Power Recline Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-01-2008, 06:57 AM - Thread Starter
CJO
CJO's Avatar
I just finished my wiring, but wanted to make sure that I didn't miss anything. How many amps does a typical power recline system use? I plan to have 6 to 8 recliners, most likely Berkline, but it could be another brand.
Would a shared 15A circuit be enough? Does the motor put much feedback into the line?
CJ
coneilliv at aol dot com
The Dark Knight Theater
(a bunch of good reference links and material in first 15 posts)
CJO is offline
post #2 of 11 Old 10-01-2008, 07:50 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
If I'm not mistaken the power supply and motors for the chairs are low voltage.
oman321 is offline
post #3 of 11 Old 10-01-2008, 08:00 AM
Cathan's Avatar
15 amp circuit will be more than enough.
Cathan is offline
post #4 of 11 Old 10-01-2008, 08:23 AM
rsh
rsh's Avatar
Quoted: 157 Post(s)
Liked: 96
CJO,
The Berkline motors are rated at 3 amp max, but the 15 Amp circuit would be more than enough.
Never had a problem with the motor putting the feedback into the power line.
Hope this helps...
Roman
rtheaters.com
FusionCollectionSeating.com
Ultimate Home Entertainment
rsh is offline
post #5 of 11 Old 10-01-2008, 08:56 AM
Quoted: 5507 Post(s)
Liked: 5096
Some time ago for the sake of science (actually the same question was posed on the forum) I plugged a Berkline 099 into my Belkin PF60 power supply. The PF60 shows the amp draw of items plugged.
OK, after a minimum of 10 round trips I can say with 6 Sigma Accuracy that at no time did the draw register over .8 amps. That was with a load. Some would say Big Load.
post #6 of 11 Old 10-01-2008, 08:59 AM
Liked: 5096
post #7 of 11 Old 10-01-2008, 10:02 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
I know, I was wondering too. I had an issue with one of the chairs not retracting and had to lay it on its back. The powersupply actually had connectors for 9v batteries??? In any event I figured the powersupply has a tranformer built in. Didn't look to much into it once I got it working but I figured if it coverts it with a transformer it couldn't possibly draw anything significant as proven by your test.
Of course I could be totally wrong which wouldn't be the first time
oman321 is offline
post #8 of 11 Old 10-01-2008, 11:02 AM
tlogan6797's Avatar
Quoted: 155 Post(s)
Liked: 167
Have you been holding out on us Big? I've got a PMP and I don't talk like that. Or do I have start asking you about your process to move that big load? Is that process repeatable? Did you do a CBA? What is your ECTC? Do you have an ACTC? And the biggie (so to speak), are you computing EV over the life of this project?
I can say with 6 Sigma Accuracy that 86% of all statistics are made up on the spot.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #9 of 11 Old 10-01-2008, 11:08 AM
Liked: 5096
post #10 of 11 Old 10-01-2008, 06:13 PM - Thread Starter
CJO
CJO's Avatar
DMAIC bro DMAIC
My wife's an MBB and she thought that this was a bit nerdy!
CJ
CJO is offline
post #11 of 11 Old 10-01-2008, 06:15 PM - Thread Starter
CJO
CJO's Avatar
But thanks for the info
CJ
CJO is offline
