TBNL (To Be Named Later) Theater Build - AVS Forum | Home Theater Discussions And Reviews
 17Likes
post #1 of 70 Old 03-24-2015, 02:17 PM - Thread Starter
grnwnv's Avatar
Quoted: 27 Post(s)
Windy City Cinema Theater Build
What better use for my 3rd post ever than to start a build thread, right? I have been around the forum for many years, soaking up the knowledge and waiting for the day when I would be able to build one of these great rooms. I almost got there 2 years ago, and I had finished all of the rest of my basement (my wife knew I would never finish it if I worked on the theater at all), but I was suddenly forced to relocate for my job and my opportunity vanished. We finally moved into our new house about 6 months ago, which has a space reserved for a dedicated theater. It is not an ideal space, but after reading so many build threads I am not even sure such a thing exists. Everyone seems to have obstacles, and mine will be no different. The room is roughly 20' x 20' x 9', which is great for the width, but not as much depth as I would like. The other challenge is that it is upstairs, since there are no basements in Florida. Even so, I consider myself very lucky to be able to do this at all, so I am going to make the best of the space I have. I will be doing all the work myself, of course. I am a technologist by day, and I have done a lot of construction projects over the years so I have a good foundation of skills and tools to work with. Hopefully, coupling that with all of the great knowledge I have gained, and will continue to gain, from all of you I can make something my family can thoroughly enjoy for years to come.
Here are my main goals for the project, which will ultimately drive the decisions I make along the way.
1. I have 4 young children. This is a space for us to enjoy as a family, which will certainly differ in some ways from an adult focused space. It is also a built in excuse for when I don't make the progress that I should. Funny how that works.
2. Sound proofing is important. I will be trying to do everything I can, within reason, to keep sound in the room. I am resigned to the fact that I won't be watching certain movies at reference level when my children are asleep, but I want it to be as isolated as possible.
3. I want to do everything myself. I don't intend to build my own speakers, but as far as the room goes I won't be contracting anything out. I enjoy doing this type of work in my spare time, and I want the satisfaction that comes with building something with your own hands. Plus, I am afflicted with a certain amount of OCD that would prevent me from having others work in my room. I could probably cure that with therapy, but that money would be better spent on a projector.
4. While budget won't be a primary driver, and I don't have a number in mind to stay within, I will keep my spend to a reasonable amount. I realize that is somewhat subjective, but I would guess I am somewhere in the middle in terms of the rooms I have seen here on AVS. I want a good quality experience, but 30K for a projector isn't for me.
5. Lastly, I want to watch movies. That is why everyone builds these rooms, right?
I don't have everything figured out yet, but I do have some layouts and photos that I will post later tonight or tomorrow. However, I believe I have enough figured out to move forward with construction of the room which I started recently. Mainly, this is demolition of the current space right now. I had to remove all of the existing drywall and sub-floor and start from scratch. I am pretty sure some of my neighbors think I am crazy for demolishing a room in a brand new house, but whatever. I begged the builder to leave it unfinished, but they were not able to do it. At this point, I have removed everything but the ceiling and I am halfway done putting the floor back in place after filling with pink fluffy goodness. I also had to replace a bunch of recessed lights for the room below as the ones they put in were non-IC rated. Figures.
I will post my current progress along with photos and current plans in another post. Hopefully, later tonight. Until then, thanks to all of you that have chronicled your builds over the past several years. I would never have been able to start this without that knowledge. Hopefully, my thread can serve someone else the way so many others did for me. Still so much to figure out along the way, but let the fun begin!
grnwnv is offline
post #2 of 70 Old 03-24-2015, 02:17 PM - Thread Starter
grnwnv's Avatar
Quoted: 27 Post(s)
Reserved for future use.
grnwnv is offline
post #3 of 70 Old 03-24-2015, 04:34 PM
billwil's Avatar
Quoted: 104 Post(s)
Liked: 77
Awesome. Can't wait to see it develop. I'm jealous of your dimensions, so it's all relative. Since you're planning on soundproofing where possible, are you going to dampen the floor with green glue and two layers (at least) of subfloor?
Best of luck through the process...you'll have fun (but there will be many times you just want it done).
My latest theater build: Whisper Mountain Theater
billwil is offline
post #4 of 70 Old 03-25-2015, 06:42 AM - Thread Starter
grnwnv's Avatar
Quoted: 27 Post(s)
The short answer to the floor question is yes. More specifically, here is what I have planned for soundproofing overall.
  • Double Stud Walls all around
  • 2 layers of 5/8" drywall with GG on walls
  • Clips and Hat Channel for ceiling along with 2 layers of 5/8" drywall and GG
  • On top of the sub-floor, I will add Serenity Mat and then 2 additional layers of sub-floor with GG
  • Stacked single doors in the entry (Still deciding if I want to do this or not)
  • All wiring and HVAC will be in the soffit, which will be built after the room is sealed
All of that came from discussions with Ted at Soundproofing Company, where I ordered all of the materials from. If anyone sees any glaring holes in that plan, or room for improvement, I am always open to suggestions. Particularly when it comes to the door as I don't love that plan at the moment. I need to figure it out pretty quick though.
grnwnv is offline
post #5 of 70 Old 03-25-2015, 07:16 AM - Thread Starter
grnwnv's Avatar
Quoted: 27 Post(s)
As promised, here are some photos of the room before I started, and one that shows the current state. As I said, I have removed all of the drywall on the walls, and about half of the original floor. I am purposely waiting to deal with the ceiling until I have a large chunk of time. I don't want to leave that room open to the attic space for a long period of time, so I need to be completely prepared to do that work when I start. I am also attaching a basic plan for the layout of the room. I would love some input on what I have, but there are a few limitations to work within. First, the location of the door isn't really flexible. The wall where the screen is currently is an exterior wall, and on one side is my daughters room and on the other side is a mechanical room. The hallway is really the only place to enter the room. It could potentially move a little left to right, but that's about it. I am currently planning on taking a small chunk of the hallway out to house my equipment rack. That is the only place I could go outside the existing room, and I didn't want to use the room space if I could avoid it. I wish I could find a way to do 2 rows of seats, but unless someone sees something that I don't it just isn't possible. With 4 kids I really wanted everyone to have their own seat, but as of yet I have not been able to come up with a layout where that is possible. Giving up the AT screen might help there, but that is something I really want to have. If anyone has any ideas, thoughts, or whatever please share.
ID:	624193   Click image for larger version
ID:	624201   Click image for larger version
ID:	624209   Click image for larger version
ID:	624217   Click image for larger version
ID:	624241   Click image for larger version
Name:	Home Theater Design - 1.jpg
grnwnv is offline
post #6 of 70 Old 03-25-2015, 07:39 AM
JohnstownFlood's Avatar
Quoted: 187 Post(s)
Liked: 147
You need the double decker couch from the Lego Movie! Looking forward to the progress.
mushroommunk likes this.
JohnstownFlood is offline
post #7 of 70 Old 03-25-2015, 07:02 PM
billwil's Avatar
Quoted: 104 Post(s)
Liked: 77
Yes! Demo pics. Love seeing a perfectly good room torn to pieces. BTW, your soundproofing plan sounds awesome. Looking forward to seeing it come together. Oh, and plus one on the double-decker couch. Good call, JohnstownFlood.
billwil is offline
post #8 of 70 Old 03-31-2015, 08:36 AM - Thread Starter
grnwnv's Avatar
Quoted: 27 Post(s)
Floor should be done in the next day or two, and I am now planning my materials to frame the internal walls and run the electrical. I plan to have minimal penetrations in the walls for electrical by putting the outlets in the columns like most people do. The part my brain is struggling with at the moment is the switch boxes just inside the door. How did you guys figure out exactly what depth to mount those at? I have had issues in past projects where the boxes weren't at quite the right depth, and then the outlets end up looking sketchy when you are done. I want to be 100% certain that doesn't happen here. Is there some way to do it such that I have some flexibility when I get to the finishing stage? I am not 100% certain what the depth of my acoustic panels will be in that area yet, so I am hoping I can figure out a way to make it flexible. Any suggestions would be appreciated. Thanks.
I will try to post some pics of the final floor work for those that are interested. I can say that prying up sub-floor that was screwed, nailed, and glued is not a pleasant way to spend an evening.
grnwnv is offline
post #9 of 70 Old 03-31-2015, 09:30 AM
M.T.Nest's Avatar
Quoted: 30 Post(s)
Overflow Seating
Our room is technically not "finished", but we're using it. We have two rows of three seats, but sometimes that isn't enough. We'll eventually have bar seating behind the second row, but we accommodate overflow seating using a Lovesac Supersac we bought second hand. It's been known to accommodate four kids and an English Mastiff all at once, although in the spirit of full disclosure, the dog doesn't really care about watching films.
Here's a link to the product page fyi: http://www.lovesac.com/sacs/supersac.html
I imagine this thing may act as sound absorption, but we've never done any measurements.
Good luck with your build!
Kevin
M.T.Nest is offline
post #10 of 70 Old 03-31-2015, 09:50 AM
RedStripe88's Avatar
Quoted: 226 Post(s)
Liked: 191
A couple options to handle the switches just inside the door:
1) Adjustable depth box
2) Build a backer box and defer the decision on how deep to place the box until you know your panel depth.
3) Combine 1 and 2
4) Figure out your panel depth now
I went with #1 and #2 . Adjustable depth switch boxes in an MDF backer box:
Frame built to fit around the electrical boxes:
Covered fabric frame around the boxes:
Adjustable boxes adjusted to be flush with fabric frame:
My in progress build thread: The Salt Mine
RedStripe88 is offline
post #11 of 70 Old 04-22-2015, 12:51 PM - Thread Starter
grnwnv's Avatar
Quoted: 27 Post(s)
3) Combine 1 and 2
Thanks for the info on the switch boxes. That was helpful, and allowed me to complete the backer boxes and still have some flexibility for acoustical treatment in the end. I am clearly not great about updating my thread, so I need to get better at that quick. I am currently just about to start on the 2nd layer of drywall. I had a few days off, so I put them to good use and spent 14-16 hours a day in the theater for 5 straight days. I also have some good pictures of the room after the entire drywall ceiling fell down on top of me, but that will have to wait until I am at home. I can laugh about it now.
For the moment, I am struggling with the the devils triangle of seating capacity, screen size, and viewing distance/angle and was hoping to get some thoughts from those that have experience. As I mentioned earlier, I have 4 young kids (2 thru 9) so having a seat for the whole family is a priority. I can't even imagine the fights that will ensue if everyone does not have the same kind of chair. My head hurts just thinking about it. Anyway, my original design had 4 theater recliners with bar seating behind and I have come to realize that just won't fly with the family. I finally realized that if I create a row of 6 using 3 love seats I can actually fit it in a single row. So, I think that is going to be my new plan as I just couldn't find a good way to get 2 usable rows given the restrictions of my room. Now, I am struggling with whether I should keep the bar seating at all, or just move the single row back to get a better viewing angle and possibly increase the screen size. My room is wide, about 19 ft after soundproofing, so I want to make sure the screen is large enough so that it isn't dwarfed by the room. At the same time, I don't want it so large that it is uncomfortable. How often do people use those extra seats for guests in reality? In theory they are nice to have, but I am not sure if I would need more than 6 seats very often. Is it worth a slightly smaller screen or a less than ideal viewing angle to have 6 more seats at the bar?
The last piece to that puzzle is whether to go AT for the screen or not? With only 19 ft of depth, sacrificing 2 feet to a false wall is tough. I really like the look of the AT screen, and the fact that it hides everything. I also think it just has a "cool" factor. But will that wear off in the short term and lead to regret at the sacrifice of screen size and/or viewing angle? Other than having to go with a horizontal center channel, and having to expose my speakers, there really isn't much downside to go with a normal non-AT screen that I can see. I am starting to feel like an AT screen is just a luxury that I should compromise on in favor of the extra space, but I am happy to listen to anyone that wants to talk me out of it.
Thanks in advance for any thoughts, and I will try to satisfy the picture cravings tonight.
grnwnv is offline
post #12 of 70 Old 04-23-2015, 11:52 AM
J_P_A's Avatar
Quoted: 762 Post(s)
Liked: 574
Have you considered a second row of theater style chairs? Something like this
They're not recliners, but they save a lot of space and are still nice and comfy. You could do reclining theater seats on the front row, and then these on the back. You would need a riser. Could you build a riser and have the step up outside the room?
Also, have you considered moving the surrounds forward of the seats? There are quite a few designers that recommend that.
EDIT: Have you considered putting your light switches in the column next to the door? I'm not sure how far away that is from your drawing, but it's a thought.
The Plains Theater Has Begun
J_P_A is offline
post #13 of 70 Old 04-23-2015, 11:54 AM - Thread Starter
grnwnv's Avatar
Quoted: 27 Post(s)
So, as promised, some photos of my ceiling cave in. I had purposely not torn out the ceiling because I wasn't sure how I was going to handle all of the blown-in insulation. On top of that, I wanted to leave the attic exposed for the shortest possible time since I live in Florida and it is already hot down here. I did want to get the new walls up though, so my plan was to cut out about 6 inches around the edges of the ceiling. That would give me enough room to attach the clips to the joists/walls and get all the new walls built. That way, when I took the ceiling down I would just have to put up clips and track and be ready for drywall. Everything was going fine until I got to the first corner. I had cut a line about 6 inches out with my RotoZip, and I was just ripping out the part near the wall. When I pulled on it near the corner, it seemed like I had not gotten all the way through the drywall with my saw. So, of course, I pulled harder. When I did, the whole first sheet started coming down, and then the next, and the next, like dominoes. In a matter of about 5 seconds, the entire ceiling save one sheet had fallen on me. It wasn't funny at the time, but luckily I got off the ladder quick and got my hands up to prevent injury.
ID:	682025   Click image for larger version
grnwnv is offline
post #14 of 70 Old 04-23-2015, 12:09 PM
JRock3x8's Avatar
Quoted: 1804 Post(s)
Liked: 566
thats terrifying - glad you're okay!
JRock3x8 is offline
post #15 of 70 Old 04-23-2015, 12:14 PM - Thread Starter
grnwnv's Avatar
Quoted: 27 Post(s)
And here are some photos of my progress thus far. I completed the new walls inside the room, ran the electricity, HVAC, and low voltage wiring, and insulated the walls. Most of the wiring will take place within the room once it is sealed, so the wiring wasn't too complicated. I have a large mess at the switch box to sort out, but it is all labeled so there is no rush since none of the lights are in yet. I also built and hung some backer boxes for future potential Atmos speakers. I am not sure if/when I will use them, but I figured now was the time to do it. If I want them, they are there. If not, it was only a few hours effort lost. Finally, I put up the clips and channel for the ceiling. Never having done that before, I won't discuss how many mistakes I made. I should have gotten a laser level, but the big box didn't have one I wanted and I didn't want to wait. It turned out fine when I was done, but I did a lot of it multiple times to get there.
A quick tip for anyone trying to mount large backer boxes in the ceiling. I found that it was really simple to get the box in perfect position by using the drywall lift. That allowed me to easily adjust it, plus be certain it would end up exactly even with the drywall like I wanted. If not for that lift, I have no clue how I would have managed it. Especially by myself.
Once I had everything in the walls that I needed, I started doing the drywall. Thankfully I was able to get the drywall company to bring it all upstairs for me. I have done a fair amount of drywall work over the years, but never with 5/8" drywall. That stuff is really heavy. I estimated 68 sheets to do 2 layers, and there was no way I was getting that upstairs alone, or with my wife for that matter. Even with delivery and taking it upstairs it still ended up being cheaper than buying it at HD, so I was happy about that.
At this point I am about 95% done with the first layer. I still have the small pieces at the top of the walls, and the section right by the door. I didn't have my backer box for the switch done, so I couldn't finish that part of the wall. I have since built that, and I will install it this weekend along with the remainder of the first layer of drywall. I also hope to get all the seams caulked this weekend as well. If I am lucky, maybe some of the 2nd layer will start going up. As a rule though, I am not very lucky.
ID:	682177   Click image for larger version
ID:	682185   Click image for larger version
ID:	682193   Click image for larger version
ID:	682201   Click image for larger version
ID:	682217   Click image for larger version
ID:	682225   Click image for larger version
ID:	682233   Click image for larger version
ID:	682241   Click image for larger version
ID:	682257   Click image for larger version
ID:	682265   Click image for larger version
grnwnv is offline
post #16 of 70 Old 04-23-2015, 12:22 PM
J_P_A's Avatar
Quoted: 762 Post(s)
Liked: 574
..... If I am lucky,..... As a rule though, I am not very lucky.
This should be on a T-shirt.
With four kids, I'm impressed that you are making progress this quickly! I've only got two, and I can never find time to work in my theater
J_P_A is offline
post #17 of 70 Old 04-23-2015, 12:23 PM - Thread Starter
grnwnv's Avatar
Quoted: 27 Post(s)
I had not considered either of those things. I haven't seen anyone put their speakers in front of their seats, but maybe I just wan't paying attention. Are there any examples you can think of where they have done that?
The switch in the column actually isn't a bad idea either. It isn't as close to the door as I would like, but that might not matter to be honest. I am putting a contact in the door and the lights will go on automatically when I come into the theater and it is not in use.
Both excellent suggestions, thanks.
grnwnv is offline
post #18 of 70 Old 04-23-2015, 12:40 PM
J_P_A's Avatar
Quoted: 762 Post(s)
Liked: 574
Going from memory, I believe dlbeck's Savoy theater and BrolicBeast's theaters both use that layout as well as mine. It is recommended by Toole and the ITU standard uses it as well for 7.1 IIRC, and Nyal recommends this layout for his spaces (Nyal designed all three of the spaces I've mentioned).
Another that comes to mind is Roger Dressler's space, but I'd have to search for it to be sure.
Full disclosure, not all the big name designers use that layout. Dennis Erskine for example uses the typical Dobly and THX layout with the sides at 90 or little behind.
EDIT: Here's a quick reference from Nyal's site
J_P_A is offline
post #19 of 70 Old 04-23-2015, 12:45 PM
atc98092's Avatar
Quoted: 1343 Post(s)
Liked: 559
So you are completely blocking access to the two windows? Will that cause any issues for future building maintenance? Just curious, and I certainly understand not leaving them open to the room.
Dan
Samsung JU7100 4K TV, Yamaha RX-V583, Nvidia Shield, a number of Roku players and TVs, Windows 10 media server with Serviio and Plex. Other players and TVs as well.
atc98092 is offline
post #20 of 70 Old 04-23-2015, 01:34 PM - Thread Starter
grnwnv's Avatar
Quoted: 27 Post(s)
Fair question, and one I did think about. Here is the way I look at it. It is a second floor window just above my screen enclosure in the back. It would be very difficult for something to accidentally break those windows because they just aren't easily accessible. The windows don't open, so there should not be any leaks. It is also a brand new house. I actually considered removing them completely when we built it, but I thought the outside of the house looked odd without them. Lastly, I can access it from outside if anything actually does happen. For example, I do have to caulk the outside every so often. In a nutshell, I didn't see any justification for leaving access to it. I am sure others might see it differently, but that was my thinking.
Note, I did put a fancy window film with white backing on the window before I covered it, so from the outside it looks like we just have some fancy curtains that are closed. Unless you see the room, you will never know that I covered them. Even then, you might not realize it.
grnwnv is offline
post #21 of 70 Old 04-23-2015, 03:09 PM
JVoth's Avatar
Quoted: 307 Post(s)
Liked: 154
Sub'd. Looking good so far. I second JPA's suggestion for the theater style chairs. I have them in my room and they are really nice. Probably perfect if you have 4 kids. I will say that I would rather have a bar though. I drink a crap load of beer and eat in the theater room a lot so that would have been handy for sure. But like I said with 4 youngsters running around, theater seats would be perfect.
JVoth is offline
post #22 of 70 Old 03-14-2016, 07:03 AM
Mattcc22's Avatar
Quoted: 185 Post(s)
Liked: 173
Do you know yet what speakers and projector you will be using?
Mattcc22 is offline
post #23 of 70 Old 03-14-2016, 07:22 AM - Thread Starter
grnwnv's Avatar
Quoted: 27 Post(s)
I really need to put in a full update, as the room is substantially further along than my last update. That will take more time than I have at the moment, so I will just answer your questions for now. I went back on my original stance on speaker construction, and decided to build them all. I have completed 3 1099's for my LCR, as well as 2 18" subs. I wanted to have more subs, but I just can't fit them. I am currently building 8 Volt 10 LX's for my side, rear, and Atmos surrounds. As for the projector, I am planning on the JVC RS400 right now. I still have about 2 months until I have to make that decision formally, but that is my thought currently.
grnwnv is offline
post #24 of 70 Old 03-14-2016, 09:00 AM - Thread Starter
grnwnv's Avatar
Quoted: 27 Post(s)
I also finally decided on a name for my theater, so I changed the thread title. I live in Florida now, and have for the past couple years, but I spent my whole life before that in and around Chicago. I always find myself saying that I live in Florida, but I am from Chicago. So, I decided to bring a little bit of that into my house by naming my theater the Windy City Cinema. I am not sure what other Chicago themes, if any, I will work in besides the name, but we will see what comes to me as I go.
grnwnv is offline
post #25 of 70 Old 03-14-2016, 01:07 PM - Thread Starter
grnwnv's Avatar
Quoted: 27 Post(s)
I am going to try and catch the thread up to where the room currently sits. After putting up the 2 layers of drywall, I turned to soundproofing the floor as much as possible. As I said earlier, this would consist of first insulating beneath where the original floor was, replacing that floor, a layer of Serenity mat, and then 2 additional layers of subfloor separated by a layer of Green Glue. Other than the fact that my room is an odd shape with angled corners, this was fairly straightforward to accomplish. Probably even easier if you don't have to do it by yourself, but I did so it can be done. Here are some photos of that process since I haven't seen many people do this. Unfortunately, I don't have a basement so it is my only option.
You can see that I have shims to keep the floor away from the wall. Eventually that space gets filled in with acoustic caulk.
Another angle.
Finally almost done, coming back from the other side.
Stage to follow......
grnwnv is offline
post #26 of 70 Old 03-14-2016, 01:39 PM - Thread Starter
grnwnv's Avatar
Quoted: 27 Post(s)
Once the floor was done, my next step was the stage. I wanted something a little different than what I typically see here on the forum, but ultimately it ended up pretty similar to most. I think my steps are fairly unique though, which made it a little more challenging to build. Other than some unique construction to deal with the corners of the steps, it is pretty similar to what you normally see. It is 2x10 construction, filled with pink insulation, with a single layer of 3/4 plywood on top. Given that my theater is on the 2nd floor, weight is a consideration. So, that obviously precluded the use of sand as a filler. It is also part of the reason I went with a single layer on top. There are some wires running through the stage as well. I have wiring for some screen lighting, which I am not entirely sure what I am going to do with yet. I will probably try some back lighting and see if I can work out something I like. It would mainly be for a cool factor when showing off the room, and not really useful overall. If I don't use it, no harm done. I also have the speaker wiring for the LCR and subs coming out in the back as well along with a couple general purpose outlets. Here are some construction photos.
First I set the supports in place for the overall structure.
Once that was done, I created a pattern from 1/4" plywood for the front steps. I don't have any photos of this process though. I created the pattern, and then put it on top of the structure I had set out. I traced the pattern on to the supports, and then I notched them all to match the desired pattern. Here is a shot of the stage after I cut the supports with the patterns laying on top.
That was not as easy as I had hoped, but it worked out. Once that was done, I created the actual tops of the steps out of 3/4" plywood. Then, I created some additional supports for the steps. Those were both to support the plywood as well as help give shape to the plywood that I had to bend around the edge. Here are a couple photos of that.
Once the steps were done, I basically repeated the process for the top. The only difference being some cutouts I had to make for the wiring. Once again, not having a rectangular room made this a challenge, but it came out pretty nice. I guess I forgot to take a photo right after I finished the stage, but here is one that shows most of it. As you can see, this is taken after I started building my speakers. That is one of my 1099's sitting on the stage.
With the stage complete, it is on to the soffit which included the HVAC, lighting, and the equipment rack.
Mattcc22 likes this.
grnwnv is offline
post #27 of 70 Old 03-14-2016, 05:48 PM
swanym's Avatar
Liked: 3
I want to make that my signature.
mumps and astrofool like this.
swanym is offline
post #28 of 70 Old 03-14-2016, 07:04 PM
wtshaw1971's Avatar
I love the stage....certainly the steps are not your garden variety steps.
wtshaw1971 is offline
post #29 of 70 Old 03-15-2016, 06:17 AM - Thread Starter
grnwnv's Avatar
Quoted: 27 Post(s)
For the soffit, I pretty much stole the entire thing from various theaters on this forum. I always liked the soffit on the Bacon Race theater, so that is probably the one that influenced it the most. Other than the very front, almost the entire thing is filled with HVAC, so leaving it open on the bottom didn't make much sense.
I started out putting in all of the HVAC, which included building some custom register boxes
Once the HVAC was done, I started the soffit. Similar to many, I hung a 1x2 from the ceiling, and then attached the sides of the sides of the soffit to that with screws and glue. The angled corners were once again a joy to deal with.
Once the sides were up, I filled any open space with insulation, and brought the wires for the lighting through into where the light tray would eventually sit. Only one of the corners of the room is square, and below you can see that I angled the soffit to match the rest of the room.
Then I started on the light tray. First the bottom was attached. It is 6 inches from the soffit everywhere except for the front. On the front I created a curve that matches the stage in shape, but it isn't directly above it.
Here you can see the front. Not to worry, I put in additional bracing shortly after this to hold up that giant curve.
Once all of the bottoms were up, it was time to add lighting. Those halogen work lights get really hot, so it was definitely nice to finally get some real lighting in the room. The soffit contains LED can lights, rope light, and black lights for the star ceiling. I will show some details on that in the next post.
grnwnv is offline
post #30 of 70 Old 03-16-2016, 07:14 AM - Thread Starter
grnwnv's Avatar
Quoted: 27 Post(s)
I still have more updates to do before I am caught up to present day, but I wanted to throw out a question first. As you can see from the last picture of my stage area, I lack the corners traditionally used for bass traps. While I have managed to read the Acoustics thread from start to finish (a pretty big feat in my opinion), I can't say I "absorbed" as much as I would like. I generally understand the reason corners are good for bass trapping, so I am curious what options I might have with the shape of my room. I will have an AT screen, so I have some space to work with back there. I could still cut the traditional triangles and put the long side against the wall, but I am not sure if that will function properly from an acoustic perspective. That might be hard to envision and I don't have time to draw it right now, but if you look at the stage and picture an AT screen about 2 feet off that wall you can see where a reversed triangle might fit at the very edge against the wall. If anyone has thoughts on that idea, or perhaps a better one, please let me know. Thanks.
grnwnv is offline
