V-T HT 2.0: Dedicated Room within a Room within a Concrete Home - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #1 of 43 Old 05-11-2015, 02:32 PM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
Lightbulb V-T HT 2.0: Dedicated Room within a Room within a Concrete Home
I'm finally getting around to posting a build thread for theater 2.0. In July of 2014 we started building a concrete home using ICF or Insulated Concrete forms. Here at AVS I will concentrate on the dedicated theater built into a basement room of that home. Originally I was designing a multi-purpose Theater/Gameroom but eventually that design changed into two separate rooms, the dedicated theater and a Lobby/Arcade room. Though we ended up with a smaller theater we were able to improve our sound containment efforts.
Theater Size: The unfinished area set aside for the home theater is 16'6" wide and 19'5". Ceilings throughout the basement are 9' clear but we were able to step down the theater area gaining about 16" for 10'4" ceilings. Building a room within a room cut down our finished size quite a bit leaving 15'6" wide and 18'6" in length. Height varies due to the soffits from about 7'8" on the riser under the lowest soffit to just under 10' above the first row of seats.
Usage: 65% Movies, 25% Gaming, 10% TV
Design: I'd like for theater 2.o to be a very clean and open design. Components can be visible, in wall/on-wall but I want very little protruding into the room. 8 "Good Seats" with the front row of 4 being the ideal seats.
I like our current theater but I think I missed out not going with a wider AT screen.
Link to finished photos in old build thread.
The Plan:
So this is what we ended up with:
Showing Soffits:
Sound "Proofing" efforts:
  • The Theater is completely decoupled from the rest of the house... Well as decoupled as we could make it. It doesn't even share a slab with the rest of the basement. Exterior walls sit 1" away from the ICF/concrete walls on three sides and 1" away from the load bearing wall in the back. These walls then support a new ceiling interleaved between the floor joists above.
  • All walls and ceilings will have 1 layer or in some cases 2 layers of 5/8" OSB and a layer of 5/8" drywall with Green Glue between.
  • All walls and ceilings bays are stuffed with insulation.
  • All outlets, lights, switches, supply ducts, return vents and in-wall speakers are given a similar backer-box treatment of at minimum 2 layers of OSB.
  • You will then exit from the theater into the lobby that although not decoupled from the rest of the house has OSB/Drywall treatment and a second door to help contain the noise coming through the theater door.
Boomassiv likes this.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #2 of 43 Old 05-11-2015, 02:33 PM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
Reserved.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #3 of 43 Old 05-11-2015, 02:40 PM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
And now we join this build already in progress.
Excavation
The first time, but not the last we had water in the theater. Had to redo part of the excavation.
Footings formed up. Looking down at the theater.
Footings
1st of 6 times we had to pump out the theater.
Drainage and plumbing.
The slabs are in.
jroyv is offline
post #4 of 43 Old 05-11-2015, 02:55 PM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
Entering the Loby:
Framed Theater Entry:
Lobby/Arcade Looking at EQ room.
Lobby/Arcade EQ Room Door on left Dedicated Driving Sim / Game Pod Setup on right.
Future Screen Wall
Back Wall, No Riser Yet.
New Screen Wall from what will be the back row.
Stuffed with insulation.
Ducts will be wrapped in OSB
Double wall between lobby and theater.
8" return duct.
The Lift Chandelier
Soffits going in.
OSB going up...
Starting to take shape.
jroyv is offline
post #5 of 43 Old 05-11-2015, 04:48 PM
Boomassiv's Avatar
Quoted: 130 Post(s)
Liked: 53
Looking good
Boomassiv is offline
post #6 of 43 Old 05-11-2015, 08:10 PM
Quoted: 6250 Post(s)
Liked: 5979
a 16 inch tall riser only requires a single step not two, Actually two 5 and change steps will feel awkward but I would make it a big deep step as shown in my Big Step thread. https://www.avsforum.com/forum/19-ded...big-steps.html
post #7 of 43 Old 05-13-2015, 01:01 PM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
The riser finished out at closer to 18", by the time we add a sub-floor to the lower area I think we are looking at rise of 5-3/4" on three steps. We tested it out and they were comfortable as long as we made the run at least 12" I might mock up some big a$$ steps and see how those feel.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #8 of 43 Old 05-18-2015, 06:46 AM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
Drywall & Green Glue is Done... Now it's getting finished.
Screen Wall from the entry
Screen Wall from the back row
Looking back towards the riser
Empty Soffits above the screen... 2 - 6' long areas ~ 15" x 15" for use as base traps
Ceiling from the back looking forward. Each of these squares will get a base trap too, except the center section in the back. This is the bay for the projector.
Ceiling from the front.
Looking towards the EQ Room
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #9 of 43 Old 06-11-2015, 11:32 AM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
Adding a few pictures. THeater Screen Wall post primer and some pics of the lobby/arcade.
THere will be a desk with two monitors/game stations on this wall. and two on the opposite wall.
Equipment room and my "Game Pod" about 4'4" by 6'6" for a dedicated racing sim setup.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #10 of 43 Old 06-17-2015, 11:27 AM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
A friend shot this picture of my house... Thought it was cool even if it does capture the worst side, aesthetically.
I'll post some more exterior pics when it drys out a little. Concentrating on the interior right now.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #11 of 43 Old 06-17-2015, 11:51 AM
domz777's Avatar
Quoted: 77 Post(s)
Liked: 78
Holy COW! Where do you live, OZ?! There's a yellow-ish foot path running right thru an emerald forest that is DIRECTLY next to your house. And there's nothing else around but that.
Where I live, when I see that much green, I expect to see big numbers every 10 yards!
...and there's a freeking RAINBOW coming out of your house, no less.
What, you ride a unicorn to work too?!
domz777 is offline
post #12 of 43 Old 06-17-2015, 12:09 PM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
We have two houses going up on 40 acres... Cool until it comes time to mow. I Grew up on acreage can't wait to get back to it.
and oh yes about 12 miles east of the OZ state line.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #13 of 43 Old 06-17-2015, 12:37 PM
domz777's Avatar
Quoted: 77 Post(s)
Liked: 78
WOW 40 acres. That would cost like a billion dollars here LOL
and that wouldn't even include the unicorn OR a flying monkey.
They always kill you on the options LOL
domz777 is offline
post #14 of 43 Old 06-17-2015, 01:40 PM
eng-399's Avatar
Quoted: 2457 Post(s)
Liked: 5118
eng-399 is offline
post #15 of 43 Old 06-18-2015, 01:02 PM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
Between the concrete (ICF) construction, my sound containment efforts and the 1.5 football fields to the nearest neighbor.... that shouldn't be a problem.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #16 of 43 Old 06-29-2015, 06:38 AM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
For the Arcade Lobby area we have Red vs Blue!
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #17 of 43 Old 06-29-2015, 06:56 AM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
For the Theater and Lobby Colors I just took one of Sherwin-Williams HGTV Color Palettes and picked the colors I liked... "...exclusive color collections and paint designed for beautiful color transitions throughout your home." Ha, Color design for idiots.
The theater will be Tricorn Black for the Screen Wall and Ceiling. Well-Bred Brown for the Walls.
THe Lobby is Latte for the base color, Antique Red for the Red team and Indigo Batik for the Blue team.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #18 of 43 Old 06-29-2015, 07:53 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2732
Nice
Build
Mfusick is offline
post #19 of 43 Old 07-10-2015, 09:50 AM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
In-Wall Speaker Setup for Atmos 9.2.4.
Currently cut out for Definitive Technology UIW series with back boxes:
Fronts: 3 - Definitive Technology UIW RLS II
Wides: 2 - Definitive Technology UIW RCS III (In Front side columns with ante angles towards the seating position.)
Surrounds: 4 - Definitive Technology UIW RLS III
Atmos: 2 - DI 5.5R in-ceiling speakers (Wired for 4.)
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #20 of 43 Old 07-15-2015, 01:56 PM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
Black and Brown... First coat of paint
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #21 of 43 Old 07-15-2015, 09:29 PM
domz777's Avatar
Quoted: 77 Post(s)
Liked: 78
Will there be a Griffball machine?
domz777 is offline
post #22 of 43 Old 07-16-2015, 09:30 AM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
THere may be some Grifball played in there. Definitely lots of gaming... I hope... if we ever get it done.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #23 of 43 Old 07-24-2015, 06:22 AM
cdy2179's Avatar
Quoted: 916 Post(s)
Liked: 794
This is gonna be nice. Like Big was saying 16" only needs one step. Mine is 16" and I did just like he mentioned with a huge deep step. I really like the look of it. I'd say you could go 18" tall and be fine. You're room is almost identical to mine. Mine is 16x21'6" with 10'4" ceilings as well. Whats cool about that high of a riser and that ceiling height is even projecting a 170" picture at the proper height you can literally walk on the edge of the stage and not be close to the light path and it makes the room feel huge, even on the bottom row there is plenty of room to play kinetic or walk around and not be in it's path.
I've also owned the RLS2 inwalls. Probably one of my best consumer speakers, great choice. Great vocals and able to hit around -5db from reference. When I sold my last house and HT those were behind the screen.
cdy2179 is offline
post #24 of 43 Old 07-30-2015, 02:19 PM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
UPS says they just delivered most of my 9.2.2 Atmos setup from AV SCIENCE INC... (Minus the subs)
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #25 of 43 Old 08-27-2015, 01:36 PM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
With the painting done we have been working on flooring, tiling, doors and trim... but we started with the 2nd floor and are working our way down. So it may be a while yet before I have some more theater updates. .... SIGH...
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #26 of 43 Old 08-28-2015, 07:56 AM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
In fact I'm kicked out of the basement entirely for a few days while the finish drys.
We went with a stained concrete finish for the basement outside of the theater.
Daniel Chaves likes this.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #27 of 43 Old 08-28-2015, 08:14 AM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
While I wait I'm speculating on my eventual equipment list.
For the projector I'm playing the wait and see game. Will have to be something with lens memory for the scope screen zoom. Probably not 4K because of $$$.
I'm leaning towards a 120" Wide Scope Falcon Screen with their new Horizon AT fabric. That will make my 16x9 image about the same size as my current theater.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #28 of 43 Old 09-17-2015, 03:33 PM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
A Couple Pics of the stained concrete Floor in the Loby/Arcade.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #29 of 43 Old 03-04-2016, 03:25 PM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
Pictures of the tile work. I'll post more one I have things cleaned up.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #30 of 43 Old 03-04-2016, 04:03 PM
Daniel Chaves's Avatar
Quoted: 645 Post(s)
Liked: 514
lol at first I thought it was like rose pedals and you were trying to do something romantic for the lady... ^^;;
BllDo likes this.
Projector: BenQ w1500 + ES Sable 135" 16:9 Screen AVR: Marantz SR6011 ATMOS/DTSX + Unity 2ch Amp + Darbee 5000s Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), FXiA6 (SL/SR), Monitor40 Series II (RL/RR), TSx110B (Ceiling FL/FR RL/RR) LFE: (2) JL Audio 12" Subs + (2) Dayton 15" Subs + (2) ButtKicker LFE Arrangement: 7.1.4 Source: OPPO UDP-203 4k Bluray Player, HTPC, nVidia Shield TV Pro, Hauppauge OTA DVR
Daniel Chaves is offline
