YACWPT (Yet Another Crazy Window Plug Thread) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-03-2013, 04:21 PM - Thread Starter
memmo's Avatar
Quoted: 77 Post(s)
Liked: 68
I have 2 basement windows in my theatre space that I plan on covering right over. In anticipation, I cut some Linacoustic and fit it into the frame so that it would black out the window. Looks great from the outside. I proceeded to put in some Roxul insulation in the studs (right over the window).
Today, I wanted to use the window one last time to pass some stuff through (won't be able to do it much longer as drywall is gonna go up shortly), but when I removed the Roxul and then the Linacoustic, I noticed some condensation on the window glass.
I'm in Central Ontario and it was about -2c this morning and over the winter will routinely see -20c temps.
Now, I don't have any vapour barrier on the wall yet (that was the next step) and that may be why I'm seeing the condensation, but I still got a bit worried when I saw the moisture build up.
Question:
Should I place the Linacoustic in the frame and then tape a piece of vapour barrier (6 mil poly) directly to the window frame, then put the Roxul back in and then cover the entire wall with more vapour barrier as I normally would?
OR
Should I just stick it all back in and proceed with vapour barrier over the entire wall as per normal?
OR
Should I do both? I obviously don't want moisture issues.
The Big Bay Home Theater Build Thread
My personal theater build on Kempenfelt Bay, Barrie Ontario Canada
memmo is offline
post #2 of 3 Old 11-04-2013, 10:59 AM - Thread Starter
memmo's Avatar
Quoted: 77 Post(s)
Liked: 68
I'm a little hesitant to apply the double vapour barrier but something tells me sealing the window casing etc up after the Linacoustic is placed inside would be my best bet.
Anyone?
memmo is offline
post #3 of 3 Old 11-11-2013, 01:05 PM - Thread Starter
memmo's Avatar
Quoted: 77 Post(s)
Liked: 68
I'm ready for vapour barrier -- anyone have any thoughts before I embark?
memmo is offline
