Man Cave with a HT, Bar and a Poker room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 02-02-2015, 11:13 AM - Thread Starter
draja's Avatar
I live in Westborough, Massachusetts. With the help of few contractor, started building a 11.2 home theater, a wet bar and a poker room. Fitness room will be in phase 2. I am uploading the before photographs and the plan. The theater is almost done and bar is work in progress.
ID:	519425   Click image for larger version
ID:	519433   Click image for larger version
ID:	519441   Click image for larger version
ID:	519449   Click image for larger version
draja is offline
post #2 of 20 Old 02-02-2015, 11:21 AM
Quoted: 5548 Post(s)
Liked: 5140
Welcome, If it is almost done we won't be able to help you.
post #3 of 20 Old 02-02-2015, 11:24 AM - Thread Starter
draja's Avatar
I need help in seating design arrangements. I may also need suggestions on sound proofing if possible now. I think it is too late. Suggestions welcome. The first floor shakes a lot even if I listen to music! I will post the photographs shortly.
draja is offline
post #4 of 20 Old 02-02-2015, 11:26 AM
Liked: 5140
If the drywall is up, it is too late to soundproof. There are a few things you could do to take the edge off but you missed out on some easy wins early on.
post #5 of 20 Old 02-02-2015, 11:27 AM
JCJetta's Avatar
Quoted: 339 Post(s)
Liked: 672
Looking forward to watching your progress! My man cave will feature my power rack and various meathead equipment as such. I'm interested in seeing how you balance out your Man Cave.
JCJetta is offline
post #6 of 20 Old 02-02-2015, 11:33 AM - Thread Starter
draja's Avatar
The approved plan
draja is offline
post #7 of 20 Old 02-02-2015, 12:23 PM - Thread Starter
draja's Avatar
framing phase.
draja is offline
post #8 of 20 Old 02-02-2015, 12:39 PM - Thread Starter
draja's Avatar
L Shaped bar and theater framing
ID:	519697   Click image for larger version
ID:	519705   Click image for larger version
ID:	519713   Click image for larger version
draja is offline
post #9 of 20 Old 02-02-2015, 12:41 PM - Thread Starter
draja's Avatar
Stage
ID:	519777   Click image for larger version
draja is offline
post #10 of 20 Old 02-02-2015, 12:43 PM - Thread Starter
draja's Avatar
Riser
ID:	519833   Click image for larger version
ID:	519841   Click image for larger version
draja is offline
post #11 of 20 Old 02-02-2015, 02:15 PM - Thread Starter
draja's Avatar
Front speaker placement and insulation.
I also used Dri-Core for the sub floor
ID:	520137   Click image for larger version
ID:	520153   Click image for larger version
draja is offline
post #12 of 20 Old 02-02-2015, 02:35 PM - Thread Starter
draja's Avatar
Poker room ceiling
ID:	520225   Click image for larger version
ID:	520233   Click image for larger version
ID:	520241   Click image for larger version
ID:	520249   Click image for larger version
ID:	520265   Click image for larger version
ID:	520273   Click image for larger version
draja is offline
post #13 of 20 Old 02-02-2015, 02:37 PM
Liked: 5140
you asked for help on seating
counting studs it looks like the front of the riser which dictates the back of the first row seating is about 17 1/2 ft from the screen wall. It needs to be about 12-13
post #14 of 20 Old 02-02-2015, 03:23 PM - Thread Starter
draja's Avatar
You are right on the money. I have loaded few more photos to show the back of the wall. Can I install stadium style seat on the back and a theater seating in the front? Will it look weird? Or there are any slim HT seating so that I can fit two rows? Mostly kids may sit in the last row and may not require big fat recliner.
ID:	520369   Click image for larger version
ID:	520393   Click image for larger version
draja is offline
post #15 of 20 Old 02-02-2015, 03:27 PM - Thread Starter
draja's Avatar
These photos may explain better.
ID:	520417   Click image for larger version
ID:	520425   Click image for larger version
ID:	520433   Click image for larger version
draja is offline
post #16 of 20 Old 02-02-2015, 04:09 PM
Liked: 5140
there have been several theaters where the back row were traditional bolt down theater style seats which take less space and the front row are full size recliners. If you order both in all black it will help them blend together.
post #17 of 20 Old 02-02-2015, 04:59 PM - Thread Starter
draja's Avatar
Any specific model or brand that you would recommend? I am not looking for expensive seating.
I have the dimension of the riser. I am planning to install three rows. Two on riser and one below.
The riser is not a perfect rectangle. One corner is sliced (Entrance).
156" is the bottom
95" top (behind the bar)
I will draw a picture and upload it tomorrow.
draja is offline
post #18 of 20 Old 02-02-2015, 05:05 PM - Thread Starter
draja's Avatar
I am planning to install the infinity bar top with tempered glass top. Any suggestions?
draja is offline
post #19 of 20 Old 02-02-2015, 05:10 PM
Liked: 5140
I have no hands on experience with bolt down seating but Snickers1 of Falcon screens has some in his theater.
I've worked with this vendor and Alan answers questions over on the Theater accessories forum.
http://www.htmarket.com/home-theater...r-seating.html
post #20 of 20 Old 02-02-2015, 07:14 PM - Thread Starter
draja's Avatar
Can you please suggest a low power LED rope light? I tried 5050 RGB light placed in a crown molding on the top of my ceiling. The blue light gets reflection on the ceiling also even when it is dimmed all the way down.
draja is offline
