Did i get the wrong insulation? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By BIGmouthinDC
  • 3 Post By BIGmouthinDC
  • 1 Post By DaveClement
post #1 of 13 Old 07-16-2017, 09:57 AM - Thread Starter
Quoted: 55 Post(s)
Liked: 2
Hello all,
So i got the Roxul AFB acoustic insulation, however they're 2.5 inches thick and i would have over an inch of space on the walls and couple of inches on the floor would this work or i simply purchased the wring one ?
Sent from my SM-N920V using Tapatalk
tnycman is offline
post #2 of 13 Old 07-16-2017, 10:25 AM
Quoted: 5966 Post(s)
Liked: 5540
post #3 of 13 Old 07-16-2017, 10:41 AM - Thread Starter
Quoted: 55 Post(s)
Liked: 2
here is the data on those products.
http://www.bobgolds.com/AbsorptionCoefficients.htm
Thanks for that, great info on that link..
I guess i didn't ask the right question in my initial post, what I'm trying to find out if the empty space of about 2 inches will make thwm useless ? Or it wont matter ?
tnycman is offline
post #4 of 13 Old 07-16-2017, 10:57 AM
bscool's Avatar
Quoted: 889 Post(s)
Liked: 714
You want to fill the space you don't want it to have gaps and you don't want to pack it in/compress. How much difference will have the extra space have? I don't think anyone can actually tell you other than it is not optimal and when spending the $ and all the work it is best to get the right stuff that fits correctly with no gaps and not too tight.
If it were me I would take it back and get the correct stuff and I think the link Big put in his post is so you can see which product is best for sound absorption and the difference between different products and thicknesses.
HTPC, Sony 40es, 120" Silver Ticket, 7702mkii, Sunfire Amp 225w, JBL 590, JBL 520
PSA XS30, Seaton Submersive, 2 Um-18 8cf sealed, Outlaw Ultra x 12, Kappa Pro 18LF, BFM Tuba 60 horn, B&C 18TBW100 6cf 41hz, 34hz, 28hz tune
iNuke 3000 & 6000 DSP's, Crowson Motion Actuator
bscool is offline
post #5 of 13 Old 07-16-2017, 11:12 AM
Liked: 5540
I'm not sure what construction method you are using here?
What is that metal and what is it doing?
post #6 of 13 Old 07-16-2017, 11:28 AM - Thread Starter
Quoted: 55 Post(s)
Liked: 2
The picture was upside down, for some reason tapatalk app keeps rotating the picture, but its a standing wall, if you rotate it once clockwise.
On the floor there werr metal studs, that the previous owner has placed and there were bunch of electical cables going through most of them going to the floor below, it was a lot of work cutting and moving this cables so i left it alone, that has increased the depth of that wall by 2 inches..
tnycman is offline
post #7 of 13 Old 07-16-2017, 11:55 AM
Liked: 5540
at the end of the tape measure is that concrete or the back of drywall for another room? If drywall the original builder created an electrical hazard.
post #8 of 13 Old 07-16-2017, 11:56 AM - Thread Starter
Quoted: 55 Post(s)
Liked: 2
Drywall
tnycman is offline
post #9 of 13 Old 07-16-2017, 12:46 PM - Thread Starter
Quoted: 55 Post(s)
Liked: 2
It seems thar there is no way but take them back to the store, that thing was heavy and big bags, took me two trips to get it..
tnycman is offline
post #10 of 13 Old 07-16-2017, 01:27 PM
Liked: 5540
Drywall
Imagine someone coming along and nailing up some baseboard molding in that room. There is a good chance of running a nail into a Romex cable. You should fix that while the wall is open.
post #11 of 13 Old 07-17-2017, 08:38 AM
Spyderturbo007's Avatar
Quoted: 244 Post(s)
Liked: 104
It also looks like there is a CAT 5 in there too. CAT 5 and electrical don't get along very well.
Spyderturbo007 is offline
post #12 of 13 Old 07-17-2017, 09:14 AM - Thread Starter
Quoted: 55 Post(s)
Liked: 2
Make sense, however the area you are seeing behind that wall is a crawl space in the attic, i doubt thete ever be a baseboard molding in the crwal space..
tnycman is offline
post #13 of 13 Old 07-17-2017, 10:45 AM
DaveClement's Avatar
Quoted: 606 Post(s)
Liked: 486
Your insulation is designed for 2x4 framing, which is 3-1/2" deep. It looks like the space is about 5-1/4". You'd be better off with insulation that is designed for 2x6 framing, which is 5-1/2" deep. The insulation that you purchased will "work" to a certain extent, but not as well as thicker insulation that will fill the space all the way.
It would seem to me that there is a very viable way to take them back to the store. It took two trips to bring them home the first time. Two more trips would allow you to bring back the wrong insulation and bring home the right kind. Sure, it is a hassle, but if you are going to do it, why not do it right?
tnycman likes this.
DaveClement is offline
