Sunflower State Cinema - Page 26 - AVS Forum | Home Theater Discussions And Reviews
 49Likes
post #751 of 752 Old 03-16-2018, 12:48 PM
d_c
d_c's Avatar
Quoted: 1130 Post(s)
Liked: 1540
d_c is offline
post #752 of 752 Old 03-17-2018, 12:07 PM - Thread Starter
jedimastergrant's Avatar
Quoted: 839 Post(s)
Liked: 665
Originally Posted by d_c View Post
Great idea on the mounts. Did you up the gain on the Atmos speakers or let the AVR decide?
I have been using my speakers without an automated EQ for the last year. I can't tell a big difference switching between XT32 on and off anyway. That could change with this latest swap out for the height speakers. But, the front stage is the most important by far and that hasn't changed.
I do use an EQ on my subwoofers with the DBX DriveRack Pro PA2. Michael did that calibration before the KC HT crawl last year. He also did a few bands worth of mild manual EQ for a few speakers.
I wonder how much different/better my system could sound with Dirac or Trinnov? I need that tech to trickle down and I would love more bed channels as well (not wides). I want Dolby to activate another set of bed channels for home theater use so I can do 9.x.4.
So I just used my cheap meter and matched what my center channel was putting out. Then manually measured for distance. I should probably run XT32 (after taking a picture of my manual settings) and see where it puts them too. The Radio Shack meter isn't as accurate as my iTest mic so I guess I should use it instead. The last few movies I have felt like I almost needed to turn the height channels down a hair but it is very immersive so I will need to play with the levels.
jedimastergrant is offline
Jvc Dla Rs45 Home Theater Projector 1080p Hdmi , Klipsch Rf83 Black Each 2 Way Reference Floorstanding Speaker , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Black Each , Triad , Emotiva Xpa 5 5 Channel Power Amplifier , Sherbourn , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Harmony 900 Remote
