Recessed Canned Lighting recommendations - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #1 of 37 Old 04-18-2016, 09:20 AM - Thread Starter
Liked: 0
Hi I am looking for what others have possibly used for recessed canned lighting in there rooms? There are so many choices of course and I know many of them will not be best for a theater room.
I am trying to avoid the lessons learned option of canned lighting. I am also open to other types of lighting if you feel canned lighting should just be avoided.
If you could post some recommendations of what is working for you that would be super helpful.
WickedShark is offline
post #2 of 37 Old 04-18-2016, 07:26 PM
BlowinSno's Avatar
I am just about to install these. I bought the white ones and spray painted the rings, as they come off easy enough.
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
Still haven't decided the bulb, although will prob be LED. I chose these due size, cost and functional; gimbal design.
Best of luck!
-=Kirt
BlowinSno is offline
post #3 of 37 Old 04-18-2016, 09:32 PM - Thread Starter
Liked: 0
Best of luck!
-=Kirt
Thanks did you do any sound proofing like DDW, channels, or clips? If so will these still be easy to install? Should you use a backer box (think that is what they are called) at all with lights like these?
post #4 of 37 Old 04-18-2016, 11:28 PM
BlowinSno's Avatar
Floor and the walls and prit near everything else, sans the ceiling. I am building some sound proofing boxes around them, to also keep out of the insulation.
post #5 of 37 Old 04-19-2016, 06:18 AM
Tedd's Avatar
Quoted: 2250 Post(s)
Liked: 962
You might be surprised at what can work for a home theater, lighting-wise.
Art Install really pushes the bar.
http://www.artinstall.ru/en/
So maybe there's room to be creative, and let the décor push the lighting?
Tedd is offline
post #6 of 37 Old 04-19-2016, 08:46 AM
Quoted: 6177 Post(s)
Liked: 5870
my guide to recessed lights.
I've used these, see Bacon Race:
http://www.lowes.com/pd_16059-47842-...&Ntt=utilitech
-- throw away the halogen bulb, get a SunSun LED MR16 GU10 bulb. Be prepared for a very difficult wiring task as the junction box is tiny. They are probably the smallest diameter of the the lights I've used.
I've installed about 100 of these:
http://www.lowes.com/pd_289424-53058...itech+recessed
-throw away the bulb, larger junction box
I just tried these and they are a cheaper version of the above, large junction box. cheap in the contractor pack, bring your own LED bulbs. I think the Lowes version bulb swivel mount is better.
http://www.amazon.com/Globe-Electric...essed+lighting
I just bought one of these to test and it you have limited headroom get them, comes with an LED bulb. The can is only 2 3/4 tall. That is remarkable and it is rated IC.
http://www.homedepot.com/p/BAZZ-Flex...PL7W/204722808
You will note that all of these are remodel cans, put the wires in place, drywall the ceiling, cut a hole reach up and grab the wire, attach and push up into the hole.
acras13 and kaiforce like this.
post #7 of 37 Old 04-19-2016, 10:02 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2731
Strong post ^
Mfusick is offline
post #8 of 37 Old 04-19-2016, 10:10 AM
nathanddrews's Avatar
Quoted: 629 Post(s)
Liked: 648
I'm going to piggyback/hijack this thread. We recently became obsessed with Philips Hue bulbs... but they don't seem to make any color bulbs small enough to fit into shallow cans. Any ideas?
nathanddrews is offline
post #9 of 37 Old 04-19-2016, 12:43 PM
Liked: 5870
google "6 inch remodel recessed lights" , you will find plenty of options. At that size you usually have to buy the can and a baffle separately. Take one of your bulbs and walk into Home depot and try a few cans on for size.
post #10 of 37 Old 04-19-2016, 04:26 PM - Thread Starter
Liked: 0
Strong post ^
I agree that was a super valuable post of information with a ton of options to investigate. The only other question I had is will any of these or should I install any of these options into sound proofing or minimizing backer boxes?
post #11 of 37 Old 04-19-2016, 05:21 PM
Liked: 5870
Anytime you cut a hole in a drywall sound isolation bunker you need to think about the consequences. It is possible to design a theater without any holes for outlets, switches and recessed lighting. If you cut holes they need to be addressed. You can put lights in a perimeter soffit built inside the drywall shell.
post #12 of 37 Old 04-21-2016, 12:01 AM - Thread Starter
Liked: 0
Why we are on the subject of lighting I am also looking for Warm LED dimmable rope light. I see some rope lighting used in some Big's builds, but are they LED lights? I can hardwire or I can have an outlet installed that is switched for dimming.
post #13 of 37 Old 04-21-2016, 06:47 AM
Liked: 5870
the biggest problems with LED rope is making sure about it's dimming capability and dealing with the transformer that is required. You can overcome both ot theses issues. You just need to plan where to tuck the transformer (size varies) and get some recommendations on which rope will dim properly. It has been awhile since I've used an LED rope so I can't recall a particular model. Over the years I've had good luck with Bird Dog distributing as my source and you could call them. This product may work I have no hands on with it: http://www.birddogdistributing.com/B...5ft-Spool.html
Some ropes are directional and you have to rotate the rope so it casts the light the way you want.
post #14 of 37 Old 04-22-2016, 02:49 PM
TheNecromancer's Avatar
Quoted: 185 Post(s)
Liked: 29
Big, I was hoping to do a recessed light system in my perimeter sofit. These that you linked would be perfect. I'm planning on clips, GG and OSB /DW. What is the best way to try to soundproof these? Backer boxes I'm guessing? Are backer boxes pre-made?
I have a basement room with a 10" sofit framework. It's hard mounted to the ceiling joists.
Steve
TheNecromancer is offline
post #15 of 37 Old 04-22-2016, 03:56 PM
Liked: 5870
the best way to soundproof lights in a soffit, is to build the soffit inside the drywall shell. If that train has left the station the next best approach is to use backer boxes. You can make your own or buy premade ones if they fit in your framing. After that, the last option is to put the bottom on the soffit first, install the lights and coat the backs of the lights with putty pads or Dynamat Extreme or Equiv.
Pre Made: http://isostore.com/shop/product/qui...soundproofing/
post #16 of 37 Old 04-23-2016, 09:40 PM
Quoted: 185 Post(s)
Liked: 29
Thanks Jeff!
post #17 of 37 Old 04-24-2016, 08:25 AM
Quoted: 185 Post(s)
Liked: 29
I'm planning a small theater room and looking for some advice on lighting. The room is 12'6 x 18'. It has a perimeter sofit in which I had planned 10 canister lights, 3 per side and 2 in front and 2 in back. These would be the smaller 4" round cans. I was also considering 4 wall sconces, 1 per column. Both would be on separate switches and both would be dimmable.
Is this to much for a small room? How much light do get from the 4" cans?
post #18 of 37 Old 04-24-2016, 01:20 PM
Gouie's Avatar
Quoted: 469 Post(s)
Liked: 383
Popped into Costco today and came across these. 4" IC and roughly 4" high 3000k and gimbal . For us Canadians this is a very good price at $26. I bought 16, will try tonight.
Gouie is offline
post #19 of 37 Old 04-24-2016, 03:11 PM
Tedd's Avatar
Liked: 962
If that is a black cave of a room, that might just equate to adequate lighting for cleaning the theater. The fact you have two zones, and they are dimmable, means you won't have too much light.
If anything I'd be considering more zones, to add more lighting flexibility. Some people like a little bit of light in the back of the room (not me) , so you might not want those front sconces to light up while having the rears on.
You also might want to consider ceiling height and beam spread, and how much lighting does the combination of the two, give you?
Tedd is offline
post #20 of 37 Old 04-24-2016, 04:18 PM
Quoted: 185 Post(s)
Liked: 29
The room has no windows, so very dark. The ceiling height is 8'. As far as the beam width I assume you're referring to the light being projected down? If so, I'm uncertain. I was planning to use an LED bulb.
I guess if anything it wouldn't be to much light.
post #21 of 37 Old 04-24-2016, 06:25 PM
hobsocc7's Avatar
Quoted: 85 Post(s)
Liked: 57
Big has some great photos on connecting the backer boxes to clips and channel if your following that route.
I got some Amazon remodeled LED can lights and I am following the guide at the sound proofing company.
I can send you some pictures if you want since I'm currently constructing them.
Sent from my Nexus 6P using Tapatalk
hobsocc7 is offline
post #22 of 37 Old 04-25-2016, 07:28 AM
Fezmid's Avatar
Quoted: 26 Post(s)
Do you need to build backer boxes for the 4" lights? I assumed the answer was yes, but when I was asking Ted some questions, he said the 4" LED lights don't require a backer box... Is it the case of "it's better to do it, but not required?" This assumes a standard clips/channel, DD/GG setup.
Fezmid is offline
post #23 of 37 Old 04-25-2016, 07:37 AM
Liked: 5870
I know that Ted has recently been vocal on that point, that with the size of the 4 inch hole AND if you use an Air Tight, IC rated can and surround it with insulation you may not need the backer boxes. Next theater I build for myself, I'm only doing the ceiling and soffits once, I will use backer boxes. Most of the small Remodel can lights discussed in this thread so far are not Air Tight. The air tight versions are new work versions. You pick your own path on this journey.
Fezmid, WickedShark and Tedd like this.
post #24 of 37 Old 04-25-2016, 08:22 AM
ddigler's Avatar
Quoted: 1114 Post(s)
Liked: 498
Yep, Ted had mentioned to me that 4" dia cans don't require backers with enough insulation behind them. However I'm working too hard at the soundproofing to skimp here... Makes me want to cry but I'm building boxes for all my recessed lights (approx 20).
ddigler is offline
post #25 of 37 Old 04-25-2016, 06:42 PM
Tedd's Avatar
Liked: 962
Beam spread is the circle of light, the bulb produces. And the lower the ceiling, the smaller that circle will become.
Room finishes can have a big impact on just how dark the room is, even with lighting on full. An all black room will suck up light, and you need a well lit room for cleaning.
Tedd is offline
post #26 of 37 Old 08-02-2016, 09:26 PM
Fezmid's Avatar
Quoted: 26 Post(s)
So I see Big recommends either the Lowe's or the Amazon lights. The ones from Amazon say they're IC-rated if you use an LED bulb, whereas the Lowes ones say non-IC with no caveats listed. Is it safe to assume that they're both IC rated with LED bulbs or is that an unsafe assumption? I ask because the SIM that Ted at Soundproofingcompany puts out says to put some insulation in the box to help reduce resonance. My understanding is that you can't do that unless the light is rated IC, so... Does that mean the Amazon lights are the recommendation here? Or is the insulation in the backer box overrated?
Fezmid is offline
post #27 of 37 Old 08-08-2016, 12:21 AM
acras13's Avatar
Quoted: 322 Post(s)
Liked: 306
No, it is not safe to assume you can put insulation in contact with the non IC rated can . By code , you can not. Will it be an issue? Lets say I have seen plenty of non-IC rated cans burried in insulation , and sometimes with bulbs that are a higher wattage than rated , and they havent burned the houses down . LED lamps are much cooler running , but I still wouldn't use the non-IC housings with insulation , but I'm a trained professional.
Turn that $*!# UP!! --Beethoven
acras13 is offline
post #28 of 37 Old 08-09-2016, 04:56 PM
Wayne A. Pflughaupt's Avatar
Quoted: 468 Post(s)
Liked: 390
I’ll add, make sure you go with an airtight can. The ones shown with holes in the cans will suck in all kinds of dust into the room if you have central A/C. You could get away with regular cans if you build a soundproof box around them, but make sure it’s sealed air tight as well.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #29 of 37 Old 08-19-2016, 10:07 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2731
You guys using the cans and lights are one ? Or buying the cans and then inserting the light/trim? advantage to either way ?
Mfusick is offline
post #30 of 37 Old 08-19-2016, 10:13 AM
Liked: 5870
generally contractor multi packs of cans and trims will be cheaper.
