Roll-In Reels Cinema - AVS Forum | Home Theater Discussions And Reviews
 23Likes
post #1 of 156 Old 03-07-2015, 03:40 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
BACKGROUND Like many here I joined AVS 5 years ago in search of a question regarding my new plasma tv. I started hanging around, reading and exploring different sections of the forum. Most time was spent in awe of the guys who posted pics and threads of their dedicated theater rooms. I started saving for my own project and finally can now post my own thread about my space. The physical work started in November 2014. I'll give my apology now, all pictures are from my iphone, I don't own a camera.
My living situation is not normal for most and because of it, this isn't a DIY job by myself due to me being in a wheelchair (queue the play on words for my theater's name). I owe my father many many thanks for helping and learning through the process of DIY'ing a theater. He tackled majority of the work, and the bigger things we didn't want to tackle, we hired out. Nyal from Acoustics Frontier is in charge of all the planning for my theaters equipment, sound isolation, and acoustics.
AUDIO EQUIPMENT
L/C/R Speakers - Procella P8s
Surround Speakers - Procella P6Vs
Atmos Ceiling Speakers - 4x Procella P6IWs (will be mounted on ceiling though)
Subs - 2x SVS PB12+
AVR - Yamaha Aventage Rx - A3040
Amps - Parasound a23 (x2) (upgraded 7.29.2016)
VIDEO EQUIPMENT
Projector - JVC RS-500 (upgraded 4.3.2016)
Screen - Seymour AV 2.35 110" wide
Blu Ray - Oppo 103D
ROOM LAYOUT
The room measured 23' x 13' ~ 10' ceiling. The room has a some obstacles to overcome, like all rooms. This one has a window, glass french doors to the courtyard, and 3 interior doors (a single and french door). Here are pics after we bought the house. The previous owner had his own version of theater. It worked for him and his wants/needs. My vision is different.
this was after we moved in, hence storage use.
ID:	684817   Click image for larger version
realife3 likes this.
My theater build : Roll-In Reels Cinema (7.2.4 atmos theater)
lpnaz480 is offline
post #2 of 156 Old 03-07-2015, 03:41 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
We started by demoing the existing room you see in the previous post. Took everything out. Then had to frame a new wall in front of the french doors and window. We also framed a new wall in the back as I wanted to keep the french doors that face the main entrance hallway
side entrance to the theater, from the hallway. adding an interior door to create communicating doors. there's another entrance from the rear.
so many wires, he had every room ran w/ cat5.
framed wall is going infront of the french doors that lead to the courtyard.
ID:	590226   Click image for larger version
ID:	590234   Click image for larger version
Name:	photo 5 (2).jpg
lpnaz480 is offline
post #3 of 156 Old 03-07-2015, 03:41 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
For sound isolation we filled the walls with 3-4# rockwool and the ceiling was r19. Then the 2 original walls we used clips + 2 layers of 5/8" drywall. The ceiling is clips w/ 3/4" osb & 5/8" drywall. The two new walls were built decoupled so we went w/ 2 layers of 5/8" drywall. Green glue was used in between layers and then used acoustic sealant in gaps. Also used acoustic sealant for the new door frames that were built since the doors are communicating doors.
Don't really have any pics of the sound isolation. Pretty much typical clips and rail
here's 3/4" OSB layer on the clips channels.
hat channel, clips are the isomax, and used rockwool insulation
ID:	590290   Click image for larger version
lpnaz480 is offline
post #4 of 156 Old 03-07-2015, 03:42 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
Hired a friend of a friend who does drywall. He and his brother were a two man crew and I lucked out with these guys. They listened to my instructions on the green glue, took their time, measuring twice, and were pumped to learn. If I didn't have an answer, I'd search here or ask Nyal. I got reallyn lucky w/ these guys. They also framed my soffit for me. The dimensions for the soffits are 18"x18". The soffits are double layered w/ 5/8" drywall, and green glue. All gaps again filled with acoustic sealant.
here is one layer of the heavy 5/8" drywall. i got lucky w/ them as they paid attention to the details i asked for and they did their own reading on green glues website/soundproof company site.
used metal to frame out the soffits
before mud
after
ID:	591346   Click image for larger version
ID:	591354   Click image for larger version
ID:	591370   Click image for larger version
ID:	591378   Click image for larger version
lpnaz480 is offline
post #5 of 156 Old 03-08-2015, 10:05 AM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
Riser
The plan calls for a high riser. It's 18". Also because I am having that rear door swing into the room, it has to clear 36" from the wall, so the back row won't be able to go full recline. It won't bother me as my main seating position is the front row. Steps are wide as well in the front since front row will be 2 chairs and space for my wheelchair.
Laid roofing felt down first, then constructed the riser. The pictures don't show it because we built this first as a mock up to see if it would work.
ran wire for step lights and power outlets
2 layers of 3/4" that comes to exact height of 18", green glue in between and filled w/ insulation.
ID:	591394   Click image for larger version
ID:	591402   Click image for larger version
ID:	591410   Click image for larger version
lpnaz480 is offline
post #6 of 156 Old 03-08-2015, 10:17 AM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
you can see the rear single door in the background above. facing that door from the gym, would see french doors. wanted to keep that look. so here's how we solved the french doors. on the two new doors, (have communicating doors for side entrance too) i used q-lon weatherstrips, thresholds and jamb seals. i'm contemplating automatic door bottoms and some more q-lon strips for the other doors, as well as an astragal seal too.
lpnaz480 is offline
post #7 of 156 Old 03-08-2015, 10:55 AM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
i'm not doing a stage or any front curve soffit. instead i built a baffle wall per Nyals specs. The baffle wall has an outer frame that will hold the screen and the track lighting i bought to light up the speakers and auralex. The physical build portion is done, need to add the platfoam and pyramids still. The tracklighting I went with for the Imax effect is:
in black though
http://www.ylighting.com/model801.html
heres first frame, the baffle wall.
after putting a layer of drywall, gg, mdf, this is the final layer of drywall again
added thick r38 in the space between wall and baffle wall, just going over final scraps of covering mdf and trimming up the speaker cutouts
the baffle wall is complete, this framing the screen wall. it also holds the track light for the speakers.
ID:	591458   Click image for larger version
ID:	591466   Click image for larger version
ID:	591514   Click image for larger version
lpnaz480 is offline
post #8 of 156 Old 03-08-2015, 12:56 PM
jimim's Avatar
Quoted: 577 Post(s)
Liked: 158
in black though
very cool. nyal is doing my plans also. i also had him do the baffle wall layout for me along with the imax look. i didn't spec my light yet though. I'm actually using wac lights to light the front of my screen with down light. i like what u picked for the speaker lights. what is ur layout plan for them? on the floor shining up, but where are u hiding them cause you mentioned the screen attaches to the baffle wall? is there a space left for them? you lost me with that part?
jimim is offline
post #9 of 156 Old 03-08-2015, 01:43 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
i'll try and get a picture of what did. my lighting will be from the bottom up style. i ended up notching a little section on the supports that are just for the holding the screen and velvet panels.
yea, sorry, there is 13" between the baffle wall and screen wall. in the pic below, i ran power to the front of the baffle wall, but behind the frame wall. then in the downward arrows i notched gaps to hold the track. we'll see if the barndoor accessories are visible, once the screen is hung.
if it is, i'll run another support a tad lower to hold the lights. went with the notching first as the subs haven't been placed in their cutouts
lpnaz480 is offline
post #10 of 156 Old 03-08-2015, 05:31 PM
jimim's Avatar
Quoted: 577 Post(s)
Liked: 158
Ok that's makes sense. So the baffle wall, 13 inch gap to the screen support framing. Lights inbetween. What is the circle stuff behind the wall? Treatment and design of the false and baffle wall?
jimim is offline
post #11 of 156 Old 03-08-2015, 05:53 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
the baffle is 14" off the wall, the frame 13" from that. the holes are attached to the baffle wall and are per nyals design. i had lots of mdf left over so we used that, the spec called for plywood. holes were punched out w/ hole saw 3" diameter, 4" on diameter.
lpnaz480 is offline
post #12 of 156 Old 03-09-2015, 07:24 AM
jimim's Avatar
Quoted: 577 Post(s)
Liked: 158
thanks for the info. that's cool about the holes. i didn't get my plans yet for the wall. i'm not there yet. i am getting stuff from him as i need it.
jim
jimim is offline
post #13 of 156 Old 03-09-2015, 07:01 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
jim
no problem, the holes were definitely the dirtiest trickiest. nyals been awesome, i've had tons of questions, probably more then he wanted to answer and has been tremendous in this whole project.
lpnaz480 is offline
post #14 of 156 Old 03-09-2015, 07:12 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
the goal for the walls is to have some wainscoting, the chair rail, then fabric covering up the acoustic treatment. per the acoustic plan, the side panels start at 28" high, giving me room for wainscoting. i kept the entire wainscoting 28" total, but adjusted per steps and riser.
wainscoting is mdf and to adjust for depth of the panels, 3" deep. insulation stuffed in the cavity.
started w/ 2x2, then added another layer of 1" thick wood, to bring it out those 3"
close up
ID:	594241   Click image for larger version
lpnaz480 is offline
post #15 of 156 Old 03-09-2015, 07:31 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
heres a better pic showing the separation. the shiny plastic is the wac track i notched into the frame. just waiting on the end of line junction box to arrive to connect the line and wac
lpnaz480 is offline
post #16 of 156 Old 03-09-2015, 08:14 PM
Cksqurd's Avatar
Quoted: 64 Post(s)
Liked: 56
Can't wait to see the finished room. Looks like it will be awesome.
Cksqurd is offline
post #17 of 156 Old 03-10-2015, 05:29 AM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
thank you. yours looks great too!
lpnaz480 is offline
post #18 of 156 Old 03-10-2015, 05:56 AM
jimim's Avatar
Quoted: 577 Post(s)
Liked: 158
cool thanks. i can't wait to build my baffle wall. i got to build a stage first though. i spoke with nyal about the stage a few weeks ago and he wanted me to just nix it, but i really want that look. maybe of my room was wider i would have and added some columns but its so narrow my screen goes end to end almost. figured the stage would dress it up. i can't wait to see ur front of the room done.
keep chuggin' along!
jim
jimim is offline
post #19 of 156 Old 03-10-2015, 06:22 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
jim
thanks dude. i'm hoping more platfoam comes in soon so i can wrap up the baffle wall
i was looking at a stage in the beginning but adding the depth i need for the baffle wall, then the riser needing to be 36" from the new wall in the back (which is more like 40 w/ dd dw) i didnt see the point for me. it would cramp down on room size, probably make it feel overcrowded. plus i have a side door that would of gotten in the way.
i agree though, i like the stage look in the other rooms on this site
lpnaz480 is offline
post #20 of 156 Old 03-10-2015, 07:02 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
because the room isnt long, i only have 4 columns, two on the side of riser, 2 in the back. the columns were built in the room. used 2x2 for support and then covered them with mdf, using screws. measured out what the cutout would be and did it by hand.
back columns i had to adjust for the returns that were in the soffit. the only pic i have is a blurry one of the frame
heres the cavity filled w/ insulation. added 3/4" mdf as the face
other side showing more insulation
heres the screw up in placing the return grill and columns. did the little notch out giving enough space to open the grill and change filters
ID:	596161   Click image for larger version
ID:	596169   Click image for larger version
lpnaz480 is offline
post #21 of 156 Old 03-10-2015, 10:19 PM
Nyal Mellor's Avatar
Quoted: 546 Post(s)
Liked: 387
Looking good!! Can't wait to come and calibrate that bad boy!!
lpnaz480 likes this.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
post #22 of 156 Old 03-10-2015, 10:22 PM
Quoted: 546 Post(s)
Liked: 387
The holes are there to let sound into the deep pink fluffy trap behind the baffle wall. Plus they provide some scattering for the surround speakers. Sometimes my baffle walls have holes, sometimes just a big are that is covered. Depends on the room. I really like 'hybrid' baffle walls. Provide the function of reinforcing the output of the LCRs and also provide function of bass trapping for the room. And sometimes you can even make them diffusive, like this one!
post #23 of 156 Old 03-11-2015, 01:41 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
thanks! its coming along nicely and cant wait to have it calibrated
lpnaz480 is offline
post #24 of 156 Old 03-11-2015, 02:39 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
after the column cutouts, sealed and sanded and sanded and sanded the mdf. got it nice an smooth, primed the entire room.
the back corner
showing same corner, though with my step and riser
left side wall
my color scheme so far is: black soffit/ceiling, black carpet, midnight blue wainscoting, walls gom 701 blue plum (will be last. need to save for it)
carpet:
http://www.fabrica.com/forms/product...19LF&cId=999LF
soffit/ceiling paint:
went to hd and asked for black mouse ear
wainscot:
https://www.dunnedwards.com/colors/browser/det579
blue plum:
ID:	597441   Click image for larger version
ID:	597449   Click image for larger version
lpnaz480 is offline
post #25 of 156 Old 03-11-2015, 08:04 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
added crown molding, chair rail, and baseboards.
you can see 2 crown moldings on the soffit. the top is king george and is huge. the one below it is a smaller prince george. the soffit is 18" and with the location of the king george molding being higher, i needed another tray to hold the blacklights; hence the prince molding. this is painted black and blends with the soffit.
only thing missing is the trim on the wainscoting and around the column cutouts.
you'll notice the back columns werent planned properly and got in the way of the returns. putting the top mdf on there was cramped and difficult. could get it flushed as you see
to correct and hide that gap, we rotated crown molding and nailed it around that step down cutout section on both sides
ID:	597857   Click image for larger version
ID:	597865   Click image for larger version
ID:	597873   Click image for larger version
ID:	597881   Click image for larger version
lpnaz480 is offline
post #26 of 156 Old 03-12-2015, 06:54 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
jeff came by yesterday so the days before were spent finishing any soffit and ceiling painting. also needed to get the quadfusors/minifusors stuffed and up.
here the ceiling completed before jeff's work. you see the 2 crown moldings on the soffit arent as cluttered looking now that the prince is painted black
like others, capturing the after is hard. but man is it amazing in person. photos don't do it justice to how stunning the ceiling is. the hardwork that jeff puts into his artwork is astounding. thanks jeff!
lpnaz480 is offline
post #27 of 156 Old 03-12-2015, 08:39 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
heres the general lighting plan.
have a dedicated line for my pj, and two lines for my subs. home run to the panel. the subs are plugged into the surgex, the pj in the apc j25.
i have six zones all controlled via lutron grafix eye
side soffits
rear soffit light
speaker lights
riser
cove lighting
blacklights for star mural
lpnaz480 is offline
post #28 of 156 Old 03-12-2015, 08:44 PM
billwil's Avatar
Quoted: 104 Post(s)
Liked: 77
Two things to say. I Can't wait to see it finished, and Go Devils!
Great job so far. Good luck on the rest of the build. I have to admit I'm just a little bit disappointing that it's not going to be maroon and gold.
Bill~
billwil is offline
post #29 of 156 Old 03-12-2015, 09:16 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
Bill~
go devils
thanks! maroon and gold did cross my mind, once lol.
lpnaz480 is offline
post #30 of 156 Old 03-13-2015, 08:26 AM
jimim's Avatar
Quoted: 577 Post(s)
Liked: 158
nice job. you are trucking. i had momentum and lost it this week. your crown's look really really nice.
jim
jimim is offline
atmos , jive , jvc rs57 , multifuser , procella
