HT Part Deux with Coffered Ceiling - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #1 of 39 Old 05-09-2015, 02:11 PM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
I think the seven-year itch finally kicked in. Here is what my theater looked like six weeks ago.
I saw some good postings, and couldn't stay away from some ideas I noticed, especially the acoustics panels in YzfBossman's theater. I just got to have it.
I have spent about six weeks of "weeknights and weekends", and this is the current status.
Front view:
Rear view:
I've been busy working my butt off, and not have time to post, but I'm taking pictures as I progress, and I will be taking few breaks to post the column and ceiling details next week, and the updates going forward.
Thanks to other members who has posted in the past, (this is my second rodeo), and believe me, I'm always learning something new every time I login.
Major construction is halfway, next is the moldings..... And yes, there will be lots of them, especially in the ceiling, and around the columns.
auburnu008 likes this.
nosdude is offline
post #2 of 39 Old 05-10-2015, 06:35 AM
Cksqurd's Avatar
Quoted: 64 Post(s)
Liked: 56
That's going to be a cool looking room.
Cksqurd is offline
post #3 of 39 Old 05-10-2015, 06:53 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2725
Cool ceiling
Mfusick is offline
post #4 of 39 Old 05-28-2015, 05:15 PM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
Back On
I had to hold off on the theater build to build a side project, compliments of my Home Owners Association. I need to add a cover for my trash bins on the side of the house.
nosdude is offline
post #5 of 39 Old 05-28-2015, 05:16 PM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
Quick re-intro for my theater:
Seating:
3 in front row, 3 in the rear.
Screen:
142” diagonal 2.35 Seymour acoustically transparent curved screen at 40 degrees radius (DIY project)
Projector:
Panasonic AE-7000U 3D projector + sliding Anamorphic lens
Gear:
Pioneer Elite SC-27
Oppo BDP-103 BluRay
Popcorn Hour A-410
DirecTV
Polk Audio TSi200 Bookshelf for fronts (Will replace with Klipsch RF-82ii), and then become Rear surround
Polk Audio center (Will replace with Klipsch RC-62ii)
Klipsch RS-52ii (Surround speakers)
Lighting:
Lutron Caseta in four zones
Remote:
iRule app runs it all.
nosdude is offline
post #6 of 39 Old 05-28-2015, 05:29 PM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
Column details:
I got most of the ideas from the forum, and i tweaked a little to match what I'm looking for. I will eventually wrap the opening with a panel molding and build a panel cover with speaker cloth material.
Test with Klipsch RS-52ii surround speaker.
Six of Eight completed.
A view of wall of columns.
nosdude is offline
post #7 of 39 Old 05-28-2015, 05:43 PM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
Coffered Ceiling:
The design was based on 6x3 = 18 boxes.
Construction material was mostly 3/4" plywood.
Started with the long span across the room, and built the cross pieces, and attach with screws, one box at a time.
Span #1 completed, a couple of cross pieces attached.
These clamps were very helpful in holding things down before applying screws.
Row by row, Cross piece by cross piece:
Completed, 1/2 inch bottom piece added, and I ran the electrical wires for the 4-inch can lights.
nosdude is offline
post #8 of 39 Old 05-28-2015, 05:51 PM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
Misc
The trusted Kreg jig was very instrumental in the assembly process.
My kitchen island becomes an extension of my garage. Makes the perfect assembly table.
My cars are very jealous of my tools right now. They've been temporarily kicked out of the garage.
nosdude is offline
post #9 of 39 Old 05-28-2015, 05:58 PM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
Paint before Moldings
I decided to paint the moldings before install, while they are drying, we decided to start painting the room, and the coffers are going to get a red base that will match the acoustic fabric panel on the walls.
Front:
Rear:
nosdude is offline
post #10 of 39 Old 05-28-2015, 06:32 PM
DavidK442's Avatar
Quoted: 867 Post(s)
Liked: 729
That is a serious undertaking. Will definitely take your theater to the next level. Very nice.
DavidK442 is offline
post #11 of 39 Old 05-28-2015, 08:22 PM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
nosdude is offline
post #12 of 39 Old 05-28-2015, 08:58 PM
RicardoD's Avatar
Beautiful work so far. Thanks for sharing the photos.
RicardoD is offline
post #13 of 39 Old 05-28-2015, 09:03 PM
wse
wse's Avatar
Quoted: 2207 Post(s)
Liked: 814
All I can say it FANTASTIC this is going to be a very nice room! Can I come to the opening
wse is offline
post #14 of 39 Old 05-29-2015, 09:00 AM
d_c
d_c's Avatar
Quoted: 1134 Post(s)
Liked: 1543
d_c is online now
post #15 of 39 Old 06-16-2015, 07:04 AM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
Moldings, moldings and more moldings
Whew, this is a lot of work folks.... And I'm not even done yet.
Rear view:
Other Views:
Tedd likes this.
nosdude is offline
post #16 of 39 Old 06-16-2015, 07:48 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2725
WOW ceiling looks great !
Mfusick is offline
post #17 of 39 Old 06-17-2015, 01:14 PM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
Ceiling Speaker help
The coffered ceiling has about 6-inches plywood-made beams.
I just purchased two in-ceiling speakers, and i would like to know what your recommendation is between these two options.
Option 1:
Build a 6-inch plywood box that matches the existing coffer beams and install the speaker inside the box.
Option 2:
Install the speaker in the drywall inside the coffer. I'm just worried about heat in the attic. It's about 120 degrees up there around July/August.
nosdude is offline
post #18 of 39 Old 06-17-2015, 04:48 PM
Cksqurd's Avatar
Quoted: 64 Post(s)
Liked: 56
Option 1:
Option 2:
I would think install in ceiling with backer boxes in attic. Here in Phoenix , our attics get a lot hotter than that and my speakers are fine. Just a thought.
P.S. Room looks great!
Cksqurd is offline
post #19 of 39 Old 06-17-2015, 11:37 PM
bombertodd's Avatar
Quoted: 224 Post(s)
Liked: 138
Do you have a link or make and model of those lights on the walls?
Ceiling looks great!
Klipsch RF-82II, RC-62II
2x Dayton Ultimax 12, Behringer iNUKE3000DSP
Denon 2113ci
New Theater Under Construction
bombertodd is offline
post #20 of 39 Old 06-18-2015, 07:49 AM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
nosdude is offline
post #21 of 39 Old 06-18-2015, 07:56 AM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
Lamps Plus.
http://www.lampsplus.com/products/po...ht__r7825.html
bombertodd likes this.
nosdude is offline
post #22 of 39 Old 06-18-2015, 08:33 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2725
Did you design yourself ?
Mfusick is offline
post #23 of 39 Old 06-19-2015, 07:21 AM
lemonslush's Avatar
Quoted: 835 Post(s)
Liked: 424
I love the work you did. My wife wants that in our house now.
Mfusick likes this.
lemonslush is offline
post #24 of 39 Old 06-19-2015, 09:29 AM
javeryh's Avatar
Quoted: 314 Post(s)
Liked: 230
Wow awesome. How deep are the beams in the coffered ceiling? And how high is the ceiling. The moulding looks great. I've got 8' ceilings and want to add something like this to the ceiling but I don't want it to come down too far if you know what I mean.
javeryh is offline
post #25 of 39 Old 06-22-2015, 11:29 AM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
The beams are 7-1/2 inches. My ceiling is 9ft tall.
nosdude is offline
post #26 of 39 Old 06-22-2015, 11:30 AM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
Yes. It's 100% DIY. Which is why it's taken so long. My day job is always in the way.
nosdude is offline
post #27 of 39 Old 06-23-2015, 09:28 PM
DavidK442's Avatar
Quoted: 867 Post(s)
Liked: 729
I will add my own "Wow!" to the accolades. A total piece count would be mind boggling. Great work.
post #28 of 39 Old 06-26-2015, 07:10 AM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
Dolby Atmos and DTS:X Retrofit
Moldings are finally completed!!!
I installed four brackets for four indoor/outdoor speakers in the ceiling, and the accompanying wires this week. I chose outdoor speakers because I have no attic access, and plus the fact that it could be 120 degrees in the attic during the summer here in Texas, therefore cannot protect a regular ceiling speakers system. I'm going with the Klipsch R-28 home theater speakers, (recommended by Stereo East, an HT re-seller & installer in Frisco, TX due to the fact that the R-28F is a front firing speaker, and I have limited room behind the screen where I'm placing the front and center speakers) and their AW-650 outdoor has the same bass and tweeter technology which is a perfect fit.
I also build a test panel, using YzfBossman's methods with a slight variation. I went with a simple panel molding which is half the cost of the chair-rail. But still looks good all the same. I'll post detail pictures of the panel build next week, but here is a peak.
Here is the panel installed. The frame holding the material will simply slide in. And years from now, if i want to change the look, i simply take out the frame, replace the material.
nosdude is offline
post #29 of 39 Old 08-03-2015, 07:34 AM - Thread Starter
nosdude's Avatar
Quoted: 13 Post(s)
Nearly Completed
The light at the end of the tunnel. Finally got a break from my day job and did more work. I completed the panels, build a DIY rack (of course it's a 100% build).....
Here are some additional detail pics of the acoustic panels. Next is for the carpet contractors to come in and do their thing.
Completed panel frame and nailed in:
Nailed-in panels, top is 2-3/4" thick to fit the 2" OC703. Bottom is 3-3/4" thick to fit 3" Roxul:
Panels filled in with OC703 & Roxul:
Here are the completed fabric panels that simply get pushed into their respective slots:
The work it takes to get that professional looking paint job..... Whew!!!
And here is what the finished product looks like (minus the new carpet):
Here is a couple of pics of my DIY rack. Will eventually build an enclosure for it using mahogany plywood and gel stain.
Power is in, and so is the receiver.... the rest getting on board tonite.
nosdude is offline
post #30 of 39 Old 08-06-2015, 05:12 PM
Maklar's Avatar
Quoted: 45 Post(s)
Looks great. What fabric did you use for your panels?
Maklar is offline
