checking the PQ when setting up a recording.
____________________
You're welcome seatacboy!
Floydage is offline
post #1477 of 1489 Old 02-17-2014, 10:14 AM
jjeff's Avatar
Quoted: 867 Post(s)
Liked: 334
I've never heard of any specific dates, my boxes are basically original when the first came out.
I'm not sure why some people experience problems but others not, same thing with older DVD recorders where I have several that are working just fine while others have had to have the capacitors replaced :confused: I wonder if it has to do with the users local power or if it's just the luck of the draw. If the later I'd call myself lucky and as you said........knock on wood :)
jjeff is offline
post #1478 of 1489 Old 02-17-2014, 03:08 PM
Floydage's Avatar
Quoted: 172 Post(s)
Liked: 86
Yeah mine are earlier vintage too, well when the coupons first came out. And the cap problem posts seemed like were folks complaining they've only had them for a year or two. Hmmm, makes me wonder - later cost reduction? Or akin to Allied forces bombing Nazi factories late in the war? biggrin.gif (antique gun collectors are all too familiar with this issue in regards to the Walther P38 9mm pistol).
Floydage is offline
post #1479 of 1489 Old 02-17-2014, 08:08 PM
hardly's Avatar
In my experience, I used them 24/7 on TiVo boxes. One went three years, the other four before losing the caps.
hardly is offline
post #1480 of 1489 Old 02-18-2014, 08:55 AM
Floydage's Avatar
Quoted: 172 Post(s)
Liked: 86
How long ago do you think you bought those? I'm thinking that if it was about 4 years ago then they're possibly* several years later build dates than jjeff's and my units.
*Depends on who you bought them from, warehouse storage, etc.
Floydage is offline
post #1481 of 1489 Old 02-18-2014, 12:04 PM
hardly's Avatar
They were purchased in 2009. I replaced them with DTT-901's in 2013. Still running 24/7.
Gave the CM-7000's to Whitebar.
hardly is offline
post #1482 of 1489 Old 02-18-2014, 01:19 PM
Floydage's Avatar
Quoted: 172 Post(s)
Liked: 86
After further review, same here (Jan. and May from Solid Signal). I thought earlier in the CECB program but I'm really good at procrastinating things. redface.gif
Now I wonder if my infrequent problem mentioned above could be due to some of these caps, maybe induced by insufficient noise filtering. I know my Zinwell ZAT-970A's freak out when I toggle a fan on the same circuit but they only have a mere wall-wart for a power supply; my lone ZAT-950A does the same thing but I don't have to re-tune the channel to get it to snap out of it (different tuner module and maybe other components).
Floydage is offline
post #1483 of 1489 Old 02-18-2014, 01:58 PM
hardly's Avatar
It may be that my problems were exacerbated by defeating the energy saver so that they run 24/7.
hardly is offline
post #1484 of 1489 Old 09-22-2016, 04:35 PM - Thread Starter
seatacboy's Avatar
Quoted: 46 Post(s)
Liked: 29
Channel Master is rolling out a Digital to Analog TV converter which apparently is not CECB-certified. The web site indicates that "the CM-7000 Digital to Analog Converter is currently in production and will be available soon at your local electronics retailer."
CM certainly has a reputation for providing top-notch OTA products. However, I am concerned about the box's front branding as "HDTV Compatible" and "HD" (see picture on the information sheet).
Nothing indicates this box provides High Definition 720 or 1080 output. It should correctly bear the SDTV logo, not the HDTV logo with the legalistic phrase "compatible" in small print. I am also a bit disappointed that the product info sheet didn't provide ATSC reception specifications.
Anyone have more knowledge about this product, and why they have labeled this SD-only box as "HDTV" and "HD"?
Channel Master has introduced a brand-new replacement model CM 7003, which isn't "crippled" by the US Government's SD-only CECB specifications. The CM 7003 offers component video and HDMI outputs for HD, and is priced at $50.00 I'm told this uses a newer, more advanced ATSC chip set than the units introduced in 2007-2008. http://www.channelmaster.com/Digital..._p/cm-7003.htm
post #1485 of 1489 Old 09-23-2016, 12:34 AM
P Smith's Avatar
Quoted: 1042 Post(s)
Liked: 486
you should post the _old_ info in other more appropriate thread, not here
:backtotop:
P Smith is offline
post #1486 of 1489 Old 09-23-2016, 06:31 AM
rabbit73's Avatar
Quoted: 820 Post(s)
Liked: 348
I think what seatacboy did is entirely appropriate. He is posting new information on the old thread for continuity. He has also mentioned the new 7003 here:
https://www.avsforum.com/forum/186-co...l#post46981585
The next step would be to add the feedback for the new 7003 here or start a new thread for it.
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #1487 of 1489 Old 09-23-2016, 08:02 AM
P Smith's Avatar
Liked: 486
Originally Posted by rabbit73 View Post
...start a new thread for it.
that would be appropriate step
P Smith is offline
post #1488 of 1489 Old 09-27-2016, 02:23 PM - Thread Starter
seatacboy's Avatar
Quoted: 46 Post(s)
Liked: 29
New thread created. I still have a CM 7000 somewhere in the spare bedroom but currently not using it.
post #1489 of 1489 Old 09-27-2016, 02:24 PM
Liked: 0
looks good
ericr1123333 is offline
Reply Converter Box (CECB)
