The 'El Unico' Theatre Build - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 158Likes
post #421 of 422 Old 06-18-2019, 03:37 PM - Thread Starter
Gouie's Avatar
Quoted: 394 Post(s)
Liked: 241
Originally Posted by zebracatzebra View Post
I've read through your build thread here Gouie and it's very informative and entertaining. You've done fantastic work so far!
I believe I read you went with the "Granite" fabric because "Graphite" was unavailable, and you painted the ceiling and soffits black, I don't think I saw what color is the lower woodwork is (columns, trim, etc)? Is it black or gray? Do you remember the color and manufacturer? Thanks!
Hey there, I appreciate the kind words. You are correct; I really liked the graphite but they stopped manufacturing it just before I ordered.
The upper soffits are black and the ceiling will be covered in black acoustic fabric. Everything else in the room is a dark grey paint bought from Homedepot. I’m out of town at the moment but will get the colour for you when I’m back later this week.
Gouie is offline
post #422 of 422 Old 06-20-2019, 11:43 AM
zebracatzebra's Avatar
Quoted: 17 Post(s)
I'd appreciate that, thanks. I'm in the middle of my theater construction and had my mind set on black painted trim and Charcoal DMD fabric panels, but I love your balance of grays with the black chairs and wood accents so much I'm probably going to switch themes.
zebracatzebra is offline
