The Force Theater - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 523Likes
post #391 of 443 Old 02-02-2018, 07:58 AM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Originally Posted by Ladeback View Post
Congrats as well on HTOTM! It's a great write up and well deserved to you, Big and Shawn.
Originally Posted by subacabra View Post
Congrats! Well deserved, one of the coolest theaters around!
Appreciate it guys!
jedi1982 is offline
post #392 of 443 Old 02-02-2018, 11:08 AM
moe80's Avatar
Quoted: 76 Post(s)
Liked: 27
Originally Posted by jedi1982 View Post
Yeppers. My Rythmik FV15HP's are powered. Thus is the tale of the ground loop...
It all began when the theater was being calibrated back in Nov. During the initial playback at reference level with only 2 channels active, the power source was tripped. Knowing right away that the theater would require more power, I called my electrician and he let me know he'd be on-site the following Mon (happened on a Sat).
After spending about an hour or so running the new outlets to the A/V closet, everything seemed to be going as planned! Then it began...
My front left tower had a nasty crackle sound to it. I immediately thought this was a ground loop issue. I had my electrician come back out and we tried many many different things, including making sure everything in
the house was run in parallel, to get the crackle resolved by no luck. Finally, as I had once before tried swapping out the RCA cable from my receiver to the miniDSP, I tried one more time as that would be considered "low hanging fruit". TA-DA! It fixed the front left tower!
However, in the process of doing whatever we did, my subwoofers now had that ominous, low hum sound. I believe unless you were listening for it, you likely wouldn't recognize it. But I knew it was there and would hear it every time I got through watching something. Once I called attention to it, anyone else in the room would then hear it. My electrician was out several more times and we tried many other things to try to isolate the problem.
Troubleshooting went on for several weeks when I had the time and really didn't put much effort into it now as I thought it I was stuck with it as tried so many things! I tried unplugging the HDMI's, RCA's all the equipment from the outlets to see what would make a difference. Nothing though.
My electrician stopped by again last week to look once again at the electrical because mind you, before the new outlets were installed, there was no hum. I know I have given the poor guy headaches trying to figure this out! We decided to call Rythmik to see if we might have overlooked something. Following their instruction of unplugging all HDMI cables (yet again after previous attempts) as cable boxes are a likely culprit, they also mentioned the cheater plugs (3 prong converter to 2 prong eliminating the ground) as the subs are grounded internally. As my electrician was in the room, he mentioned that he had just got done disconnecting the ground connection from those outlets the subs were plugged into which should've yielded the same exact result. Rythmik also mentioned to try a different audio cable.
After they said that, we turned the subs sideways to access the speaker cable and noticed if you were to slightly move the RCA cable, it would make a difference in sound and not in a good way! The humming would get louder. So went to Best Buy this past Sat to get another RCA cable that would reach from subwoofer to miniDSP/receiver. Swapped out the cables but no luck. At this point, I was really discouraged as I thought I really was stuck with the ground loop issue.
I kept going back to thinking it had to be something with that outlet that was installed because when I would unplug the LCR amps from outlets, that seemed to make a bit of a difference. As a last resort, I went to Lowes yesterday (Sun) and picked up a few cheater plugs. I thought, perhaps seeing if the ground issue might be with those outlets so tried plugging in the amps with the cheater plugs into those outlets. I couldn't believe it as it still didn't help!! I even tried running those amps through a power conditioner but nope, nothing as the hum was still there.
So there I sat pretty discouraged and was putting the cheater plugs back in the package to take them back to Lowes when I thought, you know I have them here and I know we disconnected the ground wires from the outlets and that didn't help, but might as well try putting these plugs on the ends of the subs and hook them in and see what happens. AND LO AND BEHOLD IT FIXED THE ISSUE!!!!!!
Jedi
I just read your post about the ground loop issue.
I'm going through something similar, with my front sub, I tried everything and for the life of me, cannot solve it.
So I ran a separate sub cable from my AV, into the room, outside of the wall and that solved the problem.
So the RG6 in the wall seems to be causing it since the cable I ran outside the wall doesn't cause any hum.
Thinking of trying this cheater you used, do you have a link for it, or which one you got?
And nice work on HTOTM!
jedi1982 likes this.
CineMoe 3.0 Atmos 7.2.4 build in progress
JVC RS540 | EluneVision Reference 4K Audioweave 150" 2.35:1 | Anthem MRX-1120 |OPPO UDP-203 | Definitive Tech BP8060ST, CS8060HD, 4x SR8040BP, 4x Atmos DI 6.5R | Dual HSU VTF-3 MK5 subs | Ultralink HDC-150RM power conditioner | Harmony Elite | 8x Sonos Connect Amps| Monoprice 12AWG speakerwire, certified HDR HDMI |
moe80 is offline
post #393 of 443 Old 02-02-2018, 11:38 AM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Originally Posted by moe80 View Post
Jedi
Ground loop issues are a pain! Thankfully, mine was an easy fix, just was the absolute last thing I checked lol
This little guy is what did the trick. It's just a 3 prong to 2 prong adapter. I can use this because my subs are grounded internally. You may check about yours. But also know how annoying it can be to have that hum and if this does work, might be worth the risk if not grounded internally
jedi1982 is offline
post #394 of 443 Old 02-02-2018, 11:44 AM
moe80's Avatar
Quoted: 76 Post(s)
Liked: 27
Are your subs using 3 prong plugs?
I'm using the HSU VTF-3 MK5, and they are using 2 prong AC plugs.
So guessing those may not work, since they are 3 prongs to 2...
moe80 is offline
post #395 of 443 Old 02-02-2018, 12:54 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Yeah might not work in your situation My subs are 3 prong.
Still, at only about $.70, it's a very inexpensive thing to try. Other than that, might start by getting an electrician to your house and making sure everything in the fuse box is run in parallel. Next thing to try is unplug the cords from your cable box as that can be an issue as well
jedi1982 is offline
post #396 of 443 Old 02-06-2018, 07:15 PM
fizban11's Avatar
Quoted: 77 Post(s)
Congrats! WOW! It took me two days to read through the thread after the HTOTM write-up posted. I am all at once speechless (which my wife would be skeptical of), humbled and a tad envious (can't lie, but I think most of us reading this thread are, as well.) Something in the HTOTM write-up caught my attention and I paid special attention to try and find an answer to my question as I read through the build-thread. So, as Captain Needa, I will apologize if it did escape me.
"The acoustic treatments were integrated into the paneling. “The acoustic treatments and fabric track are all products from Quest. They are in specific locations to provide absorption, diffusion, and reflection."" How was it determined where and how the acoustic paneling would placed? Knowing this would greatly help my own knowledge. Congrats and thanks for sharing!
LVR: Samsung UN65JS9500, Marantz AV8802A / MM8077, NVShield Pro (2017), Panasonic BDR, XB1, Zone 2 out to HDFury Integral to Linker split to Sony MDR-HW700DS (Import) and Pio Elite VSX-90 (Patio) , B&W CM10 S2 L/R, B&W CM Centre 2 S2, B&W (4x) CI 700 Series CCM7.4 (SS/SB), B&W DB1 Sub, MBR: Samsung UN55JS9000, Marantz SR6011, NVShield Pro (2017), Pioneer Elite BDR, XB1, B&W (5x) CI CCM816, B&W PV1D Sub , C4 System
fizban11 is offline
post #397 of 443 Old 02-06-2018, 07:56 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Glad you enjoyed the read and great question! As part of the overall designing and planning process, Quest ran an acoustical analysis based on the specs of my equipment, room properties and anticipated build. That determined the type of material and location the acoustic paneling would go. I did quite a bit of research ahead of time about reflection points, but am glad that I relied on them for this part as there is SOOO much more to consider when it comes to the science of acoustics.
jedi1982 is offline
post #398 of 443 Old 02-06-2018, 08:03 PM
Brazle's Avatar
Quoted: 159 Post(s)
Liked: 196
Hey @jedi1982
Pics of the finished room look SUPER! Love me some Star Wars themes, though I don't think the wife would go for a Death Star themed livingroom. :-)
Great theater, I bet it feels really special.
HT setup: Vizio 50" 4K | Xbox & PS3 | Pioneer Elite VSX-94TX | Bose 701 towers (V1) | JBL S Center | Def Tech Reference SuperCube & DIY Nearfield cabinet ported UM18 dual ported PA380 ULF+MBM
Brazle is offline
post #399 of 443 Old 02-06-2018, 08:13 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Originally Posted by Brazle View Post
Hey @jedi1982
Thank you!! Hey, regarding your wife and living room, never give up. There's always hope
jedi1982 is offline
post #400 of 443 Old 02-12-2018, 10:52 AM
amcfarla's Avatar
Quoted: 81 Post(s)
Liked: 79
Reddit link brought me here (https://www.reddit.com/r/hometheater...heater_in_his/), pretty impressive theater. I am sure you are the envy of all your friends
amcfarla is offline
post #401 of 443 Old 02-12-2018, 12:09 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Awesome! Thanks for stopping by and hope you've had a chance to read up on the build or the article Is also featured as AVSforum Home Theater of the Month this month!
jedi1982 is offline
post #402 of 443 Old 02-13-2018, 07:19 PM
SierraMikeBravo's Avatar
Quoted: 365 Post(s)
Liked: 249
"The acoustic treatments were integrated into the paneling. ?The acoustic treatments and fabric track are all products from Quest. They are in specific locations to provide absorption, diffusion, and reflection."" How was it determined where and how the acoustic paneling would placed? Knowing this would greatly help my own knowledge. Congrats and thanks for sharing!
Good question! We use proprietary modeling to calculate ray tracing, low frequencies for each seat, modal pressure plotting, sweet triangle analysis, and numerical analysis to determine proper placement of everything including treatment types.
Shawn Byrne
CEDIA Certified Professional EST II - HAA, THX.
Theater Design Information and Examples
[email protected]
[email protected]
SierraMikeBravo is offline
post #403 of 443 Old 02-17-2018, 05:57 AM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Yay! The Force Theater was just featured on CNET.com as well
https://www.cnet.com/pictures/show-u...-wars-theater/
JDontee and Ladeback like this.
jedi1982 is offline
post #404 of 443 Old 02-17-2018, 03:23 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
HOLY CRAP!!! Mark Hamill...Luke Skywalker himself just liked my tweet about The Force Theater!!!
ID:	2362836   Click image for larger version
Name:	MARK HAMILL.jpg
jedi1982 is offline
post #405 of 443 Old 02-17-2018, 10:29 PM
Ladeback's Avatar
Quoted: 1321 Post(s)
Liked: 469
Send a message via MSN to Ladeback
So Patrick, did CNET come out or did you supply them with pictures. Very cool article. Nice props from Mark Hamill.
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
https://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is offline
post #406 of 443 Old 02-18-2018, 07:23 AM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
I supplied the pics and thank you!
jedi1982 is offline
post #407 of 443 Old 02-25-2018, 06:42 AM
Yukichon's Avatar
Quoted: 191 Post(s)
Liked: 100
You may as well retire at life now. You win !!
DavidinCT, sqmzeea and jedi1982 like this.
Yukichon is offline
post #408 of 443 Old 02-25-2018, 07:04 AM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
haha!! Was definitely unexpected
jedi1982 is offline
post #409 of 443 Old 02-27-2018, 05:59 AM
DavidinCT's Avatar
Quoted: 299 Post(s)
Liked: 96
Really ! I don't think it gets any better than that for a Star Wars Junkie. Life would almost be complete
Love the theater. This basic design has always been in my mind WAY before even joining AVSfourm. It's like my dreams came to life.
-Dave
MCSE 2003
Windows Media Center specialist - MVP and Certified Home Theater specialist
Avid gamer and home theater junkie..
DavidinCT is offline
post #410 of 443 Old 02-28-2018, 06:57 AM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Love it and thank you! I like how it's not really specialized in anything but has those signature lights and shapes so you know what the theme is and for those that don't recognize, they can appreciate the uniqueness of it as a theater room
DavidinCT likes this.
jedi1982 is offline
post #411 of 443 Old 02-28-2018, 12:12 PM
Waldo11's Avatar
Very Cool Jedi!
Shawn designed my theater that is currently under construction. Cant wait till its done!
Waldo11 is offline
post #412 of 443 Old 03-01-2018, 07:32 AM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Hey, The Force Theater was recognized in another publication today!
http://ccheadliner.com/news/force-th...5813661e3.html
jedi1982 is offline
post #413 of 443 Old 07-02-2018, 03:13 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Had a chance to grab a copy of Horizon: Zero Dawn Complete Edition for the PS4 Pro as it went on sale for $20 and holy cow! The HDR looks spectacular!! Have played about 5 hours and am absolutely loving everything about the game. There's just something refreshing about being able to shoot down giant robots with some pretty cool gear...
Little Chris likes this.
jedi1982 is offline
post #414 of 443 Old 08-14-2018, 04:29 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Had a chance to watch Avengers: Infinity War last night in 4K HDR. Was phenomenal! But still left me feeling like had just had the crap kicked outta me
brazensol, Ladeback and Mahuzz13 like this.
jedi1982 is offline
post #415 of 443 Old 08-14-2018, 05:46 PM
Jedi940's Avatar
Quoted: 267 Post(s)
Liked: 185
Nice. Makes all the hard effort worth it. I'm still waiting for the 3d release in 2 weeks. And amazingly I'm still spoiler free.
Sent from my SM-G950U using Tapatalk
Jedi940 is online now
post #416 of 443 Old 08-15-2018, 10:38 AM
Ladeback's Avatar
Liked: 469
#4 is supposed to be out May 3 2019, but there will be a few movies before that and after that. See Spoiler is you want to see what is coming.
Ladeback is offline
post #417 of 443 Old 08-15-2018, 11:13 AM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Yeah it stinks the fact that I knew about what additional Marvel movies already in the making as it takes some of the fun (or agony based on the ending) out of waiting for Avengers #4
jedi1982 is offline
post #418 of 443 Old 08-15-2018, 09:17 PM
Ladeback's Avatar
Liked: 469
My wife and a friend of ours was mad about the ending and didn't understand it. I said it should make since in#4, and they have to bring it to an end at some point. A bunch of the actors are wanting to be done with it I think.
Ladeback is offline
post #419 of 443 Old 08-16-2018, 06:30 AM
gronkman's Avatar
Quoted: 12 Post(s)
I've been following your build since the beginning, and I love it. I’m curious - Do you have an Apple TV or other digital streamer, and if so do you use it more or less than UHD blu rays?
gronkman is online now
post #420 of 443 Old 08-16-2018, 01:30 PM - Thread Starter
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
That's great news and hope you've been able to find some of the content here helpful The only streaming I do is via Netflix and haven't streamed any UHD content through that. I had a friend bring his Amazon Fire Stick and hooked to my receiver to stream Westworld in The Force Theater and plan on doing that when GoT is released next year as well!
I'm leaning towards cutting the cord when my uVerse contract is up as I don't watch a lot of tv. Primarily have it so my little guy can watch Disney/XD/Nick which, believe, can stream all of those live with several streaming services. Hoping in another year as more people cut the cord, companies will have worked out any kinks or quirks with their systems by then
jedi1982 is offline
