Edmonton AB area, linacoustic OUCH! Alternatives? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 03-07-2016, 08:39 AM - Thread Starter
Gouie's Avatar
Quoted: 403 Post(s)
Liked: 276
I'd be interested in hearing from others in the Edmonton, Alberta area regarding your sound absorption material of choice. I've called all of the local drywall and HVAC resellers that I could find in the area and quotes on Linacoustic are really stinging; 1" $1.30/square foot, 2" $2.81 square foot is the best that I could find. I'll start the call process over again looking for Owens but am curious what others have gravitated to. Roxul might be a good alternative but the only stuff I've been able to source is something they're calling Roxul R6 Comfortboard IS, not the Roxul 60 that is commonly referenced here.
Gouie is offline
post #2 of 17 Old 03-07-2016, 11:18 AM - Thread Starter
Gouie's Avatar
Quoted: 403 Post(s)
Liked: 276
So, I was able to find a source that can bring the Lineacoustic in for 70 cents per foot. Still a little pricy but I can live with that. Being that the material comes in a roll I wonder how stiff can it be? Are folks using this for reflection treatments as well as behind the screen? Seems it would be difficult to mane panels out of it if it isn't as rigid as say the Owens product.
Gouie is offline
post #3 of 17 Old 03-07-2016, 12:11 PM
Quoted: 5849 Post(s)
Liked: 5420
I pay about 40 cents a foot and buy it direct from an insulation supply house. Probably the same kind of place your HVAC companies get theirs.
it is not really all that stiff and for panels in needs to be surrounded by frames or on wall furring.
post #4 of 17 Old 03-07-2016, 12:46 PM
Waterboy77's Avatar
Quoted: 604 Post(s)
Liked: 315
http://www.crossroadsci.com/HVAC/Products.aspx#lina
JM references these guys on their partners listing...... I haven't reached out for pricing yet
One day I will start the new theater....... one day..... THAT DAY HAS ARRIVED
"If the women don't find you handsome, they should at least find you handy." Red Green
Family Cave Theater
Automation Thoughts/ Questions
Waterboy77 is offline
post #5 of 17 Old 03-07-2016, 01:20 PM - Thread Starter
Gouie's Avatar
Quoted: 403 Post(s)
Liked: 276
That helps Big (I feel like I should know your name by now) thank you. I haven't figured out my approach just yet but this will help.
As far as price goes that's closer than it may seem; Canadian conversion is not very forgiving.
Gouie is offline
post #6 of 17 Old 03-08-2016, 09:52 AM
blipszyc's Avatar
Quoted: 153 Post(s)
Liked: 79
I used an OC product called Rotary Liner. Don't recall the pricing, but I remember it was cheaper than Linacoustic in my area.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
4.0 - TBD
blipszyc is offline
post #7 of 17 Old 04-28-2016, 12:40 PM
Blacklightning's Avatar
Quoted: 998 Post(s)
Liked: 855
I don't know if you are still looking but I'm going to be using this stuff for my panels. You can get OC703 from a company in Spruce Grove/Stony plain @ $107 for 6 panels of 2". I can bet you that for twice the price you will not hear a difference. Since the Roxul R6 is 1.5" think I'm going to double it up and make 3" panels on the sides.
One thing that I might do and post measurements hear is buy 4 full packs of this stuff and stack them in my 2 front corners and see how much it helps bass. I can return the unopened packs after I do the test.
Blacklightning is offline
post #8 of 17 Old 04-28-2016, 01:45 PM - Thread Starter
Gouie's Avatar
Quoted: 403 Post(s)
Liked: 276
Thanks for that. I did find some Lineacoustic at a local distributor but will be looking for 703 for my treatments when I get there. Mind if I PM you for the name of the company?
Gouie is offline
post #9 of 17 Old 04-28-2016, 02:18 PM
Waterboy77's Avatar
Quoted: 604 Post(s)
Liked: 315
Where did you find the linacoustic in Alberta?
Family Cave Theater
post #10 of 17 Old 04-29-2016, 10:30 AM - Thread Starter
Gouie's Avatar
Quoted: 403 Post(s)
Liked: 276
PM sent. Although it's not Johns Manville, essentially the same stuff.
Gouie is offline
post #11 of 17 Old 06-28-2019, 04:25 PM
Liked: 1
Attachment 1413090
Hi Gouie,
Am in Calgary and am nearing the point of needing this. Where did you source this? Thx
ordinarybanter is offline
post #12 of 17 Old 06-29-2019, 08:29 AM - Thread Starter
Gouie's Avatar
Quoted: 403 Post(s)
Liked: 276
I picked it up at Ecco heating products in the west end of Edmonton.
Gouie is offline
post #13 of 17 Old 06-30-2019, 10:37 PM
Liked: 1
Ok thanks! I'll look them up.
Cheers
post #14 of 17 Old 07-02-2019, 08:59 AM
Helheim's Avatar
Quoted: 30 Post(s)
Liked: 59
Cheers
I got Linacoustic RC from www.crossroadsci.com in Calgary but it wasn't cheap.
Helheim is offline
post #15 of 17 Old 07-25-2019, 07:43 PM
Liked: 1
OK. did you get 1" and a roll of it for your stage wall?
post #16 of 17 Old 07-25-2019, 08:34 PM
Helheim's Avatar
Quoted: 30 Post(s)
Liked: 59
Two layers on the stage wall, lined return duct and made duct mufflers with it.
Helheim is offline
post #17 of 17 Old 07-28-2019, 10:04 AM
Liked: 1
Thx. I've contacted them. I'm following your thread with interest. Nice to have a local person and see how they are doing it.
