Acoustical Treatments Master Thread - Page 413 - AVS Forum | Home Theater Discussions And Reviews
 430Likes
post #12361 of 12724 Old 03-30-2019, 07:01 AM
bpape's Avatar
Send a message via AIM to bpape
In pro applications Duvetyne is used. Velvet pretty much always has some sort of 'sheen' to it.
thegeek likes this.
I am serious...and don't call me Shirley.
Owner - Sensible Sound Solutions
bpape is offline
post #12362 of 12724 Old 04-06-2019, 10:36 AM
asarose247's Avatar
Quoted: 1342 Post(s)
Liked: 1180
TY, in anticipation, I have a rather large piece of the D for future ceiling application.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #12363 of 12724 Old 04-06-2019, 12:07 PM
asarose247's Avatar
Liked: 1180
some "not quite scientific" but pics of some reflective(?) darkening(?) absorptive properties of
royalty velvet#3 on the hanging from top left
duventyne , standard, on the right, similarly
the bottom triangle piece showing thru is black speaker cloth on the face of this mobile and "tunable" 1st reflection pt. panel.
the object is to get the ceiling in the mancave blacked out even more
duventyne is an industrial go-to
any comments appreciated, PM's good too
pics taken under obvious lighting differences
ID:	2549742   Click image for larger version
ID:	2549744   Click image for larger version
thegeek and OJ Bartley like this.
post #12364 of 12724 Old 04-06-2019, 12:15 PM
thegeek's Avatar
Quoted: 39 Post(s)
Liked: 29
Wow it's not even a contest here as the duvetyne looks like a medium gray next to the velvet. What was your source for this exact velvet?
Sent from my VS996 using Tapatalk
thegeek is offline
post #12365 of 12724 Old 04-06-2019, 12:33 PM
asarose247's Avatar
Liked: 1180
^ that is Jo-anns royalty velvet #3 ,
now i'm wondering if I should return the d'tyne to amazon
if you sign up for coupons from Jo-anns, you can save a bundle , takes some timing and lurking
i intend to use a spray / fabric / elmers glue/ adhesive to get the material attached to my 3/16ths ply
TY
thegeek likes this.
post #12366 of 12724 Old 04-08-2019, 08:19 AM
Quoted: 21 Post(s)
Liked: 2
7.1.4 treatment design
Hi all. I am just getting in to the design stage of a 7.1.4 surround room. It has issues (don't they all) such as windows that I will have to treat. Below are some renderings I have done of my plan and a photo of the current room.
The plan will be to treat the 1st reflection points to the greatest degree possible, or practical while maintaining something that looks fairly good. One question I have is what thickness/product to use for 1st reflections. Should I treat reflections for surround and atmos speakers differently than the front and center ones? My plan was to use 2" 703 at all points, though if that is overkill I would rethink.
I will be using Bass traps at the corners, though I have not settled on how thoroughly that will be done. Currently I think floor to ceiling traps with a 2 foot face, probably OC 703.
For the render below, the blue squares show the 1st reflection points for all speakers at the left, right, and center seating positions on the couch. Obviously, there are a lot of positions to cover. I would not just treat the little squares, instead, those would be my focus areas for 2x2 or larger panels.
Please let me know what your thoughts are.
Name:	Craftsman bedroom_media room.jpg
ID:	2550414   Click image for larger version
Name:	Media Room 1st Reflections.png
ID:	2550416   Click image for larger version
Name:	Bass Trap Design 1.png
DeruDog is offline
post #12367 of 12724 Old 04-08-2019, 08:48 AM
sdurani's Avatar
Quoted: 7885 Post(s)
Liked: 7079
The problem with using thin absorbers is that they absorb mostly mid to high frequencies and not much in the lower frequencies, which turns them into elaborate tone controls rather than broadband absorption. 2" OC703 is good down to about 300-400 Hz. For broadband absorption, you'd need 6" on the wall or 4" spaced 4" from the wall (4" air gap). I would start with absorption on the front and back walls, since sounds from those directions can muddy the soundstage. Sounds reflecting off the side walls are outside the front soundstage and aid in spaciousness, so absorbing those reflections is optional.
Sanjay
sdurani is offline
post #12368 of 12724 Old 04-08-2019, 02:32 PM
asarose247's Avatar
Liked: 1180
Hth
Name:	Acoustic treatment material plus airgap explain.jpg
post #12369 of 12724 Old 04-08-2019, 08:59 PM
asarose247's Avatar
Liked: 1180
@thegeek
grinding relentless ever onward . . .
suppose .. .
as of today, the Joanns is 13.99 yd, on line order, 44" wide
however, amazon :Ben Textiles Royal Velvet Black Fabric by The Yard 58" wide, 8.60 /yd- 30% mol wider , bout 30% cheaper
now there is stretchy velvet for lower prices but the concept of stretchy would require more secure mounting
and possible glue burn-thru and a ability for "unstretched / un stressed application, to a supporting backing, I would presume.
I have a Walmart near me, (but then again who doesn't?) so I may take one for the team and get a sample if they have something that looks feasible . . .
I am however returning the D'tyne to Amazon.
I probably need about 11 sq. yds for the room so looking to avoid really overthinking this . .
I'll take some more pics . .
post #12370 of 12724 Old 04-09-2019, 03:51 AM
thegeek's Avatar
Quoted: 39 Post(s)
Liked: 29
A long time ago I was reading an article about Experimental Aircraft, aka kit planes. There are very dedicated hobbiests who construct their own personal airplanes from kits and plans. The author of this article was interviewing one of them and asked how much it costs to build one and the builder stated pointing at different pieces of their aircraft while quoting hours to build, not dollars. For them the real cost was time.
Back then I thought this was odd, but now I have a truer understanding of that man's mindset.
My build thead was started in 2006 and I'm still not done. Life happened between then and now and any time on this project is time that's not spent elsewhere. Other hobbies have shown up old hobbies have reappeared, many other projects came before me and we're slain, three children were born and the youngest is now 6. We live in Central Florida and let's just say our kids are experts at theme parks. I sank months into their rooms. Two of their rooms are murals that I've hand painted, one has a room that's almost completely trimwork. Career just won't stay in its spot and keeps crossing the line into personal time...
Time is my true cost and the family wants this thing done. I'm at the point where I don't care anymore, but it's been no compromises so I'm not letting up. I've recently swapped over the speaker choice from the Martin Logans that have been waiting in the closet for ten freakin' years to DIY SG speakers behind an AT screen. I've seen the light on planars and ribbons, and the answer is "no". As a system they're just plain better for theater use being listened to by multiple people in an actual room. It's costing me a few months of my spare time but it will be better in the end as dipoles were a dumb choice on my part. I am customizing then to my exact use, something I'd be crazy to do with a Klipsch Ultra2 setup. It's still costing me a bundle of time though.
There are things I can build cheaper and I can squeeze costs out of, but hemming and hawing on the precise fabrics for a possible slight difference in cost with the Walmart choice versus the Joanne's probably isn't a big difference. Maybe one really is better? When evaluated in terms of time the Joanne's fabric looks like it's really good, and easily sourced by ordering online. You've done me a great service in evaluating velvet versus duvetyne, but spending a few hours at taking a swing at a chance of trimming $20 might not be a good trade-off. I get it as this sure isn't a cheap hobby, but money isn't the only price we pay for what we want to have.
DRC3 likes this.
thegeek is offline
post #12371 of 12724 Old 04-09-2019, 12:58 PM
asarose247's Avatar
Liked: 1180
your logic is unassailable -
the difference is about $0.50 / ft^2, and this is for about 100 ft^2 max.
and I already own a few yards . .of the velvet
the returned d'tyne will be about $40
$50 after what I've already spent-?
I've given away many times that in an effort to clear (just didn't cut it) things out
TIME is the most expensive factor.
I'll keep watching Joanns and once I get an MO for sizing the panels I'll attach to the stringers, then it's a go
Seems like a Cutsheet puzzle . .
mantra: You're not done yet
TY
post #12372 of 12724 Old 04-09-2019, 01:50 PM
jcmccorm's Avatar
Quoted: 640 Post(s)
Liked: 495
Off topic a bit, just chiming in to say that your post was well stated, start to finish. At 54 years old, and being a grandpa now, that stuff hits home (hobbies coming and going, kids, work, life, etc.)
I like to shave a buck where I can like the rest of us. Sometime it's ok to spend extra time though. I actually enjoyed putting speakers together and building my own room treatments. That's *my* time that I enjoy. Some things though I don't waste time with. And what a coincidence, one of those things was the fabric for treatments. I went with GoM. It wasn't cheap, but it looks good and works.
I've got a good buddy who's one of those guys that built his own plane (he's taken me up in it a few times). You're right, it's time. Of course, he can't count the dollars or he'd make himself ill.
I grew up in Central Florida too; Casselberry. Me and The Mouse are old friends
What DIYSG speakers did you decide on? I did HTM-12's myself.
asarose247 likes this.
jcmccorm is online now
post #12373 of 12724 Old 04-14-2019, 01:46 PM
kgveteran's Avatar
Quoted: 967 Post(s)
Liked: 281
For my 7.1.4 room i did 4”OC703 on the ceiling for the FRP for LCR LS RS, I couldn’t get the RB LB done because of the projector placement.
The sidewalls are 10” fluffy OC. The corners are 2’x2’x8’ superchunk fluffy pink OC
The remaining parallel walls have Diffusers, they are wooden DIY along with acouple skyline (also diy). No flutter echo in my room
I left the Atmos alone, they are hanging svs prime satillites......
The room will sound very different which is why people will say it sounds “Dead”, NO it sounds treated LOL not an echo chamber :0)
My backwall is actually a 600lb acoustic door i designed and built, it has 4”OC in it, yup 600lbsPlus
And the BR and BL are on rollers so the door can be put into place :0) CrazyRoom
Good luck and have fun
**HT Build https://www.avsforum.com/forum/19-ded...-door-0-a.html **
kgveteran is offline
post #12374 of 12724 Old 04-14-2019, 11:19 PM
ComradeBrehznev's Avatar
Quoted: 45 Post(s)
Liked: 30
I personally would not worry about treating the surround and Atmos speakers. You do want *some* liveliness in the room after all. For some ideas feel free to flip through my construction photos. I have GIC bass traps behind the main L/R and GIC panels on the side walls and ceiling. Cheers https://www.blu-ray.com/community/gallery.php?u=245268
ComradeBrehznev
Oppo UDP203, Epson 5040UB; VApex 120" screen converted to AT with Seymour Center Stage XD material, Marantz SR6011 receiver, Emotiva XPA-2 for FR & FL
SVS Ultra Towers, SVS Ultra Bookshelf center, SVS Elevation Atmos ceiling, SVS PB12-NSD, SVS PB-2000 subs; Emotiva side surrounds, Aperion 4BP backs
ComradeBrehznev is offline
post #12375 of 12724 Old 04-25-2019, 04:45 PM
asarose247's Avatar
Liked: 1180
@thegeek , @Marc Alexander
The rabbit hole may much bigger than we dare allow ourselves to fear-
Here's hope - maybe not so much from me
The Chase for LESS light at the end of the tunnel . .
the bit of comparative , dare I say instead – darknessing (capability)
check back a few post to the 1st set of pics, slightly different lighting
these
on the right – Royalty velvet #3 same piece
left is relatively less expensive, black velvet sample I thought looked promising, from Amazon vendor. it's back is way much stiffer-
not the slight give of the fabric- possible plus
and sitting here looking thru the backs at the TV, by holding it up in front of me the new stuff
So I just draped them over the TV. 1st is the #3 , then the other,
#3 looks better but is that "lesser transparency a real factor for this ceiling blackout use
the new stuff depending on light may not look as deep a black as the other but it does seem to be "less bright' or less reflective, less "glossy"
so is that a good thing, and so forth
So, campers - any feedback?
ID:	2558230   Click image for larger version
ID:	2558232   Click image for larger version
ID:	2558236   Click image for larger version
post #12376 of 12724 Old 04-26-2019, 06:39 AM
thegeek's Avatar
Quoted: 39 Post(s)
Liked: 29
That's the Royal Velvet #3 with the major sheen?
For my use on the walls and ceiling I'm going with black DMD fabric from Acoustimac. I need black without sheen, and acoustically transparent, which this stuff nails. While I'm 1000% certain I like it more than your standard GOM material I'm not so sure about using it in lieu of velvet because of the texture.
They DO make a "castielle suede" material that comes in black. There's a bit of sheen to it, but the question come in how it compares to the other stuff. Might be too much of a sheen though, but my observations aren't valid without context versus the other stuff. Also, for some reason I can't find the black, navy is the darkest I'm looking at in my sample pack.
thegeek is offline
post #12377 of 12724 Old 04-26-2019, 10:07 AM
asarose247's Avatar
Liked: 1180
^ TY
ordered the sample pack of castielle suede,
so may try another set of pics
thanks for reminding me of the word "sheen'
post #12378 of 12724 Old 04-26-2019, 01:29 PM
ereed's Avatar
Quoted: 2466 Post(s)
Liked: 1765
Looking for some input here. My room is treated with GIK panels. But I have a specific question about the front wall behind the screen especially the fireplace and TV nook. Should I fill those in with pink fluffy, or other material? Not sure if it makes a difference having those 2 things exposed or closed? Here is picture of my actual room currently and here is what it looks like behind the screen to show what I'm talking about (old picture during beginning phase prior to black velvet).
ID:	2558534   Click image for larger version
Theater room: Sony 45es | 120" screen | Panasonic BDT500 | Rotel RMB-1077 | Outlaw Audio 976 | Klipsch RP-280F/RP-450C/RP-160M | Funk Audio 18.0L (2), 21.0LX (2 coming soon) | MiniDSP 2x4HD | Crowson Tech MAs | Surgex XR 315 | CyberPower UPS | GIK room treatments
TV Room: Panny 60 inch | Rotel RMB-1075 | Rotel RSP-1068 | Axiom Audio M60/VP150/QS8 |
ereed is offline
post #12379 of 12724 Old 04-26-2019, 01:50 PM
thegeek's Avatar
Quoted: 39 Post(s)
Liked: 29
@asarose247
I was going through old bookmarks was was em reminded of the existence of "fidelio" velvet, as discussed here: https://www.avsforum.com/forum/19-de...io-velvet.html
thegeek is offline
post #12380 of 12724 Old 04-29-2019, 03:56 PM
asarose247's Avatar
Liked: 1180
never mind the left sample- way too much sheen, Walmart , like $4 /yd. nice but not for this
right is #3
backdrop piece the other aforementioned piece from Amazon
any suggestions?
post #12381 of 12724 Old 04-29-2019, 04:01 PM
thegeek's Avatar
Quoted: 39 Post(s)
Liked: 29
It looks like the random stuff from Amazon is winning so far. It's almost as dark as last night's episode of Game of Thrones.
thegeek is offline
post #12382 of 12724 Old 04-30-2019, 09:11 AM
GoZags13's Avatar
Quoted: 207 Post(s)
Liked: 97
Does anyone know if you can get the Owens Corning 703 from common hardware stores (lowes, home depot, ace, etc)? Or a similar insulation for building your own absorbers? I know GIK sells it on their site but I'd rather just pick stuff up in person and save on shipping if possible.
Denon X4300H; Sony XBR75 900E; Definitive Technology RLS-II/DI 5.5LCR/DI 5.5R; NHT SW12
GoZags13 is offline
post #12383 of 12724 Old 04-30-2019, 11:57 PM
Gradenko's Avatar
Quoted: 39 Post(s)
Liked: 50
Zing!
Panasonic PT-AE8000 | OZTS 150" 2.35:1
Anthem MRX-720 | FP10000Q x 3
Intel Nuc w/JRiver | Beyonwiz | PS4 | Wii U | Switch
Ascension C1503DAMTL x 3, C812AVTL x 4, Mach5 UXL-18 x 2 (17Hz tune)
Gradenko is offline
post #12384 of 12724 Old 05-02-2019, 04:35 PM
asarose247's Avatar
Liked: 1180
short version, no pics
the amazon stuff shed way too many surface fibers with a adhesive lint removal roller while cleaning up for clinging dust, sawdust, ,
showed compression "artifacts" from the small clamps I used to hold for positioning and tensioning while stapling,
and showed "bruising' when i used a hammer to set the tacks evenly, since they rest up against the ceiling stringers
trying to be as smooth and flat as I can
uneased edges / corners of the ply "challenged"the backings integrity , becoming transparent / tearing slightly
the 2 sided tape created a textural anomaly, but that was on the 1 strip where I tried using a wallpaper seam roller for better contact.
(of course i could paint the wood black on the edges and I may do so)
OTOH, the #3 does not shed anything, comparitively, but that's as far as I got with that for today.
It would probably vacuum clean also
all edges and corners will be eased
Question?> could the #3 hold well enough using 2" wide double sided carpet tape
the entire perimeter would be 1" with it wrapped around to the back for another 1" ,mol, of hold
the tape might also reduce and tendency for the backing to "reveal'
i couldn't paint the tape at the edges, maybe a fat shapie, just a line
there will be closely spaced strips / squares of the tape in the interior area of the panel, just so the whole of the fabric is not inclined to sag, owning to the fact of no interior area "support
OTOH, the one panel of the amazon stuff is black with the lights out and all the aforementioned problems become kina of a moot point. maybe not worth the headaches, tho.
but I will go with the #3 , I have 3 pieces cut for 3 of the larger panels but have to wait to put up the new ceiling fan .
post #12385 of 12724 Old 05-06-2019, 09:11 PM
Quoted: 34 Post(s)
Liked: 9
I have a question about what I will define as bass traps that I have installed in my family room/home theater. (in the fully finished basement). Installing bass traps in the corners is not ideal for a number of reasons. It would look out of place and wife will give me grief. And the room opens to a downstairs a summer kitchen and stairway leading upstairs. The family room area is approximately 25Lx11Wx7H, if I recall correctly. I have a two SVS PB-2000s.
I have a rather good amount of acoustic panels. This weekend I made two 7’x15” panels that are 3” thick. I used Owens Corning Thermafiber Fire and Sound Guard Mineral Wool Insulation. I am calling these bass traps but they actual do a really good job of hiding wires at the base of the floor. I am curious if they act at all like a bass trap where the floor and wall intersect. I have similar, but slightly smaller, bass traps behind the seats at the floor to wall intersections.
I have bass traps in the left two corners of the room, but they on are about 40” tall, although about 4” thick.
Will re-run Denon calibration tomorrow to see what (if any impact) occurs. Curious to what you all may think on the board.
ID:	2563490   Click image for larger version
ID:	2563492   Click image for larger version
ID:	2563494   Click image for larger version
ID:	2563496   Click image for larger version
Drelldrell is offline
post #12386 of 12724 Old 05-07-2019, 03:36 AM
thegeek's Avatar
Quoted: 39 Post(s)
Liked: 29
It's a living room not a dedicated theater, there only so much to can do and aesthetically you've done a bang up job.
That said it appears like you're got the subs in the corners which are the worst places possible you can put a sub. Go ahead and run your tests, but next place each sub in the space between your mains and the equipment console and see how that changes things.
thegeek is offline
post #12387 of 12724 Old 05-07-2019, 05:42 AM
AndreNewman's Avatar
Quoted: 177 Post(s)
Liked: 108
I'm interested to hear how this goes, I'm considering something similar around my screen. I need to black out the ~half meter around my screen and would be good to get bass traps out of the project too. Mine would be like yours but 45 degrees, a big wider and above the screen to the ceiling too.
Can you hear the difference if you take them away temporarily?
AndreNewman is online now
post #12388 of 12724 Old 05-07-2019, 08:54 AM
sdurani's Avatar
Liked: 7079
The air gap in the corner behind the panel will help, but three inches of that material will absorb down to a couple hundred Hertz while four inches will get you closer to a hundred hertz. Which means that the bass being absorbed will be from your speakers, above the crossover point, not bass from your subs (the lowest frequencies would require absorption several feet thick).
Also, you'll have to cover significant surface area to have any effect. There is 1,054 square feet of surface area in your room. Your two 7' x 15" panels have 17.5 square feet of surface area. Will covering 1.7% of the surface area of your room have noticeable effect on bass? If you add in your other "bass traps", will it amount to even 5% of the surface area of your room?
Sanjay
sdurani is offline
post #12389 of 12724 Old 05-13-2019, 07:43 PM
Quoted: 34 Post(s)
Liked: 9
Thanks for the reply. I have tried to work as much as possible given the room use. I have not ran bass test again. With the leftover OC, I made a 6'x2'x6" [massive] panel that I placed behind the seating (horizontally and angled backwards to wall).
I watched a movie this weekend and bass seemed better, i.e. a bit more firm and tight. It was actually good before so improvements seems smaller as I have made tweaks.
Will run test in next day to two and report back.
ID:	2566438   Click image for larger version
post #12390 of 12724 Old 05-13-2019, 07:53 PM
Quoted: 34 Post(s)
Liked: 9
Thanks for the reply. I actually have a total 19 panels disbursed across the room. This is about 102 square feet or closer to 10%. The panels range from 1" to 6" as I just added a 6'x2'x6" panel with left of OC rock wool. Most are in the 1-2" thickness and have helped significantly with high and midrange sound.
I also have a large closest to the left of the room to which I have several bags of cellulose insulation in large canvas bags. Cheap experiment that I felt was very beneficial as that closet seemed to have bass that just resonated inside and affected the room. In my opinion, the biggest bang for my buck return on things I have done to perfect and imperfect space.
Think I have done all that I can do short of literally stripping down walls and starting a turn home theater room build. That will not be happening anytime soon!
Fv15hp Subwoofer , Denon , Audyssey
