Subwoofer in riser? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By VTstang
  • 1 Post By VTstang
  • 1 Post By BIGmouthinDC
post #1 of 16 Old 10-10-2017, 08:11 PM - Thread Starter
jmilt13's Avatar
Subwoofer in riser?
Had a hard time finding information on this. Is this something reasonable to try?
jmilt13 is offline
post #2 of 16 Old 10-10-2017, 10:34 PM
Nyal Mellor's Avatar
Quoted: 546 Post(s)
Liked: 386
Yes, very reasonable. Did those in @Aareses theater https://www.avsforum.com/forum/#/topics/2329073
Main challenge will be finding a high output sub that will fit. Luckily we developed one of those too https://store.acousticfrontiers.com/...woofer-cabinet
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
post #3 of 16 Old 10-11-2017, 05:00 AM
VTstang's Avatar
Quoted: 235 Post(s)
Liked: 181
A few of us on here have done this. Here is my take:
The option posted above might be great, but $5,000 is a lot of money. This cost me $300 for the drivers, and under $300 for an amp that will drive these subs and two more.
ID:	2296196   Click image for larger version
mpjmeyer likes this.
VTstang is offline
post #4 of 16 Old 10-11-2017, 06:02 AM - Thread Starter
jmilt13's Avatar
[IMG]https://www.avsforum.com/forum/attachment.php?attachmentid=2296196&stc=1&d=15077
23101[/IMG]
$300 bucks is closer to my speed than 5K
Any more details on your design? How did you dress up the baffle?
jmilt13 is offline
post #5 of 16 Old 10-11-2017, 06:10 AM
VTstang's Avatar
Quoted: 235 Post(s)
Liked: 181
the baffle will be carpeted and the second row sofa will sit on top of the drivers (could not flush mount the drivers if I ever wanted to be able to remove them in the future). The sides (vertical portions) will also be carpeted up to and around the ports. I will build little frames out of base cap that I will add acoustic fabric to that will cover the ports so that they disappear in the room. The basic sub design is based on the Marty series of subs that are routinely built and discussed in the DIY subs section of AVS. You can see more pictures of the my subs in my build thread (link below)
unretarded likes this.
VTstang is offline
post #6 of 16 Old 10-11-2017, 06:36 AM
Quoted: 6328 Post(s)
Liked: 6090
Successful sub-woofer installations involve careful placement planning to achieve uniform bass response in the seating areas. Before constructing your riser sub it would be a good idea to do some reading on the subject and pick your locations carefully.
TomKC likes this.
post #7 of 16 Old 10-11-2017, 06:44 AM
VTstang's Avatar
Quoted: 235 Post(s)
Liked: 181
This is true, but I thought the goal of near-field subs is to basically just get them close to the seats, however possible. If these are the only subs in the room, then it could be problematic.
VTstang is offline
post #8 of 16 Old 10-11-2017, 06:48 AM
Liked: 6090
Hard to tell the posters intentions.
post #9 of 16 Old 10-11-2017, 07:00 AM
VTstang's Avatar
Quoted: 235 Post(s)
Liked: 181
Agreed, I am just trying to clarify for my own understanding (and hoping I didn't screw up my build).
VTstang is offline
post #10 of 16 Old 10-11-2017, 07:15 AM - Thread Starter
jmilt13's Avatar
Ideally I would like to do 1-2 sealed 15 or 18" behind front baffle wall, then the ported riser. Likely keep the riser sub turned off except during movies.
jmilt13 is offline
post #11 of 16 Old 10-11-2017, 07:17 AM
Liked: 6090
A good portion of sub-woofer placement science is about avoiding nulls at the listening positions. To do that you either keep your seating out of the main null locations, 25 and 50 % of a rooms length and width. or you position subs or sub pairs to add energy at the nulls.
post #12 of 16 Old 10-11-2017, 12:21 PM
Quoted: 23 Post(s)
Liked: 6
An alternative
If you plan to have other subwoofer(s) in the room, your objective seems to achieve some tactile sensation in these seats. an alternative would be the Clark Synthesis Tactile Transducer. Not necessarily going to be less money, tho. They make several models. What they do is vibrate the riser, seats, and people when the LFE demands. They still require an amplifier. Rather than cutting 12"/15"/18" holes and mounting bass drivers, you attach these guys (quantity required based on size of riser) to the riser or seating by bolt. It's an awesome experience and doesn't add accoustical bass energy to your room. BTW, they work even when you need to turn the audible volume down for some reason. You still get that gut-wrenching experience during explosions, etc. Just have a separate gain control for these.
RickyDee
RickyDB is offline
post #13 of 16 Old 10-11-2017, 10:22 PM - Thread Starter
jmilt13's Avatar
I actually used these on my primary seats in my 1st theater. I think the silver ones? They never really felt that dramatic to me, they definitely helped, but I would like to do something more impact-full. I agree it is nice to have them volume dependent. Going for more powerful transducers will be something I keep in mind.
I also want to bridge the gap between sealed subs for music and ported for movies.
jmilt13 is offline
post #14 of 16 Old 10-12-2017, 08:13 PM
Quoted: 546 Post(s)
Liked: 386
Mixing ported and sealed generally not a good idea, due to relative phase shift differences between the two, which will cause generally unpredictable cancellations...unless you've modeled everything and have a good understanding of what the results will be.
post #15 of 16 Old 10-15-2017, 08:15 PM
Aareses's Avatar
Quoted: 518 Post(s)
Liked: 469
As Nyal mentioned above, we put 2 subs in the rear riser and 2 in the front screen wall. Here are some links:
https://www.avsforum.com/forum/86-ult...l#post45614417
https://www.avsforum.com/forum/86-ult...l#post45947345
https://www.avsforum.com/forum/86-ult...l#post45959065
Evolution of My Theater Build
Speakers: Procella P8 (LCR), P6V (2 Front Side), P5 (2 Rear Side, 2 Rear, 4 Ceiling). Subs: Deep Sea Sound Custom 18" Mariana (4). Amps: Crown DCi 8|300 (2), SpeakerPower SP2-12000-HT. Processors: Yamaha CX-A5100, Xilica XP-8080 (2). Video: JVC RS400, 2.37 Seymour AV 120" Enlightor 4K Screen, Kaleidescape Strato, Philips BDP7501. Control: iRule.
Aareses is offline
post #16 of 16 Old 10-15-2017, 08:18 PM
torii's Avatar
Quoted: 4108 Post(s)
Liked: 2389
default answer is 4 x 18's with one in each corner
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is online now
