Converter Box Recommendation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-18-2018, 10:28 PM - Thread Starter
Liked: 0
New to forum but hopeful someone with a similar situation can recommend a converter box from personal experience. I just bought a furnished home in a retirement resort in AZ. The home came with an almost new 60" Vizio 'Home Theater Display' (no tv tuner). The resort provides free high def cable to residents that requires no box, just connect to tv. My understanding is that the signal is clear QAM (unencrypted). I want to find an hdmi hdtv converter box that will pass through the high def stations and hopefully with 5.1 surround (will run the converter through an a/v receiver then to Vizio using hdmi cables).
The boxes I see on Amazon all seem to get a lot of 1 & 2 star ratings and many reviews cite DOA units or short unit life. Most say they are for OTA conversion but do not mention being able to process clear QAM signals. So anyone out there found a decent box for their Vizio that will meet my needs? I'm more concerned with picture/sound quality and less with recording but might use that feature at some point. Also a decent channel guide would be nice. Willing to spend a bit more if anyone has found a decent box for similar needs. Thanks in advance for any suggestions.
[email protected] is offline
post #2 of 9 Old 11-08-2019, 02:52 PM
Liked: 0
I see that this is a year old, but here goes anyway. LOL. If your Vizio is new enough to not have a tuner it is almost certain to have an "ARC" HDMI port. I think you can just use this port directly to the receiver to do what you want. The resort cable should hook to your RF connector on the TV, the ARC port will send audio to the receiver. OR, use the RCA "Audio Out" jacks on the TV to RCA "Audio In" on the receiver.
jd-ford-hd is offline
post #3 of 9 Old 11-09-2019, 07:14 AM
rabbit73's Avatar
Quoted: 903 Post(s)
Liked: 394
If the Vizio display doesn't have a tuner, it will not have an RF connector for the cable coax. An external tuner that will receive clear QAM is needed.
https://www.myresnet.com/public/file...tal_tv_faq.pdf
Do Google search:
tuner that receives QAM
or
qam tuner box
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #4 of 9 Old 11-09-2019, 11:57 AM
JHBrandt's Avatar
Quoted: 2852 Post(s)
Liked: 1387
Most of the "cheapos" you see at Amazon are OK if all you want is a tuner with DD 5.1. My usual recommendation is either a HomeWorx HW-150PVR or an iView 3500STBII, because I know both of those will do clear QAM, "officially" support DD 5.1, and have at least a minimal level of customer service. There is a channel guide, but only for the local stations, and I'd just call it "usable," not "decent."
It seems strange that a "TV" (actually just a monitor) would include ARC if it doesn't include a tuner! Where would the audio for the ARC come from? A different HDMI port? If that were the case you might as well go from the source to the AVR and then to the monitor as Jim wants to do and not even bother with ARC.
JHBrandt is offline
post #5 of 9 Old 11-09-2019, 02:33 PM
Liked: 0
This is from Vizio website(see pic). They state that all "SmartCast" TVs do not have tuners, but I think some do. I assumed the park cable was already hooked to this "nearly" new 60” Vizio, by some means (RF, RCA, HDMI, etc.) Anyway, here’s specs, no tuner with ARC output. 😀
ID:	2638668   Click image for larger version
post #6 of 9 Old 11-09-2019, 02:59 PM
JHBrandt's Avatar
Liked: 1387
It wouldn't totally surprise me; it seems rather useless, but manufacturers have been known to add features of questionable value to their products for marketing purposes (ahem - 4K - ahem).
Of course, manufacturers have also been known to get their specs wrong on occasion. Often they're copied/pasted from earlier models and if a change was made between models, the change might get missed when the new model's specs are written.
More interesting to me, though, is Vizio's claim that they sell tuners separately. A quick Amazon search came up with several Vizio TVs, tuner boards, and remote controls, but the only external tuners that came up were by ViewTV and someone calling themselves "Vmade;" none by Vizio themselves.
The ViewTV tuners are similar to the HomeWorx and iView tuners I mentioned, and I think the "Vmade" one is too. They're perfectly fine tuners for a Vizio, but they connect via HDMI, so there's no need for ARC if you use one of them.
JHBrandt is offline
post #7 of 9 Old 11-09-2019, 07:31 PM
ncsercs's Avatar
Quoted: 175 Post(s)
Liked: 98
Is the HomeWorx HW-150PVR or iView 3500STBII still being manufactured (even with their questionable lifespan)?
Haven't heard of any 'new' boxes coming out or have they run their course?
Nick
Every day I beat my own previous record for the number of consecutive
days I've stayed alive. - George Carlin - 1996
ncsercs is online now
post #8 of 9 Old 11-10-2019, 07:08 AM
Liked: 0
ARC can be handy.!
MY SETUP:
*antenna coax split; one to HW130STB tuner/recorder and one to Vizio 65” RF tuner (tested the "pass thru" RF on the box, better results to split before the box.!)
*HDMI cable from HW130 tuner to Sony STR DH720 receiver w/Dolby, 5.1, etc.
*HDMI cable from receiver to the same 65” Vizio HDMI ARC
RESULTS:
*With TV remote in hand, I can change inputs to view OTA channels w/TV's tuner while recording OTA program on HW130.
*The TV speakers are turned off in settings, the TV remote volume button, thru ARC, controls the receiver volume.
*The TV remote mute button mutes the receiver volume.
Full 5.1 surround w/powered subwoofer is enjoyed, when applicable, in our family room.
I have four (4) remotes within reach. Vizio TV and Homeworx tuner used daily. In the drawer next to me, used rarely, are the Channelmaster rotor control and Sony receiver remotes.
Don’t go off on me about programming remotes.! LOL.! I’m old, I like dedicated remotes for each device.! 😂🤣😂
post #9 of 9 Old 11-15-2019, 02:30 PM
JHBrandt's Avatar
Liked: 1387
Surprisingly, not only are both of those still made, they're up to new firmware versions! (V6.1 for the HW-150PVR; 1903, which I think stands for March 2019, for the 3500STBII)
As for lifespan, I noted in the iView thread:
Sounds like the average lifetime of these (at least the older 7816-based models) is about 4 years before that capacitor goes. If so, all the old ones are probably coming up on failure if they haven't already.
Luckily the capacitor that usually fails can be replaced, saving the box.
JHBrandt is offline
Reply Converter Box (CECB)
