My retirement theater... - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 112Likes
post #301 of 308 Old 11-18-2016, 08:52 AM - Thread Starter
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 417
Originally Posted by Calderes View Post
Very nice. I'm trying to build acoustical treatments but I'm not retired yet so it's taking forever!!! =)
Can't wait till I can go 100% on a project like yours.
It is a fun journey when you are able to build one!
ellisr63 is offline
post #302 of 308 Old 11-28-2016, 09:40 AM - Thread Starter
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 417
I have a progress update... One speaker is nearing completion, and all I can say is they are BIG!
Here are some images of the new speakers being built.
Basic box:
Sides of horn being mocked up to figure out the angles and location of the sides:
Ports made, and measurements stored:
Front and rear view with woofers installed (we still need to trim the front of the horn flush with the cabinet, make the additional horn flare, and make the top and bottom angled triangles for the horn (top and bottom):
The cabinets are 40" wide, 27 1/2" high, and 26" deep. After the front horn flare is designed and installed...we are thinking it will be 6-8" wider and taller. This bad boy is heavy!
Waterboy77 likes this.
ellisr63 is offline
post #303 of 308 Old 01-14-2017, 04:55 PM - Thread Starter
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 417
Today we got it to the point that we only need the following:
1: fill holes with wood putty
2: mount speaker wire jacks, and wire speakers up
3: sand speaker cabinet
4: install weatherstripping for sealing cabinet
Hopefully next time we will be to fire it up to see how the compression driver sounds, and then also how the woofers sound. At that time it might be ready to take home, and set up the crossover...for some real serious listening.
ID:	1895665   Click image for larger version
ID:	1895673   Click image for larger version
ellisr63 is offline
post #304 of 308 Old 01-14-2017, 06:24 PM
Gouie's Avatar
Quoted: 394 Post(s)
Liked: 244
Holy crap. Well done.
Gouie is offline
post #305 of 308 Old 01-31-2017, 12:07 PM
jlpowell84's Avatar
Quoted: 2027 Post(s)
Liked: 995
Agreed! What compression drivers? I just installed upgraded JBL 2453H-SL's on my JBL 4722 speakers and they are great!
Great craftsmanship!
jlpowell84 is offline
post #306 of 308 Old 01-31-2017, 01:18 PM - Thread Starter
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 417
We are using EV DH1A compression drivers.
ellisr63 is offline
post #307 of 308 Old 02-03-2017, 01:21 PM - Thread Starter
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 417
I am selling the following:
1: 3 JBL 2360A horns (without the drivers) for $150 each.
2: 3 DIY Q-Pie bass bins with EVM 15" woofers for $150 each
3: Panasonic AE8000e for $900
4: 2 Crest Audio CM2208s (8 channel) pro amps for $450 each
5: 1 Yamaha XM-4080 (4 channel) pro amp $400
6: Panamorph UH-480 (B stock) for $950
I might have a few more pieces soon too. The amps are being sold as I am making a new 14 channel amp to conserve space.
ellisr63 is offline
post #308 of 308 Old 02-03-2017, 08:51 PM
jlpowell84's Avatar
Liked: 995
Dang the PJ is tempting as I want that exact model. Decent until I go full build and 4K. But just can't spend more money right now unless my Amps sell...
ellisr63 likes this.
Denon Avr 4520ci Receiver , Jbl , Klipsch , panasonic ae8000 , seymourav
