Creekside Stone Cinema - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 72Likes
post #151 of 359 Old 11-26-2014, 10:15 PM
cocytus's Avatar
Quoted: 34 Post(s)
Are you planning on running just two subs? Did you wire for atmos at all?
cocytus is offline
post #152 of 359 Old 11-26-2014, 10:18 PM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
Wall treatments
Burning some midnight oil trying to take advantage of the long weekend and wrap this thing up!. Not quite sure if I hung the Ultra Touch correctly but it is staying on the wall so far. My concern is that it will protrude the fabric on the panel frame but I can always put more screws in to tie down the high spots. The plan is to build the frame .25" or so deeper than the treatment so we will see. I used a 3' wood screw with the I plastic washers off of the roofing nails I had.
Left wall
Right Wall
Rear panel treatments, opposite wall is the same
And from the front (excuse the mess, please)
Looking like I will need to secure the Ultra Touch a little more on the bottom, it really hangs out there.
ID:	388017   Click image for larger version
ID:	388033   Click image for larger version
24Changer is online now
post #153 of 359 Old 11-26-2014, 10:22 PM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
For now, yes. I was wondering since I have a lack of space in the rear if I could use a couple in wall subs and hide them in the rear columns. I guess that would be a question for the calibrator.
I did not wire for atmos but I think I could if I decide to go that route. I can access the ceiling from the hall and fish my wires down between the channeling holding up the ceiling. Probable easier said than done but doable.
post #154 of 359 Old 11-26-2014, 10:35 PM
cocytus's Avatar
Quoted: 34 Post(s)
That ultratouch stuff is nice but it is extremely dusty. I didn't know if you planned on putting a sub in each rear corner. From the pics it almost looks like you have room. I put one on my platform an I like the tactile feel plus it helped smooth out my room response. Hopefully you won't have any problems with you projector vibrating like I did. It ended up taking me quite a while to eliminate it.
cocytus is offline
post #155 of 359 Old 11-26-2014, 11:25 PM
iamjason's Avatar
Quoted: 32 Post(s)
Originally Posted by 24Changer View Post
I used 1/2" backer board. I needed to move the stone out a little so it did not appear to far under the ledge, which is 3.5" but still gives us a little overhang on the stone. The ledge will be flush with the 3.5" panels on the wall between each column.
thanks - i figured the stone would just adhere to the wall - i am liking the idea here!
iamjason is offline
post #156 of 359 Old 11-27-2014, 06:28 AM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
You've got that right
You know, I did not even think about that. That could be an issue. the projector pole is 24", a large distance for something like that to happen. I'm keeping my fingers crossed. Of all the reading I have done on this site, I can't say I remember read anything about that type of problem.(if you did, obviously I haven't read your thread) I am surprised that you don't hear more about that problem.
post #157 of 359 Old 11-27-2014, 08:20 AM
dlbeck's Avatar
Quoted: 662 Post(s)
Liked: 776
Thanks David. I don't know if you saw my earlier post, however, Jeff M Is scheduled for the 17th of Dec. #excited !
I did...you can't go wrong with Nyal or Jeff. I love my theater more and more every time I watch something. On the Ultratouch, just need to fasten the bottom of it as well and you'll be set. I was fortunate enough that I could just tuck it into the wainscot.
dlbeck is offline
post #158 of 359 Old 11-27-2014, 09:07 AM
rms8's Avatar
Quoted: 512 Post(s)
Liked: 358
I never would have thought of that color for a home theater, but with the stone up it looks outstanding!
Really looking awesome.
rms8 is offline
post #159 of 359 Old 11-27-2014, 09:24 AM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
post #160 of 359 Old 11-27-2014, 09:27 AM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
Thanks man. I think the brown is dark enough that I am hope that there will be no reflection of the front of the soffit. The good thing, it is only a paint roller away from fixing that if it does.
post #161 of 359 Old 11-28-2014, 11:47 AM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
Carpet
The carpet installers are here, that means more progress and that's a good thing.
The red padding is from the previous room. It was in the front of the room and had little to no foot traffic so we saved it when we tore the carpet up. I
post #162 of 359 Old 11-28-2014, 10:09 PM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
Carpet is in. I think it turned out great. It really complements the stone. 1 installer, 6 hrs and he worked his tale off.
So we moved on to installing the subs and speakers, I almost feel bad putting the 1099's behind the screen and covering them up.
and then the screen ~ Falcon Screen ~
ID:	391065   Click image for larger version
ID:	395146   Click image for larger version
post #163 of 359 Old 11-28-2014, 10:33 PM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
While the carpet was going in I fabed a header piece for the door. I used 3/4" MDF for the face & some poplar board for the top & bottom cap with a little cove. Hard to see the cove in this shot because of the shadow.
post #164 of 359 Old 11-28-2014, 10:34 PM
mtg90's Avatar
Quoted: 777 Post(s)
Liked: 1605
Just stumbled across your thread, very nice!
mtg90 is offline
post #165 of 359 Old 11-28-2014, 10:39 PM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
Thanks for stumbling across.
Thank you
post #166 of 359 Old 12-01-2014, 08:51 AM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
Hung the projector with the UH480 lens mount/slide on Saturday morning with the assistance of @TMcG, we needed to take a quick trip to Lowes to pick up 6- 10/24 x 3/4 bolts to mount the projector to the mounting plate. The bolts were not in packaging.
Also installed all the foot lighting over the weekend
and started to arrange the equipment in the rack while starting to bring the basement back from the war zone. Things are shaping up.
post #167 of 359 Old 12-01-2014, 09:06 AM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
What's left
- hang the ceiling treatments
- build the fabric boxes for all the treatments & cover
- finish the screen panels & cover
- touch up wall & ceiling paint
- stuff columns with fluffy
- build the trim/grills for the columns
- finish wiring the AV rack/ set up remote
- bring in the chairs
- calibrate on the 17th with Jeff Meier
- officially watch the 1st movie
~ any suggestions?
post #168 of 359 Old 12-01-2014, 10:03 AM
jimim's Avatar
Quoted: 543 Post(s)
Liked: 154
Hung a few of the acoustical panels tonight in the middle. Really starting to take shape and starting to see the end. Spoke with Jeff Meier and set a date for the 17th of Dec for calibration
So r those getting wrapped then? They look pretty cool in the pics but I'm on my phone so I can't really see em well. How think r they. They look really thick. Again on my phone. Lol
I'm going to to end up doing like you and leaving painted wall around the panels and columns. I've been liking this look more over the past year.
Who did ur acoustic plan again?
Jimi
jimim is offline
post #169 of 359 Old 12-01-2014, 10:11 AM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
Jimi
They are shy of 3.5" thick. I am going to wrap them acoustical fabric. Nyal Mellor with Acoustic Frontiers designed the treatments
post #170 of 359 Old 12-01-2014, 12:58 PM
cocytus's Avatar
Quoted: 34 Post(s)
Is Jeff Meier doing both your audio an video?
cocytus is offline
post #171 of 359 Old 12-01-2014, 02:56 PM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
yes
post #172 of 359 Old 12-01-2014, 03:35 PM
cocytus's Avatar
Quoted: 34 Post(s)
From the reviews that I have saw he does great work. I was actually thinking about having him do my projector an surround system in March. So I am curious to hear what you think when he does yours.
cocytus is offline
post #173 of 359 Old 12-01-2014, 03:40 PM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
I am following the lead of dlbeck and the reviews people have posted on his Savoy thread. I will definitely post what Jeff has to say and mine after comments.
post #174 of 359 Old 12-01-2014, 06:09 PM
rms8's Avatar
Quoted: 512 Post(s)
Liked: 358
I had a really hard time trying to choose a carpet to "go with" the stone, ESPECIALLY when the stone is right on the carpet (no baseboard).
Your carpet selection goes PERFECTLY with the stone you have! They look awesome together! Great choice.
rms8 is offline
post #175 of 359 Old 12-01-2014, 07:14 PM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
Thank you.That was the one thing I was concerned about as well. I am truly amazed how well the transition from stone to carpet is. I really could not ask for it to be any better.
post #176 of 359 Old 12-01-2014, 07:38 PM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
Screen Panels
we were able to cover 3 of the 4 screen panels tonight. It started out a little slow but we recovered nicely.
The velvet is from Sy fabric, there is a slight difference in finishes between the screen frame velvet and the panel velvet but it doesn't seem to be as noticeable in person as it is in the picture.
ID:	396530   Click image for larger version
ID:	396538   Click image for larger version
cocytus and Cksqurd like this.
post #177 of 359 Old 12-03-2014, 12:12 PM
Diesel 48's Avatar
Quoted: 73 Post(s)
Liked: 33
What LED's did you use? Where did you get them? About how far are they from the ceiling? Your room is looking amazing.
Diesel 48 is offline
post #178 of 359 Old 12-03-2014, 12:35 PM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
Thanks Diesel
I ordered them from Destination Lighting.
http://www.destinationlighting.com/item/dimmable-14-watt-led-6-inch-recessed-lighting-kit-case-pack-6/437586
Hope the link is still good, I did not try it. Copied & paste from 1st page
post #179 of 359 Old 12-03-2014, 12:39 PM
Diesel 48's Avatar
Quoted: 73 Post(s)
Liked: 33
Sorry! I meant the LED rope lighting, the LED's above your screen look good to. While thinking about it, with your acoustic treatments you have space on the walls were there are no treatments. What do you put there when covering the treatments? Do you leave it empty or does something go there to fill space? I am going to have the same thing in my theater but was not sure best practice when it comes to areas behind fabric that do not have any treatment.
post #180 of 359 Old 12-03-2014, 12:51 PM - Thread Starter
24Changer's Avatar
Quoted: 129 Post(s)
Liked: 140
I purchased them through here
www.ledropelightsandmore.com
I purchased 150' and it went around the room 3 times
I am going to build an open box and cover it with fabric and the trim it out with some small crown. So I will have a little open space around the treatments, roughly 4"
Last edited by 24Changer; 12-03-2014 at 12:55 PM. Reason: add comment to LED rope light
