The "BR" Theater / Patio / Bar Project - Page 91 - AVS Forum | Home Theater Discussions And Reviews
 210Likes
post #2701 of 3094 Old 03-25-2015, 06:33 AM - Thread Starter
damelon's Avatar
Liked: 345
Originally Posted by marlon1925 View Post
By the way, what's the distance of the bottom of your screen from the floor?
Well currently my screen goes from the stage to the soffit. There is no gap. The first picture of the first post of my thread still shows my original screen (Look a few down to see the new screen) So the height of the screen is the height of the stage, which ends up being about 10.5 inches off the floor. That is the frame at least.... and the border of the frame is 3.5 inches thick or so.
I'll admit that my new 16:9 screen is nice in a lot of cases, but horizontal masking panels are so much more of a P.I.T.A. than vertical ones. I noticed that with my scope screen, I had to change panels rarely, and even so, they were easy and quick to put in. Now there are 4 panels, and I need to take them on and off a lot more.
How did you apply the insulation to the wall and ceiling sir? did you use some kind of glue or was it stapled?
Insulation just sort of friction fits between walls as it is made to be the standard width of standard stud spacing. Ceiling joists vary, but for me the joists were closer together than the insulation so it also friction fit and sort of bowed downward. Usually if you put up wall insulation and use paper facing you can use some staples along the studs through the paper for an even look.
On the stage sir, is it cement floor>stage filled with sand>1st layer plywood>felt>2nd layer of plywood?
Concrete -> Roofing Felt -> Stage (With plastic liner inside of the cavities) filled with sand -> 3/4" plywood -> Felt -> 3/4" Plywood.
and on Riser is it cement floor>riser filled with pink insulation>1st layer plywood>felt>2nd layer of plywood?
Cement Floor -> Felt -> Riser filled with thick pink insulation -> 3/4" Plywood -> Felt -> 3/4" Plywood
Keep in mind when doing stage and riser how you want the "lip" or overhang to be. Some people want to have an overhang, others a flush edge like a box. If you are going to put in accent lighting you will need a lip or trim so that the lighting can be hidden from direct view. There are also a variety of step options. Some recess steps into the riser, others put them outside. Adding them outside of the riser is a lot easier construction wise and also is more obvious to people as a step.
Originally Posted by jimim View Post
3/4" i would assume cause i have asked damelon a million questions about his stage and riser. lol
Correct! marlon as an FYI jimim just did this in his own build, so I think he has the stage building measurements memorized!
I can't stress to everyone enough the importance of HVAC when doing a well-insulated theater. Think about an insulated coat. It keeps you warm! If you have done the full soundproofing you will have very little to no fresh air other than your HVAC, and the projector, your rack equipment, and just human BTUs will heat up a theater quickly. I did one vent and one return but it wasn't enough.... at least, the way I did it. Make sure you get some good consultation when it comes to your HVAC setup! (I am not a good resource for this!)
damelon is offline
post #2702 of 3094 Old 03-25-2015, 06:53 AM
marlon1925's Avatar
Quoted: 62 Post(s)
Wow!
Thank you very much sir. This is very helpful.
My contractor just finished pouring concrete for the flooring. I'm so excited to apply all of this. I just wish I could get the materials or at least alternate in the local suppliers.
By the way sir, you mentioned about spacing of the studs? Uhmmmmm...sorry for this question but I have to ask this. What's the spacing really?
You used green glue to stick the felt to the floor and onto the 1st layer of plywood? And the plywood to the felt? Am I correct sir?
And uhmmmmm Jimim? Care to share dimensions of the stage and riser?
I think my problem with be with my AC
I'm not sure if a split type unit will do the job.
One more thing, I couldn't find any local supplier for the clips and hat channel. Hmm..I'm thinking of just fabricating it in the local machine shop
marlon1925 is offline
post #2703 of 3094 Old 03-25-2015, 07:01 AM - Thread Starter
damelon's Avatar
Liked: 345
Wow!
Wall stud spacing is 16" on center almost everywhere.
Actually a mini-split would probably work very well, since it is dedicated to your theater. The one I have in my theater is not a dedicated unit, but shared with the sun room in my home, so I do lose some of the "pressure"... plus it doesn't help that my theater room is the furthest from the HVAC. Your mini-split should be just fine.
I did a recap for the stage recently here
https://www.avsforum.com/forum/19-ded...l#post32579777
And you can go to jimim's build thread to see how he did it : He can still take pictures and measure to a much greater detail as his stage is still bare!
Jimim's Thread -> https://www.avsforum.com/forum/19-ded...e-2-build.html
damelon is offline
post #2704 of 3094 Old 03-25-2015, 08:56 AM
jimim's Avatar
Quoted: 543 Post(s)
Liked: 154
lol yo totally memorized! i see those numbers in my sleep! but hey it looks perfect! thanks again for all that!
@marlon . . . check out my build for the pics with the measurements shown on the tape even. figured maybe i will save someone from a million questions like i had.
marlon1925 likes this.
jimim is offline
post #2705 of 3094 Old 03-25-2015, 03:18 PM
marlon1925's Avatar
Quoted: 62 Post(s)
Thanks Jimim
post #2706 of 3094 Old 05-08-2015, 04:09 AM
BrolicBeast's Avatar
Quoted: 1802 Post(s)
Liked: 2121
Some pictures of the day. Didn't get everything done that we hoped, but we always set our goals high.
The first order of the day was to measure, mark and cut the 15 holes for the 3 inch recessed lights in the light tray.
Then Damelon wired them up while I filled all the nail holes in the columns and sanded getting ready for finishing.
These shots are just with the perimeter light tray lights. check out the bass traps Damelon cut and stacked.
I talked him into popping in the step lights.
Hey Damelon,
Quick question for you: how deep is your soffit, including light tray, from edge of light tray to wall panel? I'm thinking about doing exactly what you and Big did, but I want to make sure I'm not making my soffits way too deep. Right now, they measure 25" deep from edge of soffit to drywall, but after wall panels, it'll be more like 18" from edge of soffit to wall panels. If I add a light tray , i may be back up to the 20"+ depth range.
Thanks in advance! I know you're enoying your new IMAX experience, enhanced by the starry sky above!
BrolicBeast is offline
post #2707 of 3094 Old 05-08-2015, 06:23 AM - Thread Starter
damelon's Avatar
Liked: 345
Originally Posted by BrolicBeast View Post
Hey Damelon,
The soffit itself (without the light tray) is 16" wide by 10" tall.
The light tray gets a little more complicated. The bottom is 5.5" piece of MDF with 1/2" think MDF attached to the end that is 6" high. The total width at the bottom is 6" but the bottom also overlapped the edge of the soffit so it could be nailed into the bottom by about 1/2". So the interior "cavity" is 4 3/4 - 5" deep, since you deduct the 1/2" wide piece on the end and then the 1/2 - 3/4" overlap. This gave enough space for the little can lights, and now I use LED lights there, which makes me feel a bit better since they don't heat up like the original bulbs did! If you do decide to do a light tray BB (And you don't need to due to sconces) then remember to either not put on the inside face side of the light tray until you wire the lights or to allow the inside edge flip down somehow like a glove compartment. Doing any work up in the light tray after it was done is not pleasant since it is right up against the ceiling.
The new screen is awesome, especially for sports, the HTPC itself, and movies like Interstellar, but it is a royal pain in the ass for scope movies since I am constantly taking down and putting up panels. The horizontal panels can be tricky because of how they fit and if you don't do them just right then they will leave wrinkles in the screen material. (Extra felt on the back would help this) So a couple of times, I've had to take a hair dryer to warm it to get it back to normal. Plus now there is 4 panels to have sitting around against the wall. Don't get me wrong, I like the screen more than my old screen.... but the panels are a big hassle. If it didn't cost so much I would want motorized masking, it is just a ripoff.
As for the stars, they are beautiful, but I haven't done a whole lot of star viewing with the lights out since the first couple of weeks. I do use the black lights in the soffit often though, since it does showcase the stars and gives a low level light to the room to help people get out of their seats and see without a big dark to light type of feel in the room.
damelon is offline
post #2708 of 3094 Old 05-08-2015, 07:09 AM
tlogan6797's Avatar
Quoted: 155 Post(s)
Liked: 168
Damelon -
Just trying to get caught up again. Nice job!
This is a limitation of the Insteon products in general where both switches in a 3-way configuration have to be Insteon so they know each other's state.
Actually, I find it to be a feature as you can turn any two switches (as long as they a neutral in the box) into three, four or TEN-way switches if you want to, without the need for 3/1 or 4/1 wiring between them.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #2709 of 3094 Old 05-08-2015, 07:27 AM - Thread Starter
damelon's Avatar
Liked: 345
Damelon -
Nice to see you again!
No doubt you are right about multi-way switches, I was talking about it is a "cost" limitation. You can usually buy switches for almost nothing, where as an insteon switch would cost quite a bit. When you start talking multi-way then it becomes frustrating since you get the remote capability with just one but you have to continue to pay the full price for additional switches. The additional switches just end up being remotes for the primary one.
In any case I ended up using just one for the 3 two-way switches I replaced and then terminated/covered the old second box. In these cases, the two way switches didn't really matter as much. I will end up buying two control panels though, since I made all of my outdoor lighting insteon using the outdoor plugin part. The problem is there is currently no way to turn them on now other than through the phone app. So a single remote panel by my basement door where I removed one of the two way switches would be perfect.
damelon is offline
post #2710 of 3094 Old 05-08-2015, 07:48 AM
tlogan6797's Avatar
Quoted: 155 Post(s)
Liked: 168
OK, when you look at it from that cost perspective, yeah. Especially since we seem to be the DIY types around here.
If you're PAYING an electrician and have to run new 3/1, I think you come out WAY ahead.
Tom Logan
post #2711 of 3094 Old 05-08-2015, 09:36 AM - Thread Starter
damelon's Avatar
Liked: 345
For sure!
damelon is offline
post #2712 of 3094 Old 05-08-2015, 01:17 PM
Liked: 2121
Thanks for the info on the soffit! Man, that sucks on the screen....I have three same screen (just not yet assembled) and I'm worried about the masking panels now. Maybe I should not use them. Have you tried watching a movie without the panels? Are the unmasked sections extremely distracting?
post #2713 of 3094 Old 05-08-2015, 01:25 PM - Thread Starter
damelon's Avatar
Liked: 345
Yeah, it's pretty distracting. Once you are used to pitch black borders, the black-grey bars do get annoying, and it does wash out the picture quality quite a bit. It is not as bad when they are side bars though. I noticed it at the IMAX theater when I saw TDKR too, and at home during interstellar at the beginning. Mostly during dark scenes it stands out.
damelon is offline
post #2714 of 3094 Old 05-08-2015, 03:23 PM
Liked: 2121
Uh oh...hmmm...what causes the screen to wrinkle? is it the act of aligning the Two halves? I thought the magnets would automatically latch on without having to position them much. Would fu1l-width masking panels work better? I'll be trying them in a couple weeks, but just want to know what I should be prepared for.
how is your booster turning out? Did you end up fastening the booster to the riser?
post #2715 of 3094 Old 05-08-2015, 03:32 PM - Thread Starter
damelon's Avatar
Liked: 345
First, you can't really do full width masking, how would you take it off, it would be way too big for normal storage anywhere. Normally yes it is right where the pieces join, mostly on the bottom. It could be that the screen is slightly non-squared because the pieces fit a bit tight.... but they are on thin aluminum frames so the corners can push against the screen material if it isn't sitting quite right. Most of the time it is fine but I've seen it happen a few times.
The booster is great. I never did fasten it to the riser, in fact I only ever had planned to fasten the chairs to the booster but I haven't done that either. It is mostly a problem if I have kids in the room and they try to lean forward and push the leg rest down on the electric recliners. Due to the weight shift, the chair wants to tip forward. I just need to constantly supervise is all. Otherwise mission was accomplished there as far as viewing angle goes. The biggest thing in the way is my big doberman who doesn't always lay down right away. Then he gets in the way of the front screen now that it is floor to ceiling.
damelon is offline
post #2716 of 3094 Old 05-08-2015, 05:59 PM
Quoted: 5550 Post(s)
Liked: 5141
woven fabric screens are prone to showing stretchmarks as a result of masking that might push a bit on the fabric. Often in isolated spots, normally it goes away just like wrinkles when the fabric is rolled up and shipped to you. The only solution is a masking system that doesn't lean on the fabric, Those tend to be the mechanized masking systems $$$$$$$.
post #2717 of 3094 Old 05-09-2015, 04:34 AM
dengland's Avatar
Quoted: 92 Post(s)
Liked: 113
I don't know if it is because the market is so small, or what for the retail systems. Speaking from no experience, just reading some of the DIY threads over the years, the materials and the electronics involved don't seem to justify a price of $$$$$$$.
dengland is online now
post #2718 of 3094 Old 05-09-2015, 05:57 AM - Thread Starter
damelon's Avatar
Liked: 345
I think it is a combination of a small market plus it is work that most screen companies just don't want to do. There are a lot of motors and moving parts and it has to all be custom per screen. Most screen companies want to just deal with extrusions and fabric materials. The bigger companies do offer it, but yeah, it is way too expensive.
MrMister did one themselves and it turned out really well, but I believe the whole thing is that you have to do a DIY frame and build it around that. I read a lot about it when they were building it and it did seem like a lot of work to get it right. I also don't think it would work with a curved screen at all (For Brolic) As much as I do compain about masking, we are talking about something that takes 30 seconds of time when a movie starts. It isn't sexy doing it yourself or having the panels laying around when you aren't using them to be sure, but is that small amount of work worth $5-10k that companies charge for that? No way. If it was something more like $1000 I think a lot more people would buy it.
I'd seriously consider building a DIY one over my current screen if someone local like BIG wanted to help tackle the project with me. Unfortunately, due to my super large format screen now, there is no place on the top and bottom for the masking system to go except into the stage and soffit itself, so I have to live with it in this theater I think unless I wanted to shrink the screen size.
damelon is offline
post #2719 of 3094 Old 05-09-2015, 07:44 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2725
Sounds like a badass DIY project. I'd like to tackle one at some point but after I start with a simple fixed screen and my theater and home are otherwise semi completed. That's a long way off...
Mfusick is offline
post #2720 of 3094 Old 05-10-2015, 07:24 PM
Liked: 2121
I discussed a motorized masking system pretty extensively with SeymourAV--I was even willing to switch from curved to flat, but I couldn't swing it. The only motorized masking system I'd be willing for fork over the $$ for was the Carada Masquerade, but they don't make a 16:9 masking system at 12' wide (they do make a 12' wide 2:35 motorized mask). Motorized masking was the only thing that I was willing to give up the curved configuration for, but it just wasn't feasible.
post #2721 of 3094 Old 05-11-2015, 06:06 AM - Thread Starter
damelon's Avatar
Liked: 345
Yep, this was pretty much what I discovered too. Though the one thing is that if you do have a scope screen, vertical only masking isn't difficult to do. You can even just do it with curtains if necessary. It is when you get into 4-way masking or horizontal masking that it becomes complex. On a curved screen, I haven't even seen automated vertical masking.
damelon is offline
post #2722 of 3094 Old 05-18-2015, 05:43 AM
Dan Rankin's Avatar
Damelon-- Have been following your build and the recent changes for a while -- very impressive.
Your recent screen size upgrade got me thinking if I could do something similar. But I have a CIH curved scope screen setup with manual masking. I built black velvet covered panels that I use to mask the right and left sides when viewing 16:9 material. The panels fit over the top of the sides of the screen using cabinet magnets that are screwed into a soffit above and soffit below the screen, so they never touch the screen material itself.
So now I am thinking about whether I could use a similar approach if I switch to a CIW setup like you did, using a flat screen instead of a curved one. I am pretty sure I could make a couple of bottom panels for horizontal masking that would just sit on the bottom soffit using magnets, similar to the approach I already use for the vertical masking. Then I would need a solution for the top, perhaps hinges that would allow two panels to swing down from the top soffit when in use to view 2.35:1 material, and something to fasten them horizontally to the soffit unobtrusively when viewing 16:9 material. Or I suppose another approach for the top might be a short, black screen that lowers down from the soffit for masking.
Thank you for the inspiration.
Dan Rankin is offline
post #2723 of 3094 Old 05-18-2015, 06:00 AM - Thread Starter
damelon's Avatar
Liked: 345
Dan, Thanks for the compliment! Yes, the screen I currently have does use magnets. Due to the size of the screen, they are divided up into 4 panels, so there are magnets along all of the edges of the screen frame and the panels that touch the screen frame, as well as magnets along the joining area of the panels so they sort of stick to each other. In addition, there is a small fabric flap between the two panels so that there is no gap if the fit isn't exactly perfect.
I like your idea of hinges a lot. If there is room above and below the screen, this would easily be doable. The primary thing is that you want to make sure they could flip up or down completely. In that case you wouldn't need to have 4 panels but could stick with two. This would make the masking process very easy. The top side is more complicated if you don't have the space to flip it up flap since if your scenario is like mine, it would be at an odd angle if it flipped up to the soffit itself. If they would go completely up and completely down though you could easily work it with magnets to get it to stick. It would give it an odd look when the panels are flipped open, but It would make the panel storage issue moot. You would have to get the right hinge though, or have it so the panels did not rest inside of the frame itself but over the frame. The over the frame part would be easiest, and if the frame was flush with the screen wall then it would work perfectly. You could even hide the magnets to keep it open behind some screenwall fabric. If they are both black it could blend in well, though unlike most panels, you would have to finish both sides or it wouldn't look too good when it was flipped open. Interesting idea, and one I haven't seen.
It is really too bad that once you finish a theater a certain way that modifications cost a lot. I would really like to have designed the screenwall in such a way that I could do 4 way masking but there just isn't room, which is unfortunate. In addition, I think things like hinges, snaps, and magnets are something I would have liked to use in a lot of places:
1) Make all of my panels removable via one of the methods above
2) Make my front two columns swing open with hinges, so they could be used as storage or something similar
3) Make the side panels of my screenwall swing open like doors so that I didn't have to disassemble the wall somewhat to get back there (This is actually much better with the new screen now since the sides are now velcro fit vs friction. I will likely change this to magnets
4) Make at least the major parts of the light tray detachable or swing down for access
These are all minor things, but once you have used a room for years you think of what you could have done to make it better. If you have room to improve, why not? Make sure that if you do attempt your changes that you post a link here to let me know so people can follow up on your work!
damelon is offline
post #2724 of 3094 Old 05-18-2015, 03:53 PM
RedStripe88's Avatar
Quoted: 226 Post(s)
Liked: 190
Here are some of todays pictures. I have only adjusted the basics like sharpness, brightness, contrast but the Nikon program shows a different image than windows photo viewer so they end up a little darker. At least in these you begin to get some of that 3D effect
Great pictures of the star ceiling. I've tried a couple times with mediocre to no success. Could you share what settings you used on the Nikon and any other tips.. How many layers did you splice together?
My in progress build thread: The Salt Mine
RedStripe88 is offline
post #2725 of 3094 Old 05-18-2015, 04:11 PM - Thread Starter
damelon's Avatar
Liked: 345
Actually, I don't know how to use Photoshop, and I don't know how to do layers. Those are single photos. I adjusted the sharpness/brightness/contrast slightly with the Nikon software that came with my camera. I have a friend in my office who said if I re-took them as raw files he would touch them up for me if I wanted, but I haven't had a chance to re-take them.
I didn't do much at all with the camera. I got a Nikon D5300, which is a decent mid range camera. I used my wife's tripod, which is a very good quality tripod and easy to manipulate. The one that came with my camera package was junk. I turned off auto-focus and manually focused the camera to the best of my ability on the far soffit from where I had the camera. I had only the floor black light on in the center of the room angled up and the ceiling pre-charged. (Hence why you get the purple light hues on the ceiling and the soffit) left the soffit lights on, but not at a dimmed setting. (I had no luck really with all of the lights out) I set the camera to Aperture mode and left it at F8. I believe the default ISO is 100. I actually didn't figure out how to disable the flash in manual mode, so I believe I set it to slow flash. I think what happened is that it either pre or post flashed quickly (Which lights up some areas of the background) but then took about the full 30 seconds to gather the light for the photo. You have to understand, I am a complete novice when it comes to cameras. The fact that I even know ISO/Aperture is that I googled how to take night pictures the day that I took them. In fact that was the first day I ever even used this camera. It was an impulse buy after I couldn't get it right with my wife's D90. I think the moment that some started coming out ok was when I got excited and posted them here. I still haven't been able to get a full dark photo to work, which is what I tried with the D90. The slow flash may have actually been what made it work for me.
damelon is offline
post #2726 of 3094 Old 05-27-2015, 06:18 PM
marlon1925's Avatar
Quoted: 62 Post(s)
very nice...how did you make those stars in the ceiling?
NightSkyMurals likes this.
post #2727 of 3094 Old 05-27-2015, 09:11 PM
Liked: 5141
post #2728 of 3094 Old 05-28-2015, 08:18 PM
marlon1925's Avatar
Quoted: 62 Post(s)
post #2729 of 3094 Old 05-28-2015, 08:44 PM
Liked: 0
Nice star mural you got in your theater room.
aherre07 is offline
post #2730 of 3094 Old 05-29-2015, 05:55 AM - Thread Starter
damelon's Avatar
Liked: 345
Thanks! The mural was done by Jeff @ NightSkyMurals. He did an excellent job!
damelon is offline
Optoma Th1060p Projector , Oppo Bdp 93 Blu Ray Player , M80 V3 Floorstanding Speaker Boston Cherry , Sony Vpl Vw95es Full Hd 3d Home Cinema Projector , Seaton Sound Submersive H P
