1/2" or 3/4" MDF for atmos speaker boxes?? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By BIGmouthinDC
post #1 of 9 Old 07-10-2017, 12:18 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 300 Post(s)
Liked: 253
Going to build 4 atmos speaker boxes next couple days and wondering if 1/2" MDF will be suffice or should I still use 3/4" MDF? The boxes will sit between the ceiling joists on top of the plywood followed by a layer of drywall with green glue sandwiched between.
It may not be your job, but perhaps it's your opportunity.
MPJ's theater build: https://www.avsforum.com/forum/19-ded...ter-build.html
mpjmeyer is offline
post #2 of 9 Old 07-10-2017, 12:27 PM
edge928's Avatar
Quoted: 93 Post(s)
Liked: 68
Thicker the better but I couldn't imagine a big difference between them. I used 1/2" MDF for my backer boxes since the sheets aren't as heavy (no help loading/unloading). If you have pieces lying around or help then go 3/4".
Audio: Denon X3300W / Outlaw 7140
Speakers: Elac Unifi UF5 x2, UC5 / Elac Debut IW-D61-W x4 / Outlaw Ultra-X12
Video: Epson 5040 / 116" 16:9 DIY Spandex
Sources: Xbox One X / PS3 / PS4 Pro / Nintendo Switch / Steam Link / RetroPie
My Theater Thread
edge928 is offline
post #3 of 9 Old 07-10-2017, 12:30 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 300 Post(s)
Liked: 253
I could probably go ahead and do 3/4" for the speaker boxes, however I'll be ok with 1/2" MDF for my soffit's, right? The soffit will hold the ac duct and lights, no speakers...or should that also be 3/4"?
mpjmeyer is offline
post #4 of 9 Old 07-10-2017, 01:43 PM
Quoted: 5958 Post(s)
Liked: 5526
best practice is a two layer box with Green Glue between layers. Start with a Minimum of 3/4 MDF and decide if you think the location and your goals deserves more layers.
Tedd likes this.
post #5 of 9 Old 07-10-2017, 02:12 PM
edge928's Avatar
Quoted: 93 Post(s)
Liked: 68
Really depends on if you're doing pre or post drywall soffits. Post-drywall you can just throw 1/2" drywall on the soffits and be done (unless you have some really noisy ducts). Pre-drywall you'll need to treat the soffits like any other stud wall with clips/channel, DD and GG. I ran dedicated channels for my soffits and then put them up after drywall using 3 1/2" deck screws. Ran 2 returns, 2 supplies (all flex vent) and 6 can lights, no backer boxes needed but I did stuff insulation in them to prevent reverberation.
My Theater Thread
edge928 is offline
post #6 of 9 Old 07-10-2017, 02:54 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 300 Post(s)
Liked: 253
I plan on building a room inside a room first, then build the soffits. Probably just use 1/2" MDF for the soffits for the extra durability and bass dampening. The original plan was to use plywood then drywall which would have been a tight fit with the door opening and media rack so if I only use 1/2" MDF, that helps a little. I'll take every bit of space I can get. As far as the speaker boxes go, I'll use 3/4" MDF and see how that works for what I need
mpjmeyer is offline
post #7 of 9 Old 07-12-2017, 07:03 PM
DaveClement's Avatar
Quoted: 606 Post(s)
Liked: 485
Your backer boxes should have at least as much mass as the holes you are cutting out. That probably means that you want 3/4". With speaker boxes, stiffer is always better. Another reason to use 3/4". 3/4" also gives you more area to screw into for anything that you screw into the end of the panels. I can't think of any good reasons not to use 3/4" over 1/2"
DaveClement is offline
post #8 of 9 Old 07-17-2017, 08:47 AM
Spyderturbo007's Avatar
Quoted: 244 Post(s)
Liked: 104
I used this when I built mine. Damn things were heavy.
5/8" Drywall / Green Glue / 1/2" Plywood / Green Glue / 5/8" Drywall / Acoustical Caulk
Spyderturbo007 is offline
post #9 of 9 Old 07-17-2017, 10:48 AM
Quoted: 606 Post(s)
Liked: 485
Exactly as they should be!!!
