“The Daydream” Dedicated Theater Build - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 283Likes
post #271 of 288 Old 02-28-2019, 08:59 AM
Shape of Grey's Avatar
Quoted: 70 Post(s)
Liked: 52
Looks awesome, all around. Unfortunately for my wallet, I got a lot of ideas from this build.
bluer101 likes this.
Living Room-Sony 65" XBR900E, Denon X3300W, Nvidia SHIELD. 5.1.2-Ascend Acoustics CBM-170SE L/R, CMT-340Center, HTM-200SE Surround, RSL C34E Atmos, Sealed UM18-22 Sub.
"Micro Theater"-Optoma UHD51A, DIY 120" Spandex AT Screen, Denon X4400H, Sony UBP-800X, Nvidia SHIELD. 7.2.4 - DIYSG HTM-10 LCR, RSL CG3 Surround, Micca M-8C Atmos , 2 4cuf Sealed 18-22 Ultimax.
Shape of Grey is offline
post #272 of 288 Old 02-28-2019, 07:40 PM - Thread Starter
bluer101's Avatar
Quoted: 624 Post(s)
Liked: 704
Thanks guys. I have been really slacking in finishing the screen wall and masking. Been doing other house projects and watching movies. Also ordered a Umik-1 from Cross Spectrum. Need to run some sweeps to see how the room looks on paper. Audessy has done a good job but would like to see what’s really happening.
popalock likes this.
bluer101 is offline
post #273 of 288 Old 02-28-2019, 08:49 PM
DavidK442's Avatar
Quoted: 867 Post(s)
Liked: 729
If you are having a great time with that girl after last call, just make sure you leave before the light of day.
Don't measure it!
DavidK442 is online now
post #274 of 288 Old 04-24-2019, 06:48 PM - Thread Starter
bluer101's Avatar
Quoted: 624 Post(s)
Liked: 704
Don't measure it!
I still have not measured the room or finished the masking. We have been enjoying movies and the hard work.
pkinneb likes this.
bluer101 is offline
post #275 of 288 Old 04-25-2019, 02:30 AM
mdpc's Avatar
Quoted: 22 Post(s)
Excellent job Mate. I'm definitely inspired!
mdpc is offline
post #276 of 288 Old 05-10-2019, 08:02 PM
Quoted: 40 Post(s)
Liked: 53
Got the back 2 soffit panels done with the air exchange return grill. Deleted the passive small projector box vent and installed a 80mm exhaust fan. This way on low it can pull hot air out of the projector box and into the air exchange return. Painted the stage wall before I put up acoustic treatments. Cut and installed the bottom soffit panels above the stage. Used leftover oak plywood and stained black. Made 5 sections that are all removable. I still need to pack the soffits with pink fluffy too. Then did the one sin, put the projector in the room and pinned up the spandex. Watch a few demos and it’s so nice to hear the front soundstage coming from where is suppose to be located. Below are some pictures as usual.
Still need to do HVAC in ceiling, room treatments behind fabric panels, side finish panels, screen and electric masking, screen wash lights, and bass shakers.
For your projector fan does it directly dump into your return? How do you control it (on/off) also what foam did you use for the box and your screen wall? As always thanks for your help
pkinneb is online now
post #277 of 288 Old 05-11-2019, 04:48 AM - Thread Starter
bluer101's Avatar
Quoted: 624 Post(s)
Liked: 704
Yes the fan dumps right into the air exchange return. I originally had the passive grill there. Then I changed it to the 80mm fan. Just to be safe I changed the 80mm to a 120mm fan to move more air at a lower rpm. As for controlling on and off, tapped off my rear subs switched power bridge outlets in the rear column. I intercepted that romex and installed another outlet in the soffit. The fan plugs into that outlet so when I turn my whole system on the fan comes on.
Foam is from foam factory
https://www.thefoamfactory.com/acous...wedgefoam.html
Daniel Chaves and pkinneb like this.
bluer101 is offline
post #278 of 288 Old 05-11-2019, 02:57 PM
Quoted: 40 Post(s)
Liked: 53
post #279 of 288 Old 05-24-2019, 01:49 PM - Thread Starter
bluer101's Avatar
Quoted: 624 Post(s)
Liked: 704
No problem anytime.
bluer101 is offline
post #280 of 288 Old 05-29-2019, 07:54 PM
Quoted: 40 Post(s)
Liked: 53
Some items arrived today, like Xmas in April.
Got some rack blanks, 2nd duct fan, and rack fans. Going to use a 2u rack plate to mount the controllers for the duct and rack fans, pictured below.
Also framed the back wall tonight.
bluer101 curious did you hook your two duct fans to one controller?
My Theater Build - Full Circle Cinema
post #281 of 288 Old 05-30-2019, 04:46 AM - Thread Starter
bluer101's Avatar
Quoted: 624 Post(s)
Liked: 704
No, I have them separate for better control. Plus I can monitor intake temp and exhaust separate.
pkinneb likes this.
bluer101 is offline
post #282 of 288 Old 05-30-2019, 05:00 AM
TMcG's Avatar
Quoted: 1615 Post(s)
Liked: 1810
First, EXCELLENT job all-around. Really great and fastidious work.
Separately, regarding your rack...what monitor is that? I was looking to do something similar in my rack and wanted to get the largest 1080P or 4K monitor which would fit in the space and have the custom rack face to hold it in position. It wasn't in your equipment list in the first post. Thanks!
TMcG is offline
post #283 of 288 Old 05-30-2019, 05:10 AM - Thread Starter
bluer101's Avatar
Quoted: 624 Post(s)
Liked: 704
I have to go back and update the list seeing stuff changed along the way. The tv is an Insignia 19” NS-19D220NA16-A. The tv is a 720p set but excepts 1080p, will change it out eventually to a 4K computer monitor. The rack mount bezel is from eBay that was meant for Denon’s 5805 receiver. It just happens to fit perfectly.
bluer101 is offline
post #284 of 288 Old 07-08-2019, 10:45 AM - Thread Starter
bluer101's Avatar
Quoted: 624 Post(s)
Liked: 704
With the long holiday weekend I decided to work on the bass shakers. At my old place they were installed in my 4 living room seats. So after removing them I went to work on designing the new wood bracket for my Octane seats. I don’t have any photos of building the wood brackets but they are 1/2 ply front to back 6” wide. The ends that are screwed to the front and back of the chair is 3/4 ply. This gives a I mounting plate. This way the shaker transfers the shaking through the wood plate and evenly distributes thru the chair. The shakers themselves are bolted thru the 1/2 ply with wood nuts to make sure a tight connection to the wood plate.
Another issue I had was which way to wire the shakers. They are the ADX shakers from parts express with the Dayton sa230 subwoofer amp. The amp is rated at 4ohm minimum and with 4 shakers before I was able to wire them for 4 ohm. With 3 shakers I had 2 choices. Wire them as 4 shakers and hide one in the column somewhere or wire 3 in series for 12 ohms. I went with 3 in series for 12 ohms with hopes the reduced power will be ok. Did all the series wiring behind the wall plate so each chair is separately plugged in. Well after they were hooked up they are plenty powerful and really help fill in some bass feeling. Below are some install photos.
bluer101 is offline
post #285 of 288 Old 07-08-2019, 12:05 PM
TMcG's Avatar
Liked: 1810
Links to the pics are broken, FYI.
By the way, in your rack for the triple horizontal mount .... are those the Air Infinity ventilation control panels? Were those screw spacing patterns now standard in the Middle Atlantic RSH custom faceplate catalog?
TMcG is offline
post #286 of 288 Old 07-08-2019, 12:28 PM - Thread Starter
bluer101's Avatar
Quoted: 624 Post(s)
Liked: 704
Yes those are the AC infinity fan controllers. The left one is room exchange exhaust, center is rack fans, and right is intake air exchange. As for the face plate I made it myself out a blank faceplate. Just lined them up and cut them out. Used masking tape to prevent scratches to the brushed aluminum.
TMcG likes this.
bluer101 is offline
post #287 of 288 Old 07-08-2019, 01:13 PM
impreza276's Avatar
Quoted: 482 Post(s)
Liked: 720
At least he's got pictures ..Just sayin'
bluer101, James92TSi, femi and 1 others like this.
impreza276 is offline
post #288 of 288 Old 07-09-2019, 01:35 PM
TMcG's Avatar
Liked: 1810
Why you do me like that, bruh?
TMcG is offline
