The "Spill and You're Banned" HT Construction Thread - AVS Forum | Home Theater Discussions And Reviews
 35Likes
post #1 of 63 Old 03-13-2017, 10:57 AM - Thread Starter
edge928's Avatar
Quoted: 93 Post(s)
Liked: 68
I'll get right to it. Like many others I would not have attempted such a robust build had I not read and learned on here for what is going on 4 years now. Many of you answered my questions over that time and I am truly appreciative (Jeff, Dennis, Ted to name a few). Started construction last month (Feb 2017) and I'm currently about 50% done. We ended up going with our home builder to finish our basement with the emphasis on the theater. We looked at dedicated HT builders but they wanted the same amount of money for the theater room as others wanted for the entire basement. I knew I could save a ton of money by doing the critical things myself (clips, channel, wiring, insulation, etc). I have some construction background so I was up to the challenge. Primary usage will be gaming followed by movies.
I've learned a ton so far, every day. The one thing that sticks out the most is that many builds I've seen do not follow code, or at least my local code in the Midwest. For example, I did not want any outlets in my theater room for obvious reasons. Called inspector, forced me to put in minimum (6 for my room). Additionally, I planned on a 12" riser height but code only allows for 7 3/4" (standard step height) without resorting to rails. I could go on and on but I'll let pictures tell the story.
Link to flickr album, has ALL pictures in this thread: https://www.flickr.com/photos/214002...57680471609033
Finished Pictures
The blank slate. Dimensions are 12' x ~23' (2x6 wall is 27'). Tape outline is for a ~120" diagonal screen.
Framing up. I went back and forth between a 34" or 38" door. Chairs will be the biggest item going in and out so I settled on 34" to lessen the amount of area sound could leak out. Door will swing out to give more room for the riser.
Wired for a 7.2 setup. I made sure I could retrofit Atmos ceiling speakers but have no interest/plans for them right now. Same goes for height/wide speakers.
Backer boxes for surrounds. I looked at acoustical caulk but after much reading I decided to go with DAP Alex Flex, their most flexible latex caulk available in my area. I did not cheap out with GreenGlue because there is so much data behind it. With "acoustical caulk" I decided it was more marketing. I used 1/2" MDF since we don't have 5/8" locally.
Putty pads. Guy on ebay was selling them super cheap, got 15. This picture is before I realized they made extendable gang boxes. I eventually swapped them all out.
I'll be honest, deadvents intimidate me. This is my simple version. 2 supplies and 2 returns all using flex-vent snaked for 10-18' each. I stuffed some rockwool where I could. These will eventually be put into the 11"x16" soffits. The original plan was to add a zone to our geo heat pump but they couldn't do it without tearing everything out. The options were mini-split or keep the geo's fan on to constantly circulate air. HVAC guys gave me 200 cfm to work with, seats for 6 butts but normal seating will be for 4, maybe 8 for rare circumstances for a 253 sq ft room. I made sure I could retrofit a mini-split should the fan solution not work.
Front setup. False wall will be 20" deep. Doing a stage with sand on rubber horse mats. 2 cat6 (one for IR repeater), 2 RCA coaxial for subs and LCR speakers. Dedicated 20-amp 4-plex for subs. Plan is to build a minimum screen wall enough to mount black AT fabric.
1.5" conduit for HDMI, power and cat6. I test-ran all 3 cables before mounting. I turned the 2-gang box sideways so the scoop plate will direct the cables to the back of my projector. I plan to run an extension cable to my line conditioner/surge-protector on my rack in the mechanical room. Still going through options to cap/seal the end as sound will easily travel through this. (Edit - Thanks Dave for a good solution in post #4)
Tape is for rough riser location.
Rockwool in. Doubled up the ceiling/joists and the 2x6 wall. An extra $250 for rockwool over fiberglass was an easy decision. I can already tell a big difference with the rockwool. I can no longer hear the doorbell or my dog barking when it rings. Worked in here over the weekend and nearly missed some people. You can also see the a237r clips. I went with the staggered setup. Some corners were tight. If I had more foresight I would have installed extra studs in the corners to help with this. (Edit - I went back and added them. Just doubled up the tight corners)
Thanks to Jeff for this one. Used some RSIC-04 clips to decouple the projector mount. I measured so the first layer of drywall will lay on it. Another option is to replace the first layer of drywall with it but it's less cutting this way.
Backer boxes are decoupled with clips. Measured so they should come into the first layer for drywall but not the second. Should be a good lip to caulk between them. I'm still waiting on Elac to release their in-wall speakers so I made sure the backer boxes were oversized.
This is why you supervise the drywall guys. There were 8 of them and 1 of me (not to mention a language barrier). I didn't see him working in the rack room. Thankfully there's enough left to work with (8.2 plate).
More to come. I plan to build my own AT screen from milliskin spandex thanks to other threads on this forum. Right now I'm not doing anything fancy with the room finishes. I don't have enough width for 3-wide chairs and sconces with walking room on both sides of the chairs. This also eliminates columns as options. Surround speakers will be in-walls for the same reason. The 25 gauge hat channel is being delivered tomorrow (3/14) and the drywall guys will be coming back to finish the theater room.
ID:	2023497   Click image for larger version
ID:	2023505   Click image for larger version
ID:	2023513   Click image for larger version
ID:	2023521   Click image for larger version
ID:	2023537   Click image for larger version
ID:	2023545   Click image for larger version
ID:	2023553   Click image for larger version
ID:	2023561   Click image for larger version
ID:	2023593   Click image for larger version
ID:	2023601   Click image for larger version
Barrok and BllDo like this.
edge928 is offline
post #2 of 63 Old 03-13-2017, 10:59 AM - Thread Starter
edge928's Avatar
Quoted: 93 Post(s)
Liked: 68
Channel up. Dedicated runs for 11"x16" soffits on long walls (added 3" to account for clips/DD). I almost reused the existing channels but Ted White mentioned on another thread that double 5/8 is about the max for clips/channel (especially on the ceiling). Probably dodged a bullet here. The post-DD soffits will hold flex-vent and 4" can lights stuffed with rockwool. No fancy LEDs.
Drywall up. Soffits started. Need to get first layer of mud on before I hang the soffits, want it sealed up.
First layer of mud on. Tomorrow soffits are going up. From there will finish can lights and HVAC within soffits.
Soffits up.
Soffits drywalled and stage started. Stage is only 20" deep as I need every inch I can get for seating distance. This will give me roughly a foot behind my speakers for air movement. I'll be turning my Ultra X12 sub sideways (16" wide).
Closer view of stage construction. Picked up a 4'x6' rubber "horse mat" from Tractor Supply (thanks Jeff) to use on the bottom. Cut it with a jigsaw (go slow!). Layer of OSB to spread the sand weight and 2x10's. Top will be 2 layers of plywood with GG in between. Tomorrow (3/28) I'm getting 27 bags of sand, pray for my back.
My sand calculator was way off. Only needed 20 bags. Good thing we carried them down in batches. Stage done, texture on walls and trim in place. I'll be doing acoustic treatments once construction is done.
Painting done. Stage hookups done (speakers, IR, coaxial). Wife vetoed black out of the gate so settled with a darkish gray all-round. I don't mind the white accents (trim, vents, light housings) as reflections should be minimal. Carpet goes in next week. Ordered theater seats but they won't be here until end of May. Plenty to still do. Still cleaning every day. Drywall dust is the devil's dandruff. Spandex and FR701 delivered for screen and wall. Poplar sitting in the garage for framing.
Carpet in. Stage painted. Testing speaker locations. Center will be on a stand. Pulled cables to projector. Next up is hanging linacoustic behind stage, minimal screen wall and frames for GOM.
ID:	2031137   Click image for larger version
ID:	2037577   Click image for larger version
ID:	2041585   Click image for larger version
ID:	2044033   Click image for larger version
ID:	2053801   Click image for larger version
ID:	2071033   Click image for larger version
ID:	2085097   Click image for larger version
edge928 is offline
post #3 of 63 Old 03-13-2017, 11:29 AM
Squirrel!'s Avatar
Quoted: 822 Post(s)
Liked: 512
Great work!
Main: Mitsubishi 73736|OTA|fireTV|Sony BDP-S1100|Denon AVR4311CI|MartinLogan Preface|Phantom|MartinLogan Encore TF|1-1000watt & 1-500watt DIY 12" Subs|2 Bass Shaker|APC H15 Power Conditioner|Harmony Hub|Sennheiser RS 160|SMSL B1 BT Rx|Linksys SE2500
MBR: Vizio VF550M|OTA|fireTV3|Sony BDP-S1100|Denon AVR-X1000|Chane A1rx-c|Dayton SAT-BK|MartinLogan Dynamo 300|Belkin PF30|Harmony 550
Squirrel! is offline
post #4 of 63 Old 03-13-2017, 11:42 AM
DaveClement's Avatar
Quoted: 606 Post(s)
Liked: 486
Use Gardner Bender Duct Seal from Home Depot or Lowes. It is very sticky, so disposable rubber gloves are recommended. You can soften it up a bit by leaving it out in the sun on a warm day, or put it in the oven on low heat for 10-15 minutes.
http://www.homedepot.com/p/Gardner-B...-110/100212441
https://www.lowes.com/pd/Gardner-Ben...t-Seal/4595233
edge928 likes this.
DaveClement is offline
post #5 of 63 Old 03-13-2017, 12:02 PM
scotty3x3's Avatar
Quoted: 109 Post(s)
Liked: 36
Looking great so far. What the drywall guys did to the wiring would have drove me absolutely insane!! Understand you left yourself enough service loop that you'll be ok... still would have went bananas!!! Sub'd! Looking forward to seeing the progress.
scotty3x3 is offline
post #6 of 63 Old 03-13-2017, 12:08 PM - Thread Starter
edge928's Avatar
Quoted: 93 Post(s)
Liked: 68
Yeah I went super-saiyan when I first saw it. I got out my wall plate and simulated terminations. I thought about re-running them since the other side of the wall was still rockwool. Service loops > leaving plenty on the end.
edge928 is offline
post #7 of 63 Old 03-13-2017, 12:11 PM - Thread Starter
edge928's Avatar
Quoted: 93 Post(s)
Liked: 68
Dave, can you remove this stuff if need be? I can foresee a higher bandwidth HDMI cable needed in 5 years.
edge928 is offline
post #8 of 63 Old 03-13-2017, 12:56 PM
jason4vu's Avatar
Quoted: 136 Post(s)
Liked: 223
Love the thread name. Lol
drunkpenguin likes this.
jason4vu is offline
post #9 of 63 Old 03-13-2017, 01:00 PM
Quoted: 606 Post(s)
Liked: 486
Yes, it is like sticky play-dough. It can be removed easily enough to run new cables, and be put back in place without much difficulty. It is only $3, so grab one and try it out.
post #10 of 63 Old 03-13-2017, 01:12 PM
69glamboy's Avatar
Quoted: 223 Post(s)
Liked: 93
Duct seal is removable. Heating it with a hair dryer is suffice. Putting it in the oven will cause some strife with your wife. Its non toxic but I wouldnt suggest putting where your food gets heated. ( it smells) I love the thread name as well. I've had two wine spills from the wife already and Im barely under construction. She's banned.
brazensol likes this.
69glamboy is offline
post #11 of 63 Old 03-13-2017, 01:19 PM
drunkpenguin's Avatar
Quoted: 1898 Post(s)
Liked: 1820
Your thread title got my attention, we recently recarpeted our room which meant removing the seats for the first time in 10 years. It was amazing what we found! Un-opened bags of candy, beer caps from beers I don't recall ever drinking in my life, and skittles's galore!
chadsmith013 likes this.
drunkpenguin is offline
post #12 of 63 Old 03-13-2017, 02:27 PM
Quoted: 132 Post(s)
Liked: 135
Great start! Look forward to seeing it come together.
Jerry
Fairbanks, Alaska
DIY In Progress Home Theater Build: https://www.avsforum.com/forum/19-ded...tic-build.html
Star Ceiling Build: https://www.avsforum.com/forum/19-ded...am-boards.html
arcticbowman is online now
post #13 of 63 Old 03-13-2017, 02:39 PM
Mashie Saldana's Avatar
Quoted: 1244 Post(s)
Liked: 1083
Shouldn't the title be "Cut the speaker cables and you're banned"?
Looking forward to see how this will turn out.
jsgrise likes this.
Tower Cinema - 9.1.6 in a 12'x12' room
Input : Nvidia Shield TV, Panasonic DMP-UB400
Magic : Marantz SR7010, Marantz SR6010, 2x NAD T743
Output : Panasonic TX65EZ952B, SVS PB13 Ultra, Monitor Audio GSLCR 2xGS20 2xGS10 4xGSFX 6xBX1
Mashie Saldana is offline
post #14 of 63 Old 03-16-2017, 08:19 PM - Thread Starter
edge928's Avatar
Quoted: 93 Post(s)
Liked: 68
Added channel pic in second post.
edge928 is offline
post #15 of 63 Old 03-19-2017, 08:31 PM - Thread Starter
edge928's Avatar
Quoted: 93 Post(s)
Liked: 68
Added drywall pic in second post.
edge928 is offline
post #16 of 63 Old 03-21-2017, 08:57 PM - Thread Starter
edge928's Avatar
Quoted: 93 Post(s)
Liked: 68
Added first layer of mud picture.
edge928 is offline
post #17 of 63 Old 03-27-2017, 09:04 PM - Thread Starter
edge928's Avatar
Quoted: 93 Post(s)
Liked: 68
Added soffit and stage pictures.
edge928 is offline
post #18 of 63 Old 03-31-2017, 09:56 PM - Thread Starter
edge928's Avatar
Quoted: 93 Post(s)
Liked: 68
Added stage complete/texture/trim pic.
edge928 is offline
post #19 of 63 Old 04-01-2017, 09:59 AM
sigma722's Avatar
Quoted: 614 Post(s)
Liked: 385
I think the last pic might not have posted correctly?
Are you going to extend yours stage out from the screen further for looks?
sigma722 is online now
post #20 of 63 Old 04-01-2017, 09:07 PM - Thread Starter
edge928's Avatar
Quoted: 93 Post(s)
Liked: 68
Nope, wife didn't want a stage coming out and I didn't care either way. The final result will be a wall of black GOM from carpet to ceiling 1" in front of the stage.
Edit - Fixed picture. It was there for awhile and disappeared.
Beams37 likes this.
edge928 is offline
post #21 of 63 Old 04-06-2017, 09:13 AM - Thread Starter
edge928's Avatar
Quoted: 93 Post(s)
Liked: 68
GOM FR701 ordered for screen wall. Spandex ordered for DIY screen. Started wire terminations in rack room (mechanical room next door). Painting is starting today (4/6). Went with a darkish gray color for wife-acceptance-factor. She vetoed black out of the gate. All of my recessed light trim and vents are white but will spray paint gray if I end up hating them.
edge928 is offline
post #22 of 63 Old 04-14-2017, 09:29 PM - Thread Starter
edge928's Avatar
Quoted: 93 Post(s)
Liked: 68
Added finished paint picture. I plan on painting the stage black with some left-over flat, black Valspar I have.
edge928 is offline
post #23 of 63 Old 04-15-2017, 10:49 AM
jedi1982's Avatar
Quoted: 244 Post(s)
Liked: 517
Paint color looks good!
jedi1982 is offline
post #24 of 63 Old 04-24-2017, 04:17 PM - Thread Starter
edge928's Avatar
Quoted: 93 Post(s)
Liked: 68
Carpet is in. Working on screen wall and riser this weekend. Will post pics once those are up.
JMEANS likes this.
edge928 is offline
post #25 of 63 Old 05-02-2017, 08:41 PM - Thread Starter
edge928's Avatar
Quoted: 93 Post(s)
Liked: 68
Had to postpone riser and screen wall work since the electrician screwed up mounting a light and pushed out final inspection until this week. In the meantime I've been sealing underneath the door trim/jamb with duct seal/caulk and prepping the automatic door bottom. Picked up a 32" Zero from tmsoundproofing. The ADB mechanism hits my weather stripping so I had to put a 3/8" shim (cut/sanded/painted) between the door and ADB. I should have that installed by weeks end.
Edit - Posted pictures of my rack in the "Show me your RACK" thread (link to post).
edge928 is offline
post #26 of 63 Old 05-04-2017, 08:25 PM - Thread Starter
edge928's Avatar
Quoted: 93 Post(s)
Liked: 68
Posted pic of carpet installed and stage painted.
edge928 is offline
post #27 of 63 Old 05-04-2017, 09:18 PM
dlbeck's Avatar
Quoted: 662 Post(s)
Liked: 778
dlbeck is offline
post #28 of 63 Old 05-04-2017, 09:31 PM
kjlewie's Avatar
Quoted: 95 Post(s)
Liked: 120
I just found your build from the link in the Iowa thread, thanks. Great progress so far. Keep it up!
Audio: Marantz AV7702mkII / Marantz MM8077 / Emotiva UPA-7 for 7.2.4 Atmos/DTS:X
Video: Sony VPL-VW600ES & SI Black Diamond 133" 2.35:1 CIH for 4K UHD
Sources: Oppo BDP-103D, Mede8er 600d with Synology ds716 NAS (28tb), PS4, DirecTV
7. Paradigm Studio 20 v5 (L, R, FW), CC-590 v5 (C), Sonance VP63 (SS); 2. DIYSG DA HO 18" (4); PSA S3000i (3); 4! Infinity Entra One (FH), Sonance VP65R (TR)
kjlewie is offline
post #29 of 63 Old 05-05-2017, 07:11 AM
nickbuol's Avatar
Quoted: 836 Post(s)
Liked: 865
Another guy from Marion, IA here who is tagging along...
nickbuol is online now
post #30 of 63 Old 05-05-2017, 09:24 AM
NickTheGreat's Avatar
Quoted: 522 Post(s)
Liked: 397
Lookin' good! Let us know when you're ready to host the Iowa gang :
booms1ra likes this.
NickTheGreat is offline
