Help needed with basement build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-22-2017, 10:50 PM - Thread Starter
soulEngine's Avatar
Quoted: 16 Post(s)
Liked: 33
Question Help needed with basement build
Hello, I'm in need of some suggestions for my basement build. I have two walls that are concrete, and one open, and one that is drywall. I'm trying tp decided what insulation would work best for sound.
The room dimensions are 11' x 18' by 7' high to the bottom of the open joists.
Here is my proposed build plan:
- Sealing concrete with Radonseal or Redgard
- Adding a secondary moisture barrier
- Building in decoupled walls from the concrete wall with 2x4
- Using either Roxul Safe 'n Sound or some XPS (such as This board), or even potentially the ones with the foil backing for extra moisture barrier (just in case).
- Then finishing off with 5/8" drywall.
- For the wall with drywalled wall already, I was just going to add in the insulation.
For the ceiling I plan on doing a cleat system with either Roxul or XPS again, and some drywall hanging free between the joists.
I'm also going to have four in-ceiling speakers for eventual Atmos, and two in-wall 8" drivers for my surrounds.
My questions are:
1. Which insulation would be best, the Roxul, XPS, or something else? (I don't care about temp, just sound).
2. Is drywall going to be the best, or should I add anything beyond that?
3. How does that all sound for an overall build? Any suggestions or edits?
Budget-friendly is also helpful.
Media Room: LG 55" 1080p | HTPC | Emotiva XPA-2 | Fronts: Dynaudio Excite x32 | Subwoofer: DIY Rythmik 15" 600HP | Surrounds and Rear: Polk Audio Rt65
Office: PSAudio Sprout | Sennheiser Momentum | Polk Audio 45bs
soulEngine is offline
post #2 of 2 Old 08-23-2017, 05:57 AM
Quoted: 5737 Post(s)
Liked: 5297
multiple vapor barriers can trap moisture which leads to mold. Depending on your climate/region you want one really good one. Picking a particular insulation is the least important aspect of building a room with sound isolation. You need to follow all four of the principles, Mass, Isolation, Dampening and Absorption. The articles at Soundproofingcompany.com are a good start.
