What would you do? Starting over with a 19'x21'x9' dedicated room! - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #1 of 59 Old 08-23-2015, 05:55 PM - Thread Starter
JSKMDWK's Avatar
Quoted: 68 Post(s)
Liked: 65
My family recently moved into a new home that has a nice bonus room above the garage. It is similar to our last home theater, but slightly larger with the added bonus of a kitchenette, bathroom, and small office/media room off of it. The finished room has tan/beige walls, white ceiling, red tile in the kitchenette and bathroom floor, and gray tile on the counter. There is a small storage space at the end of the room with a crawl through entry. The left wall has a large window 110"x44" and the right wall has two large window bays 106"x40". Their are two HVAC supplies at the front of the room. There is easy attic access, from the closet in the office, that run the length of the room.
Take a look at these pictures and let me know your suggestions before I get started. The goal is a dedicated theater with a CIH screen and a 7.1.4 Atmos system. Seating will hopefully be for 11 if I can figure out how to do that many.
Carried over from previous systems will be a row of 5 Cinematech theater seats, source equipment (blu-ray, TiVo, Xbox 360), Monster Power conditioning, 4 JBL Synthesis HTPS400 subwoofers, 3 Sonance Cinema Select cabinets, and a pair of Sonance S623TR in-ceiling speakers. I have picked up the following used gear Middle Atlantic 40 space rack ($200 on Craigslist) and a Panasonic AE8000 projector ($800 on AVSForum). Other than that I am open to suggestions.
I need to determine the following:
  • Screen size
    Speaker configuration
    Seating distance
    Room theme
    Color scheme
    Acoustic treatments
    Anything I haven't though of yet
JSKMDWK
Name:	from left rear corner (3).jpg
ID:	903882   Click image for larger version
Name:	from left rear corner (2).jpg
ID:	903890   Click image for larger version
Name:	from left rear corner (1).jpg
ID:	903898   Click image for larger version
Name:	from front right corner (5).jpg
ID:	903906   Click image for larger version
Name:	from front right corner (4).jpg
Name:	from front right corner (3).jpg
ID:	903922   Click image for larger version
Name:	from front right corner (2).jpg
ID:	903930   Click image for larger version
Name:	from front right corner (1).jpg
ID:	903938   Click image for larger version
Name:	from front left corner (3).jpg
ID:	903946   Click image for larger version
Name:	from front left corner (2).jpg
Name:	from front left corner (1).jpg
ID:	903962   Click image for larger version
Name:	back of room.jpg
ID:	903970   Click image for larger version
Name:	Front of room.jpg
New theater build thread
Would I have stayed happy not knowing how good it could be? -- My first theater in print -- My first build- Mocha Theater Construction
JSKMDWK is offline
post #2 of 59 Old 08-23-2015, 07:03 PM
Quoted: 6032 Post(s)
Liked: 5618
I think I would downsize the kitchenette, keep the portion under the window but get rid of the eat at counter. Turn it into snack bar/wet bar. I would cut a niche for a Refrigerator by stealing space from the office.
I think that would allow you a little more breathing space for the second row of seating to hit that 11 goal , what is the distance from the front wall to the as is counter.
ambesolman likes this.
post #3 of 59 Old 08-23-2015, 08:32 PM - Thread Starter
JSKMDWK's Avatar
Quoted: 68 Post(s)
Liked: 65
Big,
Thanks for the quick response, I was hoping to hear from you. From the front wall to the counter is 164". I currently have the front (and only so far) row of seats slightly in front of the counter and have 11.5-12 feet from the front wall to eyeballs, depending on recline. I would like to keep the counter area as is and there is already a mini-fridge in the kitchenette.
I am thinking I could add a second row on a riser inline with the counter and maybe fit 4 seats on it. that would get me to seating for 9 and then others can use the floor or temporary seating when necessary. I should be able to keep a walkway from the entrance, behind the rise, past the office door, to the kitchenette this way.
thanks,
JSKMDWK
JSKMDWK is offline
post #4 of 59 Old 08-24-2015, 06:31 AM
Liked: 5618
130 to 144 inch wide 2.35
JSKMDWK likes this.
post #5 of 59 Old 08-24-2015, 10:56 AM - Thread Starter
JSKMDWK's Avatar
Quoted: 68 Post(s)
Liked: 65
I am considering a Falcon Vision Horizon 140" screen. I had a Falcon Vision HD 120" 2.35:1 screen in the previous theater and liked it a lot. It should match up well with the Panansonic 8000.
What do you think about doing a false wall at the front, maybe 18" off the current wall and then treat the front wall with 2" of Linacoustic?
I am considering adding a second pair of front speakers to do width channels, so LW, L, C, R, RW all behind the front wall with the L, C, R behind the screen. This way I can also put 2 or 3 of the subs behind the false wall.
thanks,
JSKMDWK
JSKMDWK is offline
post #6 of 59 Old 08-24-2015, 12:31 PM
Liked: 5618
Ask Rich for my AVS brothers discount. I am a supporter of false front walls if you have the room length and viewing distances to pull it off.
post #7 of 59 Old 08-24-2015, 07:17 PM
Nyal Mellor's Avatar
Quoted: 545 Post(s)
Liked: 385
Looks like a fun project.
Two rows of seats is going to be do-able but tight, especially with a big screen. You'll run into reduced headroom due to riser height required for sight lines and good viewing position for screen.
Don't go for a screen that is too big, check how much lumens output you are going to get out of it first (calibrated lumens NOT spec sheet)
If you are doing a false wall then fill that space with pink fluffy, don't bother with 2" linacoustic.
JSKMDWK likes this.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
post #8 of 59 Old 08-25-2015, 05:33 PM - Thread Starter
JSKMDWK's Avatar
Quoted: 68 Post(s)
Liked: 65
I have seen from 622 to 1175 lumens on the low end calibrated. If I do a 140" wide 2.35:1 screen, measurements are (140x59.6/144)x1175=20.3 ft/lamberts.
But if I use the 16x9 size (140x78.7/144)x1175=15.4 ft/lamberts, since I am zooming part of the image off of the screen when watching 2.35:1 is this the correct value?
The room will be light controlled and the screen gain is stated a unity, so 1.0.
I plan to do a 10" riser, so should still have 8+ ft above the floor when on the riser. The projector will be shelf mounted in the office firing through a small window, so should not be in the way.
Thoughts?
JSKMDWK is offline
post #9 of 59 Old 08-25-2015, 10:42 PM
lovingdvd's Avatar
Quoted: 3742 Post(s)
Liked: 905
JSKMDWK - You may want to check out LeBon's excellent thread build thread here https://www.avsforum.com/forum/19-ded...#post_23719000 for some ideas. From what I recall his room has nearly identical length and width to yours - can't recall what his ceiling height is.
JSKMDWK likes this.
lovingdvd is offline
post #10 of 59 Old 08-26-2015, 12:39 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2729
There is a lot of potential in this space. Could be a fun project.
JSKMDWK likes this.
Mfusick is offline
post #11 of 59 Old 08-27-2015, 10:37 AM - Thread Starter
JSKMDWK's Avatar
Quoted: 68 Post(s)
Liked: 65
Just read the entire thread and love the theater - design and equipment. Dimensions are very similar to mine within a few inches each way and I liked seeing his false wall. I will most likely go with a slightly smaller screen, sit a little closer, and do a second row seats on a riser (in the future). I plan to mimic the projector in my office at the back of the room and will have my gear in a separate closet in that office instead.
JSKMDWK is offline
post #12 of 59 Old 08-27-2015, 01:02 PM
Liked: 5618
Keep in mind that the brightness of the projector is reduced the further from the screen. You may want to check with one of the online image calculators.
rms8 likes this.
post #13 of 59 Old 08-27-2015, 09:07 PM
lovingdvd's Avatar
Liked: 905
A few questions so I can make some suggestions...What projector are you considering, are you going to do 2.35 or 16:9, acoustically transparent or not, and what's your desired seating distance for your prime seats?
post #14 of 59 Old 08-27-2015, 10:31 PM - Thread Starter
JSKMDWK's Avatar
Quoted: 68 Post(s)
Liked: 65
Already purchased Panasonic AE8000 projector.
Planning on 2.35:1 screen that is acoustically transparent - Falcon Vision Horizon.
Seating distance 10.5 ft. from screen to eyeballs when reclined.
thanks,
JSKMDWK
JSKMDWK is offline
post #15 of 59 Old 08-27-2015, 10:41 PM
lovingdvd's Avatar
Liked: 905
thanks,
JSKMDWK
I'm not too familiar with that pj. Please do a little digging and find out what the CALIBRATED lumens are at D65 for a 100% full field measurement and let me know here.
Also what is your preference for how close you like to sit? For example when you go to the movies is your ideal seat 1/3 from the front, half-way, rear, etc?
Based on this I can share my thoughts on what screen size would be best, taking into account the lumens of your pj and preferred field of view (which will be answered by my last question above).
post #16 of 59 Old 08-28-2015, 07:33 AM
Liked: 5618
I can tell you that the online calculators estimate 10 fl if the projector lens is 20 ft from the screen and the screen is a 120 inch wide 2.35 That is claimed brightness and probably a new bulb. Not calibrated. 12 fl is the recommended minimum.
it increases to 12 with the projector 18 ft from the screen.
post #17 of 59 Old 08-28-2015, 11:23 AM - Thread Starter
JSKMDWK's Avatar
Quoted: 68 Post(s)
Liked: 65
Doing some online checking I found the following:
PT-AE8000 Lumen Output and Color Temp with 100 IRE Field (mid zoom)
Cinema 1 643 @ 7053
Cinema 2 1175 @ 8554
Game 1245 @ 10199
Normal 1285 @ 9746
Dynamic 1898 @ 7757, 1255 lumens with AI off
Rec. 709 622 @ 6695
D-Cinema 643 @ 6437
- See more at: http://www.projectorreviews.com/pana....UGLaruiV.dpuf
Post Calibration: Best Mode = REC 709 The PT-AE8000 measured 602 lumens calibrated in “best” mode.
Light output. The spec on the AE8000 is 2400 lumens, which is a 20% increase over the AE7000's 2000-lumen rating. The spec understates the brightness differences we see on our test samples. Here, in table form, are the lumen readings we saw on our AE8000 compared to our AE7000 readings from last year:
Mode AE7000 AE8000
Cinema 1 526 822
Cinema 2 1089 1612
Game 1204 1673
Normal 1300 1752
Dynamic 1685 2471
Rec. 709 592 821
D-Cinema 544 872
We connected the AE8000U to Ray's calibration setup, which consisted of a Windows laptop running SpectraCal's calibration software, controlling both a calibrated signal pattern generator and my C6 meter. In order to check our work, we also had on hand a Konica Minolta CS-200. Out of the box and in the AE8000U's "Rec 709" image preset, we measured a solid 10.2 foot-lamberts from the projector. It should be noted that, because I employ an acoustically transparent screen, light readings are somewhat diminished - on average, between 15 and 20 percent - so on a non-acoustically transparent screen, you could reasonably expect a light output of, say, around 12 foot-lamberts. Again, not bad for a 120-inch screen.
Some contradiction in these 3 so I am leaning towards ceiling mounting the projector instead of back in the closet. Definitely want a bright image and would like to do a 140" wide 2.35:1 acoustically transparent screen, so maybe 17 feet back from the screen on the ceiling would work better than 20 feet back in a closet.
JSKMDWK is offline
post #18 of 59 Old 08-28-2015, 11:50 AM - Thread Starter
JSKMDWK's Avatar
Quoted: 68 Post(s)
Liked: 65
Then I read this -
There is a measured roughly 14% increase in brightness if you place the PT-AE8000U at its closest position to the screen, in terms of zoom (wide-angle), compared to having the zoom at mid-point, with the projector 50% further back.
At full telephoto the PT-AE8000 is about 40% less bright compared to wide angle! That means you are reducing this projector from very bright to about average brightness if you rear shelf mount at the full telephoto range.
- See more at: http://www.projectorreviews.com/pana....T8w29dPQ.dpuf
JSKMDWK is offline
post #19 of 59 Old 08-28-2015, 12:03 PM
lovingdvd's Avatar
Liked: 905
Once you factor in the negative gain of the AT screen and lamp aging your picture are going to be pretty dim at that screen size for 2.35 viewing. OTTOMH I will say ahead of my calculations that it will not likely provide enough brightness. I will do the calculations shortly and let you know what ftL I'd anticipate you'd get.
post #20 of 59 Old 08-28-2015, 01:53 PM
lovingdvd's Avatar
Liked: 905
JSKMDWK - Sorry to say but IMO there is no way you can do a 140" screen if you care about watching 2.35 material. Assuming 600 lumens to begin with based on your other post, and assuming 20% loss within the first few hundred hours leaves you with say 480 calibrated lumens. The Falcon screen has around a 0.85 gain (I've measured it) which is about average gain for other AT screens, only the Center Stage XD measures higher based on my measurements. Factor that together and it leaves you with 7 ftL. Even if you can mount where you can pick up another 15 or 20% you can see you will still be quite dim. Perhaps you won't mind in a totally light controlled room, as brightness is a personal and subjective thing. And to some they may not notice the difference between say 7 ftL and 12 ftL without an A/B comparison. I know for me I need at least 12 ftL and preferrably 15+ ftL.
Now the above is for 2.35. For 16:9 viewing I calculate you will be around 9.2 ftL, so still quite on the low side. And any 3D in these modes will be roughly half of those numbers.
At 130" wide 2.35 you'd be around 8 ftL and in 16:9 around 10.7 ftL. That's a bit better but still low IMO. At 120" wide 2.35 you'd be around 9.3 ftL and in 2.35 around 12.41 ftL. So IMO its takes about 120" before you are at a good marker for 16:9 but still low on 2.35. If you tend to watch a lot of 16:9 that may work for you, if its the other way around then it may not.
Possible considerations:
- maximum of around 120" wide 2.35 screen, and sitting closer to try and get the same immersive effect. Note that sitting closer to woven screens you want to test it with your own eyes with a sample to make sure you can't see the screen texture.
- going with a NON-acoustically transparent screen that has gain of 1.3. This will effectively give you a 50% boost in brightness. Of course this has implications for the rest of your room both aesthetically and performance wise - trade offs are everywhere but having built a room already you know this.
- going with a different projector, like the Sony VW600 which will give you around 1,500 lumens, roughly doubling all the ftL numbers listed above. Its also rumored that the new JVCs models for later this year will have lumens approaching 1,500 (maybe more, maybe less, just rumors at the moment). The entry model may be considerably less than the Sony VW600 (or its upcoming replacement) so you may want to wait and see what's coming.
Any questions, let me know. Hope this helps!
post #21 of 59 Old 09-03-2015, 08:32 PM - Thread Starter
JSKMDWK's Avatar
Quoted: 68 Post(s)
Liked: 65
Well, I only want to buy the screen once, and I know I like a large image when watching scope movies. So, what do you think of this approach? I buy the biggest screen that could be considered - say 150" wide 2.35:1 and put it up. I try out the picture at different sizes and with different modes on the projector until I find the one I am happy with. I then build the all black false front wall in front of the screen with just the appropriate size opening. This way I put the screen just behind the plane of the false wall. Down the road if I change projectors I can resize the panels surrounding the screen to get a larger image. Thoughts?
JSKMDWK is offline
post #22 of 59 Old 09-03-2015, 11:11 PM
lovingdvd's Avatar
Liked: 905
I like the idea in principle. It may be a little tricky constructing it in such a way that your permanent masking looks like a frame due to the depth of the other frame. But if you have a plan for how to pull this off cosmetically I think that could work. Oh, wait - if I recall you wanted an AT screen. Well you will need to find a way to make sure your masking is acoustically transparent.
Its funny that you mentioned this because I meant to say in my post that sometimes it is good to go bigger with the future in mind. For example, projectors are just getting brighter and brighter. So what's not doable now at a large screen size may be totally doable a few years down the road. So I think you have the right idea.
post #23 of 59 Old 09-11-2015, 03:03 PM - Thread Starter
JSKMDWK's Avatar
Quoted: 68 Post(s)
Liked: 65
Still debating about the screen size, so in the mean time I have started experimenting with the front stage. I had three of the Sonance Cinema Select Cabinet speakers and picked up another used pair along with 6 matching stands from Craigslist, remember, trying to do this on the cheap. I like the width of the soundstage and plan to run the wides off of Audyssey DSX until I get an Atmos processor.
The blue tape around the 60" plasma represent three sizes of screens - 100" diagonal 16x9 (too small), 120" wide 2.35:1 (same as previous theater), and 140" wide 2.35:1 (biggest I am currently considering). The front wall will be built out 18" to conceal the speakers and the seating distance (eyes to screen) will be about 10'. Let me know what you think.
Name:	front sound stage.jpg
JSKMDWK is offline
post #24 of 59 Old 09-11-2015, 04:52 PM
Liked: 5618
You have it pretty high, be sure to imagine it lower, it will look smaller/
Name:	front sound stage with screen.jpg
post #25 of 59 Old 09-11-2015, 05:20 PM - Thread Starter
JSKMDWK's Avatar
Quoted: 68 Post(s)
Liked: 65
Yes, the plan is to keep the bottom of the screen at the same level as the top of, or just below, the speaker stands. Should be about 29" above the floor.
JSKMDWK is offline
post #26 of 59 Old 09-11-2015, 05:48 PM
Liked: 5618
If the front row is your main row I wouldn't go much bigger than 130. pull those chairs up to that distance in your room and look at the blue tape.
post #27 of 59 Old 12-01-2015, 09:35 PM - Thread Starter
JSKMDWK's Avatar
Quoted: 68 Post(s)
Liked: 65
Finally got a screen. Found a good deal on a used Stewart FireHawk Gen 3 non-perforated screen that is 120" wide, 2.35:1 ratio, 130" diagonal. The smaller size, more gain, and non-AT should help increase brightness. Will let everyone know how it goes once I get everything mounted up.
JSKMDWK is offline
post #28 of 59 Old 12-02-2015, 06:26 AM
rms8's Avatar
Quoted: 516 Post(s)
Liked: 362
Like Big mentioned above, keep the projector as close to the screen as possible.
After I was 90% finished with my HT project I was ready to mount the pro. I simply turned the pro on, and backed the zoom all the way out to get the largest picture (ie, all the light the pro can give). I fired this on the screen and then moved the pro back-n-forth until I could fill the screen. That is where I mounted the pro. It sits roughly 14' from the screen. This placed the projector above the 1st row, but due to the 10' ceiling and the ultra quiet fans Sony projectors are known for, the projector disappears. My screen is 135" wide. It's a 16x9, so it's on the large side, but easily lit up by my 55ES.
rms8 is offline
post #29 of 59 Old 12-02-2015, 08:56 AM
damelon's Avatar
Liked: 347
This is all true, but also don't forget the caveat of the requirements to use the projector's zoom. It isn't just how close the projector can be, but its height relative to the screen, so that the zoom will work. (Since he is using a scope format)
damelon is offline
post #30 of 59 Old 01-08-2016, 11:02 AM - Thread Starter
JSKMDWK's Avatar
Quoted: 68 Post(s)
Liked: 65
I made some progress over the holidays!
Mounted the 130" 2.35 Stewart Filmscreen FireHawk Gen 3 screen that I picked up used in So. Cal.
Installed 2 of the 3 sets of black out curtains.
Mounted the Panasonic projector and Peerless mount to the ceiling.
Cut the holes for the front set of Atmos speakers, matching Sonance Cinema S623R. Same as the rear Atmos speakers.
Purchased, but have not yet installed the Sonance Cinema LCR for sides and rears. - eBay
Purchased used Middle Atlantic rack w shelves. - Craigslist
Purchased used Marantz AV7702 pre-amp. - Craigslist
Purchased used Marantz MM8077 amplifier, looking for a second one now. - eBay
Removed the ceiling fan.
Here is a shot of the front wall. I have decide to hold off on the false wall for now.
Name:	front w screen.jpg
Pacific Breeze likes this.
JSKMDWK is offline
acoustic treatment , design , Home Theater , new room , projector
