The Force Theater - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 523Likes
post #301 of 443 Old 11-19-2017, 02:30 PM
tgo10000's Avatar
Quoted: 20 Post(s)
Liked: 31
Originally Posted by jedi1982 View Post
Absolutely it was! And sounds freaking amazing! @SierraMikeBravo did a fantastic job of turning the room into a true theater! Heck, sounds better than a LOT of theaters actually lol
Will post pre/post calibration screens soon
Sweet glad it all worked out!
Funny story, was getting a new basement fridge delivered yesterday, delivery guy says cool man cave. My house is in a bit of disarray due to construction but I show him the lowest level with in progress theater, etc. He says wow cool, I met this guy the other day, coolest thing ever, he had a full theme theater, Star Wars, set up some theater chairs for him.
Light bulb moment, huh, yeah I think I know who that might be...funny coincidence.
jedi1982 likes this.
tgo10000 is offline
post #302 of 443 Old 11-19-2017, 04:22 PM
tgo10000's Avatar
Quoted: 20 Post(s)
Liked: 31
Soundproofing
How’s the soundproofing? I remember seeing you talked to Ted White and used IB-3 clips some places. Did you use IB-1 or whisper clips for the rest?
tgo10000 is offline
post #303 of 443 Old 11-19-2017, 05:11 PM
Ladeback's Avatar
Quoted: 1320 Post(s)
Liked: 469
Send a message via MSN to Ladeback
Yes he used clips and channel on the ceiling, soffit and walls. Check out page 3 starting on post #65 and on pown the page.
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
https://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is online now
post #304 of 443 Old 11-19-2017, 05:17 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Originally Posted by ViciousDelicious View Post
Amazing thread and awesome awe inspiring looking threater!
I haven't heard a lot about Triad speakers myself but really looking forward to your impressions when it's all hooked!
You're going with a 2 sub configuration here, right? Any base trapping to even out the modes or is the idea that with the room in room build the modes won't be as much of an issue?
So far I'm very impressed with the entire setup! Post calibration gave me geek laughs last night
Yes I have dual Rythmik FV15HP subs and the riser acts as one big bass trap, plus the room dimensions and overall build were designed to minimize (or eliminate) any nulls.
jedi1982 is offline
post #305 of 443 Old 11-19-2017, 06:23 PM
tgo10000's Avatar
Quoted: 20 Post(s)
Liked: 31
I have previously read this thread probably 3 times all the way through and scanned it again to make sure I was asking questions that hadn’t been answered before I posted. It was lost on you but cool.
The point was, how well did the soundproofing work and the specifics of what he used? Neither of which are currently available in the thread.
tgo10000 is offline
post #306 of 443 Old 11-20-2017, 07:55 AM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Ah, got it! It worked very well. I'll post screenshots later of pre/post calibration results. Got it pretty flat. The projector got as good as could for the unit for both SD and HDR. While the graph on those won't look absolutely pristine, it's the limitations of the projector itself. However, the image still looks fantastic and had a chance to play some Star Wars: Battlefront 2 last night in HDR on my PS4 Pro lol
To answer your specific question though, I'm not sure what my final STC wound up being, but when you close that door, you can't hear any outside noise unless someone yells really loud. Also, when you're outside the room, the only time you really hear / feel anything is playing at reference levels in crazy explosive scenes. My true reference volume is 87.5 db on my receiver and can hardly ever see me playing at that as it's loud!! I typically have played it between 70-75 on receiver and can't really hear anything outside the door in the adjacent rooms.
jedi1982 is offline
post #307 of 443 Old 11-20-2017, 11:51 AM
Quoted: 31 Post(s)
For that size of the room I would personally go with at least 4 subs Having room dimensions perfect (golden ratio?) to not have to deal with modes is amazing, in my given room we have to work a bit on the 25-30 range to not get a suck out. A good acoustician can get it really good though, just needs to know how treat the room.
I heard battlefront has amazing sound. Are you running it in Atmos?
ViciousDelicious is offline
post #308 of 443 Old 11-20-2017, 12:15 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Having a good designer/acoustician is definitely the way to go and am very glad I decided to use @SierraMikeBravo and is one of the best decisions I made with this build! He was at my house for about a total of 16 hours dialing in everything correctly
freestylr likes this.
jedi1982 is offline
post #309 of 443 Old 11-20-2017, 05:04 PM
tgo10000's Avatar
Quoted: 20 Post(s)
Liked: 31
Battlefront 2 in HDR, wow, awesome.
tgo10000 is offline
post #310 of 443 Old 11-21-2017, 03:22 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Thought I'd post some updated pics now as the lighting and steps were all corrected last week. My plan over the weekend is to get the columns and area beneath the stage wrapped with fabric. Then next week will try to get the black plexiglass that will cover the projector box cut and should then be complete!
ID:	2319178   Click image for larger version
ID:	2319180   Click image for larger version
jedi1982 is offline
post #311 of 443 Old 11-23-2017, 08:33 AM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Ok I have some information to share regarding the calibration. First off, let me start by saying that if you are going to be doing a dedicated home theater build, calibrating it is an absolute MUST! I thought the equipment sounded good before...holy cow what a difference after calibration! There are items in the audio track that I have never heard before.
For my system, @SierraMikeBravo calibrated the LCR + dual subs. We can't find the pre-calibration graph for audio but have the post-calibration results.
As you can see, we got a pretty flat response and can tell you from what I remember about the pre-calibration, the pre wasn't TOO terrible but had noticeable peaks and valleys. Playing through several songs on Shawn's demo disc, you could definitely hear the difference with no calibration and then hitting a button to enable the calibrated results. The calibration took out a lot of the "noise" and garbled-ness (best way I can describe it lol). Keep in mind, prior to calibration, I thought the track sounded great but after the calibration, hearing the difference was night and day as was much cleaner and defined.
Like I mentioned above, post-calibration, I'm now able to hear details in the audio track in movies that I didn't necessarily hear before. The experience is very cool
The video calibration was a bit tougher to dial in. The limitations are really with the projector itself. For a $2,500 projector though, the out of box settings aren't too bad and after calibration of both the SDR and HDR, the results are as good as they can get. Green was the problem child though. I do have the 2 settings saved to memory (SD and HDR) and gotta say, playing Star Wars: Battlefront 2 in HDR is very cool lol
*edit* will have to repost video results as something went wrong with the files
Ladeback likes this.
jedi1982 is offline
post #312 of 443 Old 11-24-2017, 07:29 PM
darthray's Avatar
Quoted: 2092 Post(s)
Liked: 2973
WOW, and WOW
You have achieve so much work, since you and I talk through these thread.
Very well done and so impressive!!!
Since it as been so long, I skim through the last few pages, and went to see the finish product
Around page 4, you had a hard wood floor, on the final page it is carpet (my first choice).
Did you change your mind, or the carpet was lay over the hard wood floor, if so why?
Either way, very well done and enjoy
Will also post on the Aperion thread about your question!
Ray
darthray is offline
post #313 of 443 Old 11-24-2017, 08:12 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Originally Posted by darthray View Post
WOW, and WOW
Ray
Thank you! I actually didn't post it as a question but was rather a statement knowing others might be wanting to know what I was using lol
Regarding the floor, it was always rubber on the concrete then OSB as was planning on doing nice pad + carpet and love the end result
jedi1982 is offline
post #314 of 443 Old 11-26-2017, 06:08 PM
darthray's Avatar
Liked: 2973
This the result, of what happen when doing speed reading, trying to catch-up
From the picture, it look like hard wood floor, my bad
And Yes, the end result look Outstanding
Ray
darthray is offline
post #315 of 443 Old 11-28-2017, 05:49 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Gotta pick up some kind of pnuematic or powered staple gun to finish installing the fabric track along columns and under screen. Should only take a few more hours worth of work to do that and install the fabric into the track.
I'm considering https://www.arrowfastener.com/tool/t50dcd/ but am wondering if anyone has used that before.
I also called the plastic place I had cut my plexiglass and they will be form fitting the black piece that will go on the front of the projector box and cutting the hole for the lens. When these 2 things are complete, the theater will be at 100%!
jedi1982 is offline
post #316 of 443 Old 11-28-2017, 06:05 PM
Mahuzz13's Avatar
Quoted: 319 Post(s)
Liked: 475
I have not seen that one but I did pick up this one for $34CAN https://www.arrowfastener.com/tool/pt50/
Very compact (smallest pneumatic stapler I?ve seen) and works very well for fabric.
Mahuzz13 is offline
post #317 of 443 Old 11-28-2017, 06:34 PM
TMcG's Avatar
Quoted: 1614 Post(s)
Liked: 1804
Wait....you’re installing Plexiglass in front of the projector lens?
TMcG is offline
post #318 of 443 Old 11-28-2017, 06:50 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Cool, will look into it. My only concern is, will it staple through the plastic fabric track into MDF?
Yes, the projector box will have the black plexiglass covering but will have a 7.5" hole cut for the lens
jedi1982 is offline
post #319 of 443 Old 11-28-2017, 07:41 PM
Mahuzz13's Avatar
Quoted: 319 Post(s)
Liked: 475
Then you definitely need a pneumatic one not an electric or battery operated. This one will do the trick but if you want to spend some money buy the Porta Cable Stapler if you are worried but I don?t think should worry it will do the job. It only does up to a 9/16 staple so not sure the length you need.
Mahuzz13 is offline
post #320 of 443 Old 11-28-2017, 07:57 PM
Quoted: 99 Post(s)
Liked: 74
I have a Stanley TRE500 that worked great on fabric acoustical panels...I was using 3/8" staples into poplar frames and it would drive them almost all the way in...used a small hammer to drive them flush...ended up going to a 5/16" staple and it worked a little better but still had to give them a little love tap to flush them up...key was to push and hold it down firmly and they would drive in flush...I figure this out about 10 staples from being done (after approx 1000 staples)...had I not been stapling upside down it would have given me more leverage...but the pressure is the key...
go with the pneumatic...that is one serious stapler...
Denon x4300H
Ascend Acoustics CMT 340 L/C/R with HTM 200 Surrounds
Rythmik LVX12
Oppo 203
(2) V.B.S.S w/ NX3000D
tiggere is offline
post #321 of 443 Old 11-28-2017, 08:00 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
LOL oh man...that sounds like something that would happen to me right at completion and have a "D'Oh!" moment
jedi1982 is offline
post #322 of 443 Old 11-29-2017, 10:32 PM
Schneeds's Avatar
Quoted: 14 Post(s)
Liked: 8
Amazing work on this. The fabric panels you made are outstanding.
You used almost identical dimensions for your light panels as I did in my Lego theater
femi likes this.
Commence Primary Ignition Theater. Anthem MRX 710 / Sony UBP-X700 / Sony VPL HW40Es / Dual SVS PB 1000s / Martin Logan 50XT (c), Lx16 (r/l), FX (sr/sl), Motion 4 (sbl/sbr)
Schneeds is offline
post #323 of 443 Old 11-30-2017, 10:40 AM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Nice!! My plans did call for additional detail above the panels like you have, but lost that room with the soffit drop. Love your room!
jedi1982 is offline
post #324 of 443 Old 11-30-2017, 11:05 AM
TMcG's Avatar
Liked: 1804
Nice theater. And thanks for scratching my OCD itch with that sublime vacuum sweeper job!
bpassman likes this.
TMcG is offline
post #325 of 443 Old 12-02-2017, 08:07 AM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Someone asked a while back to show my rack! I thought that was kind of a personal question, but hey, what they heck!
From the bottom up is:
-Outlaw 5000 (x2)
-Outlaw M2200 (x3)
-Autonomics 6 zone amplifier
-Denon X4300H
-Coolerguys dual 120mm temp controlled fans
-Mirage 2 stream audio server
-miniDSP 10x10HD
-Savant 8x8 video matrix
-Lorex security NVR
-ATT Uverse (x2) boxes + DVR
-Savant controller
-ATT modem
-ASUS AC1900 (ASUS AC-RP68U upstairs)
-Savant host
-Araknis 24 port switcher
And the madness behind what makes it all work...
Here's where it is located in proximity to the theater (door is shut)
ID:	2324438   Click image for larger version
ID:	2324440   Click image for larger version
jedi1982 is offline
post #326 of 443 Old 12-09-2017, 07:30 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Got the front columns and side of the columns wrapped with fabric track/fabric last night and today! Each front facing column took me about an hour each and then the sides of the columns took about 30 min each. I would've had this done sooner but didn't have a pneumatic staple gun! Borrowed one to get the job done
Here's what it originally looked like up close after I installed the track
And then here's a front view with the right column already completed
and viola! Left side completed. The part where the track meets the side wall was a pain!
Here's a shot where I got the side of the column next to the screen completed as well. Looks great!
And the complete columns
Next up is to finish out the area beneath the screen. I hope to tackle this tomorrow and be done with it!
ID:	2328372   Click image for larger version
Name:	both sides.jpg
ID:	2328374   Click image for larger version
ID:	2328376   Click image for larger version
ID:	2328378   Click image for larger version
jedi1982 is offline
post #327 of 443 Old 12-10-2017, 07:45 PM
neoridium's Avatar
Quoted: 16 Post(s)
Liked: 26
Are you using a HTPC? if so change the background to something like
DavidinCT likes this.
neoridium is offline
post #328 of 443 Old 12-10-2017, 08:31 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
lol sadly I'm not so can't do that. Great idea though!
jedi1982 is offline
post #329 of 443 Old 12-10-2017, 08:34 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
ALL OF THE FABRIC TRACK AND FABRIC INSTALL IS COMPLETE!! I just have the center removable panel below the screen to finish up. It's framed and painted, just need to wrap and staple the fabric to it then install the velcro to secure it. Here's some pics of what I did installing the areas beneath the screen.
Not sure why this color/pic quality looks like the way it does, but at least you can see up close what I did...
And here's both sides ready to have the fabric installed
Then the final look
ID:	2328890   Click image for larger version
ID:	2328892   Click image for larger version
nathan_h, JPeezy13 and DavidK442 like this.
jedi1982 is offline
post #330 of 443 Old 12-11-2017, 06:02 AM
DavidinCT's Avatar
Quoted: 299 Post(s)
Liked: 96
Nice picture, Maybe I should create a HTPC Windows Media Center theme.... Even though WMC has been killed by Microsoft, it still works perfect and is a nice front end for a theater as it's got TV, Movies, Music, and even streaming sources can be added...
To the OP, Love the theater design...it's coming out awesome !
-Dave
MCSE 2003
Windows Media Center specialist - MVP and Certified Home Theater specialist
Avid gamer and home theater junkie..
DavidinCT is offline
