Who needs a garage... Theater build log! - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 37 Old 12-13-2013, 01:42 PM - Thread Starter
amo76's Avatar
Quoted: 18 Post(s)
Yes, it is 10 in. I might do 2x10 instead of 2x12.
amo76 is offline
post #32 of 37 Old 12-20-2013, 01:46 PM - Thread Starter
amo76's Avatar
Quoted: 18 Post(s)
Started removing the drywall to match the level of new sub-floor I'm going to build.
335229
Ran into my first issue today, I was going to keep the drywall on the ceiling but turns out that I already have 2 layers of DW (no GG in between). Is this a code thing or somebody had some spare drywall to use?
Doesn't look like I have to remove the first layer since they both count as a single leaf but I wouldn't get the full benefit of DD DW.
amo76 is offline
post #33 of 37 Old 12-22-2013, 08:22 PM - Thread Starter
amo76's Avatar
Quoted: 18 Post(s)
I'm not really sure what happened. I think "home theater demons" took over me and I had to remove all drywall from the walls. smile.gif I decided to do it right. Still need to remove DW from the ceiling.
336633
336634
I'm thinking about going with clips/channels and OSB/GG/DW on all walls/ceiling except one wall that already has a layer of OSB on it.
amo76 is offline
post #34 of 37 Old 12-23-2013, 03:56 AM
Tedd's Avatar
Quoted: 2293 Post(s)
Liked: 985
An upside of pulling the drywall is you could easily zone your lighting.
Tedd is offline
post #35 of 37 Old 01-02-2014, 08:08 PM - Thread Starter
amo76's Avatar
Quoted: 18 Post(s)
I didn't make as much progress as I hoped during the holidays. But here is an update:
- Drywall is all gone, while removing the drywall on the ceiling I noticed that I have a small roof leak, that will have to be fixed
- Decided not keep the garage door on rails, instead I went with this approach:
344094
344095
Feels pretty solid. I'll caulk the seams on both sides of the door and will add foam insulation on the inside to act a vapor barrier.
amo76 is offline
post #36 of 37 Old 01-14-2014, 01:45 PM - Thread Starter
amo76's Avatar
Quoted: 18 Post(s)
Haven't made much progress since the last update. I'm planning on sealing the concrete floor this week, install 6mm vapor barrier and start working on framing over the garage door and building the subfloor.
I have a sound-proofing question and I hope somebody more knowledgeable than I'm can chime in and confirm that I'm on the right track.
Here is what I'm planning to-do.
353057
I have some concerns about leaving 1/2 in. gap between the subfloor and the walls framing to allow the subfloor to expand and shrink. Should I do something about it or would it be sufficient to caulk the gap between DW and the subfloor with the acoustic caulk to prevent the sound leakage?
amo76 is offline
post #37 of 37 Old 03-02-2014, 03:03 PM
Mike_2008's Avatar
Any update? Have you finalized your plans to raise the floor?
Mike_2008 is offline
Panasonic Ptae8000u Hd Projector
