Planning stages of "Dreamgranter" dedicated home theater - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1 of 37 Old 10-01-2014, 01:19 PM - Thread Starter
drriddhish's Avatar
Quoted: 81 Post(s)
Liked: 53
Planning stages of "Dreamgranter" dedicated home theater, need advise
Hi
I want to start thanking everyone in the forum for posting pictures, discussion, expert opinions and advise they provide to many threads just as the one I am about to start.
I have partially finished basement with the great room of about 27 x 30. I have two unfinished areas one of which I want to convert to dedicated home theater.
My wishes for the home theater are following
1. sound isolation
2 good sound and large screen, attempt to implement dolby atmos
3 i enjoy 3d
4 30% sports, 70% movies/documentaries
Gears I have- is used in entertainment room that exists but I am not looking to bring them to dedicated theater except chairs.
I am budget conscious, therefore my priorities are
1. build good sound isolated room, 2. invest in speakers 3. invest in PJ/screen
My desired gadgets are
1. seymour 140 inch wide AT screen
2. 3d capable epson or other projector
3 klipsch thx ultra 2 speakers and pair it with atmos speakers 7.1.4 setup
4 Yamaha or marantz atmos capable avr for processing
5 emotiva amp
I plan sound isolation per Ted White company advise.
I am not much hands on, but I do want to learn and do some of it myself. I am enrolling into basic woodworking tool classes etc.. (waiting my employer to pickup my tuition . I came up with two plans each with distinct advantages and disadvantages. I dont care much about star ceiling, soffit, stage, and I want to avoid riser building- thus keeping the cost down. I am quickly learning sketchup so should be able to create 3d plans.
I have put two plans together on graph paper. I want to know which plan would be a good idea..
ID:	289865   Click image for larger version
drriddhish is offline
post #2 of 37 Old 10-01-2014, 03:23 PM
Tedd's Avatar
Quoted: 1989 Post(s)
Liked: 808
You could add some simple columns and encase the support post in one, to let you widen either room 5-6".
You could flip the av rack and embed it between the two support posts, in the entry area.
Could a doorway be cut into the existing wall?
A baffle wall would allow for a shallower "AT" space, that might allow for two rows of three seats, in the same area as your single row version.
How tall is the room?
Tedd is offline
post #3 of 37 Old 10-01-2014, 03:45 PM
Quoted: 5507 Post(s)
Liked: 5097
I usually use the back of the chairs as a proxy for viewing distance you seem to be using the fronts, +1 on gaining more width with the decorative columns per Tedd
post #4 of 37 Old 10-01-2014, 04:33 PM
Tedd's Avatar
Liked: 808
I'll throw this version out there. Not where you are thinking of heading, but a baffle wall
could make the most of the smaller space.
Tedd is offline
post #5 of 37 Old 10-01-2014, 08:30 PM - Thread Starter
drriddhish's Avatar
Quoted: 81 Post(s)
Liked: 53
I really like your suggestion. I also see that you flipped the room around. I am in no real need of storage. so I am ok to reduce it sacrifice it.
I am not sure which one is better in terms of room in room design and sound isolation, baffle wall vs other methods
The height I have in finished area from carpet to ceiling is 8 ft 7 inches, unfinished measures 9 ft.
Yes I believe, door can be accommodated in the area you designated.
I have uploaded you tube video of the area, so you can look at it
post #6 of 37 Old 10-01-2014, 08:47 PM - Thread Starter
drriddhish's Avatar
Quoted: 81 Post(s)
Liked: 53
Got it. If I can get four chairs in row, I dont need another row in true sense. I do like idea of six chairs though.
I have posted video for everyone to look. As you can see in video one end of the room has water and sewage main lines and installation for sewage pump site. I am not sure how and what impact it can have in room design- should I put screen on the other end as Tedd suggested?
I appreciate your help. Have you worked with anyone from contractor side who implemented room in room design in Raleigh area? would you recommend some one? Please PM me.
post #7 of 37 Old 10-01-2014, 09:16 PM
Liked: 5097
those vents both look like supplies, just follow them back to the air handler. If they connect off the top of the furnace they are supplies, connected to the sides or bottom are the returns. It is not unusual in an unfinished basement to not install a return. Then when it is finished to pop one in. For theaters you want dedicated supplies and returns in addition to what you have installed for the rest of the basement.
All those drain pipes are an issue it would help if you can indicate on your floor plans where you think they will be located
post #8 of 37 Old 10-01-2014, 09:22 PM
Tedd's Avatar
Liked: 808
The HVAC runs could be handled outside the room, in the upper area between those pair of support posts, down the side of the theater.
The room flip was thrown in there as maybe something you didn't try, as is the KQ front row in this layout. (And this layout lets you put the riser step outside the room.)
Tedd is offline
post #9 of 37 Old 10-02-2014, 05:26 AM
Tedd's Avatar
Liked: 808
I know you want isolated but have you also considered what BigmouthinDC did here:
https://www.avsforum.com/forum/19-ded...ect-recap.html
If that support post were to be allowed in the room, then you could go even wider. The beam that would be in the room could be
hidden by a soffit. Might be an option for either the single row of four or a two row of 3 design.
Name:	row of 4.jpg
Tedd is offline
post #10 of 37 Old 10-02-2014, 05:50 AM
Tedd's Avatar
Liked: 808
bar row occasional seating row version
Name:	row of 4 plus bar row.jpg
Tedd is offline
post #11 of 37 Old 10-02-2014, 08:40 AM - Thread Starter
drriddhish's Avatar
Quoted: 81 Post(s)
Liked: 53
Here is modified version of what Ted suggested to indicate placement of the pipes.
Thanks Ted..you are visionary..
I think storage in the back would be converted to av media storage
I will try to transfer this to graph paper to see what angle speaker will be and what size of screen we can reasonably achieve.
Thanks again..
Name:	row of 4 plus bar row with water and sewage mains.jpg
post #12 of 37 Old 10-02-2014, 11:34 PM
SierraMikeBravo's Avatar
Quoted: 365 Post(s)
Liked: 249
If you want atmos, that bar may become problematic. Also, the soffit in back needs to be larger. One last issue, your desired speaker package I know for a fact are not timbre matched. Timbre matching is absolutely imperative for atmos.
Shawn Byrne
CEDIA Certified Professional EST II - HAA, THX.
Theater Design Information and Examples
[email protected]
[email protected]
SierraMikeBravo is offline
post #13 of 37 Old 10-03-2014, 06:19 AM - Thread Starter
drriddhish's Avatar
Quoted: 81 Post(s)
Liked: 53
I guess you are saying bar seating would be problem from perspective of speakers need to be placed 4 ft from ground, and bar/people obstructing the speakers. Am I correct in assuming that? I also get your point on timber matching for atoms set up, I will wait to decide on speakers until more choices become available. Procella is out of budget for me in the beginning stages. I can wait for klipsch to come out something with timber matching or go with something else all together.
I did not understood about soffit in the back needs to be larger..would you please elaborate.. thanks
post #14 of 37 Old 10-03-2014, 06:51 AM
Quoted: 365 Post(s)
Liked: 249
Procella doesn't currently have Atmos approved speakers yet either. The only company that currently has Atmos approved speakers is Triad. It is unlikely that Klipsh will ever have anything timbre matched. Timbre matching requires a level of QC and parts matching that Klipsch has, so far, been unwilling to deliver. Unless they significantly increase costs to consumers, it will be unlikely to happen. Not sure why you would say Procella is out of your budget range, but I don't know what your budget is. The new P5's are very close in performance to the P6 and at half the price. The back needs to be larger in order to accommodate a projector, HVAC ducting and diffusors. Hope this helps!
Shawn Byrne
[email protected]
[email protected]
post #15 of 37 Old 10-03-2014, 07:01 AM - Thread Starter
drriddhish's Avatar
Quoted: 81 Post(s)
Liked: 53
@SierraMikeBravo
Agree that atmos approved speakers are not there yet..but if the object based sound is to hold place in home theater, I am sure others will come up with their lines at higher cost like you said.
However at Cedia they used P6 in dolby atmos demo
I dont see p5 listed on the procella site..who would I get in touch to get pricing?
Name:	atmos cedia placement of procella.png
post #16 of 37 Old 10-03-2014, 07:47 AM
Tedd's Avatar
Liked: 808
Atmos was something I was about to question. I have to wonder if money reallocated elsewhere,
might yield better overall results. The words "budget conscientious" coupled with the room
depth, had me wondering if a professionally designed baffle wall with the Procella P5 up front, and
sticking to 7.1 is the superior audio route.
Tedd is offline
post #17 of 37 Old 10-03-2014, 08:17 AM
Quoted: 365 Post(s)
Liked: 249
post #18 of 37 Old 10-03-2014, 12:03 PM - Thread Starter
drriddhish's Avatar
Quoted: 81 Post(s)
Liked: 53
@SierraMikeBravo sent you an email. Thx
post #19 of 37 Old 10-03-2014, 12:13 PM
smuggymba's Avatar
Quoted: 113 Post(s)
Are the P8's atmos enabled?
https://www.facebook.com/media/set/?...8779692&type=1
smuggymba is offline
post #20 of 37 Old 10-03-2014, 12:42 PM
Liked: 5097
Atmos enabled are mains and surrounds that bounce sound off the ceiling and contain some circuitry that modifies the frequency response to trick your ears. It is a process licensed by Dolby.
then there are ceiling speakers. the P8s pictured were ceiling mounted and as far as I know do not need and do not contain the circuity.
post #21 of 37 Old 10-03-2014, 01:46 PM
Quoted: 365 Post(s)
Liked: 249
The answer is no. However, procella has developed a waveguide that is circular like the P5.
Shawn Byrne
[email protected]
[email protected]
post #22 of 37 Old 10-03-2014, 03:29 PM
Moggie's Avatar
Quoted: 28 Post(s)
Liked: 38
Roger Dressler indicates that most automatic EQ systems will cope with timbre matching for Atmos. See this post. Do you have a different experience?
Elill likes this.
My "Old Vic" Theater Build | Screen Build | HT of the Month | Contest Win
My 8 year old daughter: "are contractors the people that mess up your house for money?"
Moggie is offline
post #23 of 37 Old 10-03-2014, 03:42 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 982
+1
I'd trust Roger's feedback.........period!
Elill likes this.
doublewing11 is offline
post #24 of 37 Old 10-03-2014, 05:16 PM
Quoted: 365 Post(s)
Liked: 249
I am going to disagree partly in that it is a general assumption. I wouldn't put a lot of faith in automatic room correction systems that have proven nearly 100% of the time to have failed in correcting a room correctly in my experience. Further, if a speaker is incapable of being matched, you have a problem. Too many assumptions and faith placed in auto majik systems. Even the more robust correction systems which require a PC to implement have failed in 7.1 systems to say nothing about Atmos. Even if you manually try to correct, if they are so far off, which I have seen in Klipsch, you run the risk of the speaker being incapable of matching the others. Further, proximity to boundaries and pisitioning will change timbre. If a speaker company adjusts for this already, that's great!! So, the moral should always be to test your speakers first before implementing for matching before running any type of EQ.
Tedd likes this.
Shawn Byrne
[email protected]
[email protected]
post #25 of 37 Old 10-05-2014, 10:15 AM
Tedd's Avatar
Liked: 808
Could "less" be "more"?
Name:	minimalist four seater with entry area.JPG
Tedd is offline
post #26 of 37 Old 10-05-2014, 10:41 AM
Liked: 5097
screen size and viewing distance in that option? The concept of a single row of four is my ideal private screening room and would fit my lifestyle.
post #27 of 37 Old 10-05-2014, 12:28 PM - Thread Starter
drriddhish's Avatar
Quoted: 81 Post(s)
Liked: 53
ok after everyone's help and discussion I am throwing out more of area for consideration in the basement.
Would this be a better fit?
post #28 of 37 Old 10-05-2014, 12:30 PM - Thread Starter
drriddhish's Avatar
Quoted: 81 Post(s)
Liked: 53
attempting it again to load properly
Name:	basement plan and reconsideration.jpg
post #29 of 37 Old 10-06-2014, 08:08 AM
Tedd's Avatar
Liked: 808
another stab at the original location
...just a low wall for the front row, that might shrink the post's visual footprint in the room?
A low one step riser, with a small island riser for the rear seating would preserve headroom.
Name:	five seater.jpg
ID:	297434   Click image for larger version
Name:	post in containement.JPG
Tedd is offline
post #30 of 37 Old 10-06-2014, 11:00 AM
Robert Jones II's Avatar
Quoted: 113 Post(s)
Liked: 64
Tedd, where is that picture with the ramp next to the riser from?
Robert Jones II is offline
