soffit question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-15-2017, 05:00 PM - Thread Starter
Liked: 1
soffit question
im confused on how to attach soffits. If you are your using decoupling hat channels . so if you hang the drywall on the ceiling screwed into the hat channels and same goes for walls. how do you add the soffits ? do they screw into the channels ? do you add another row of clips and channels for the soffits ?
Sent from my SAMSUNG-SM-G935A using Tapatalk
scyna is offline
post #2 of 3 Old 10-15-2017, 05:18 PM
Quoted: 6537 Post(s)
Liked: 6384
add another row of channel where you plan to hang the soffit in addition to the one at 24 inches OC. Screw through the drywall into the channel. Where it runs perpendicular. Hit the channels where you can and add some extra screws just into the double layers of drywall. I have hung soffits gluing and screwing just to the double layers of drywall. But you need to keep it light weight.
post #3 of 3 Old 10-15-2017, 05:29 PM - Thread Starter
Liked: 1
great thanks again for your quick response and information . You help alot of people out cheers to you .
scyna is offline
