AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Dedicated Theater Design & Construction (https://www.avsforum.com/forum/19-dedicated-theater-design-construction/)
-   -   SOWK's Home Theater Build (https://www.avsforum.com/forum/19-dedicated-theater-design-construction/1325369-sowks-home-theater-build.html)
SOWK 03-30-2011 01:54 AM
69 Attachment(s)
SOWK 03-30-2011 01:56 AM
66 Attachment(s)
Progress...
https://i.imgur.com/27zn007.jpg
http://i1224.photobucket.com/albums/...ette_boy/2.jpg
http://i1224.photobucket.com/albums/...ette_boy/6.jpg
http://i1224.photobucket.com/albums/...ette_boy/7.jpg
http://i1224.photobucket.com/albums/...ette_boy/8.jpg
http://i1224.photobucket.com/albums/...ette_boy/9.jpg
http://img405.imageshack.us/img405/8789/picture3m.jpg
http://img59.imageshack.us/img59/6817/picture1yau.jpg
http://img832.imageshack.us/img832/9113/picture8hg.jpg
http://img839.imageshack.us/img839/4403/picture16uj.jpg
http://img204.imageshack.us/img204/4193/picture1nh.jpg
http://img19.imageshack.us/img19/1849/picture7wfr.jpg
http://i1224.photobucket.com/albums/...y/eff17fa1.jpg
http://i1224.photobucket.com/albums/...y/367e868f.jpg
http://i1224.photobucket.com/albums/...y/0ebafed7.jpg
http://i1224.photobucket.com/albums/...y/9896a736.jpg
http://i1224.photobucket.com/albums/...y/9ab712e7.jpg
http://i1224.photobucket.com/albums/...y/20361aa2.jpg
http://i1224.photobucket.com/albums/...y/b8dfa250.jpg
http://i1224.photobucket.com/albums/...y/e3164c7e.jpg
http://i1224.photobucket.com/albums/...y/c7a0d772.jpg
http://i1224.photobucket.com/albums/...y/8dd29bf3.jpg
http://i1224.photobucket.com/albums/...y/cbe1dbcc.jpg
http://i1224.photobucket.com/albums/...y/77b32186.jpg
http://i1224.photobucket.com/albums/...y/3b164230.jpg
http://i1224.photobucket.com/albums/...y/1e82fb69.jpg
https://i.imgur.com/JiE7l5N.jpg
https://i.imgur.com/dPWZCmG.jpg
https://i.imgur.com/M43qmTu.jpg
66 Attachment(s)
VIDEO
Cinema Projector
JVC DLA-RS540 Datasheet:
JVC DLA-RS400 Datasheet 1
JVC DLA-RS400 Datasheet 2
Additional Information:
JVC DLA-RS400 Manual
JVC Profesional
Cinema Playback
OPPO 203 Datasheet:
AUDIO
Cinema Processor
Datasat RS20i Datasheet:
Datasat RS20i Datasheet - Front
Datasat RS20i Datasheet - Back
Datasat RS20i Pictures:
Datasat RS20i - Front
Datasat RS20i - Back
Datasat Digital Entertainment
Datasat Digital Entertainment Dealer
SOWK 03-30-2011 01:57 AM
66 Attachment(s)
Barely livable setup until theater room is done... J/K
But here is a picture of the living room.
http://i1224.photobucket.com/albums/...y/84a68782.jpg
SOWK 03-30-2011 02:29 AM
66 Attachment(s)
Reserved
BIGmouthinDC 03-30-2011 05:48 AM
Originally Posted by SOWK View Post
Question(s) for the pros... Will keep updating as I have them...
1. Insulation in the soffits?
Insulation in every concealed cavity adjacent to the theater to tame resonances. This includes risers, ceilings, soffits, etc. Stage should be filled with sand.
oman321 03-30-2011 05:50 AM
3 Attachment(s)
Welcome to this side of the forum SOWK.
Insulation in soffits? Yes, you don't want any empty cavities to act as a drum if you could help it. You may want to consider as others have done, to leave the bottom of the soffit open and finish it with fabric so it can act as a bass trap. The thing is if you are planning to do something like that or are concerned about sound isolation you may want to drywall the room first then build your soffits.
Good luck.
SOWK 03-30-2011 06:03 AM
66 Attachment(s)
Oman & Big, thank you for the input.
Oman321, The contractor has already started the soffits... so I will filling with cable tubing / insulation and will have to go external for the bass traps. That would have been a great plan though.
Or is there a way to still do this even if the drywall is not up yet?
Also new question added.
oman321 03-30-2011 06:47 AM
3 Attachment(s)
If sound isolation is not a concern then yes, you can stuff with insulation and cover the bottom with fabric. If your going the whole double drywall and green glue route then I would say no as it would totally defeat your sound proofing efforts.
As far as subs are concerned, a simple test is to place the sub at the seating position and then going around the room on hands & knees finding the position where the sub sounds/feels the best. Tuff to do in an unfinished room but you can probably get a fair analysis when everything is framed out and insulation is in place and before drywall goes up.
Having said that, I simply had one place where my sub would fit and that was dead center below the screen. With bass trapings at the corners of the screen wall it has worked out well.
At a minimum I would move the subs foward from the corners to the false wall, and use the corners for OC bass traps.
oman321 03-30-2011 06:59 AM
3 Attachment(s)
Just checked your video out SOWK, pretty cool. Nice open space you have to work with there. What are the rooms dimensions? How many seats are you able to get in there?
SOWK 03-30-2011 07:05 AM
66 Attachment(s)
5 chairs...
3 front row
2 in back row
tbraden32 04-05-2011 11:06 AM
How deep is your false wall? Looks extremely deep?
Mike_WI 04-05-2011 11:15 AM
SOWK -
Good to see a build thread.
You should definitely talk to Wayne for advice.
Mike
SOWK 04-05-2011 12:18 PM
66 Attachment(s)
7'
This is going to be an audiophile room as well.
Not just home theater.
Need good distance from side and front wall for best imaging and soundstage.
HuskerOmaha 04-05-2011 02:59 PM
Supercool videos online. I was getting into the song. Great way to show progress!
UNICRON-WMD 05-10-2011 06:38 AM
Very nice man. Cool videos. I really wish I had more space in my basement for a bigger theater. I was only able to fit 14x19 room.
Also, only 5 seats? I am positive you can fit 3 seats on the riser and 4 seats in front.
SOWK 05-10-2011 09:45 AM
66 Attachment(s)
This is more a Personal/Family Theater. Plus I am already over budget.
Mike_WI 07-03-2011 10:11 AM
Looking good.
Happy 4th!
Mike
SOWK 07-03-2011 10:26 AM
66 Attachment(s)
Thank you Mike! You too...
Btw...
Originally Posted by Mike_WI View Post
"It’s like 'how much more black could this be', and the answer is none.
None more black."
- Nigel Tufnel (Spinal Tap)
You'll know what that truly means with my pictures on Thursday night.
Was changed from Wednesday night.
SOWK 07-07-2011 04:46 PM
66 Attachment(s)
And the blackness begins!
SOWK 07-11-2011 06:36 PM
66 Attachment(s)
I know you're all going to be super jealous of my new screen...
Nothing but the highest quality here!
Image testing:
Included in the last picture is 2 of my friends for screen size comparison. Both are ~ 6' in height.
Brad Horstkotte 07-12-2011 07:09 PM
That temp screen sure looks familar - kind of amazing how good a picture you can get with a sheet or cheap fabric or wall. But I'm glad I graduated to a real screen a few days ago!
Edit: I like the screen progression in the first couple posts, good idea (i.e. I will have to steal it).
HuskerOmaha 07-12-2011 08:10 PM
Wow. You have a ton of room behind the screen. That will make things easy.
In other news, I lost out on my bid to buy Wisconsin season tickets this am.
SOWK 07-13-2011 04:08 AM
66 Attachment(s)
I always wanted a quick way to see progress from start to finish on peoples build threads. So I made mine that way Lots more to come yet.
SOWK 07-13-2011 04:39 AM
66 Attachment(s)
I plan on doing a lot behind the screen too.
Sorry to hear about your lose though.
SOWK 07-13-2011 07:39 PM
66 Attachment(s)
1 of the 5 chairs
SOWK 07-16-2011 08:05 PM
66 Attachment(s)
Molding are in and ready for caulk and wood filler.
Looking down into the main entrance area.
Entrance base molding.
Theater base and crown molding.
Full update avail in post 1.
SOWK 07-17-2011 05:02 PM
66 Attachment(s)
Below is a paint.net artistic rendering of what I want the finished project to look like minus the carpet and possible molding color.
SOWK 07-22-2011 05:49 AM
66 Attachment(s)
Small updates from here on out as it is now in the finishing stages...
Fancy outlet decor:
Top stage is up:
Back of the room with riser:
SOWK 07-24-2011 08:06 PM
66 Attachment(s)
Update:
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
