“The Daydream” Dedicated Theater Build - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 290Likes
post #241 of 293 Old 11-19-2018, 06:38 PM - Thread Starter
bluer101's Avatar
Quoted: 634 Post(s)
Liked: 729
Originally Posted by DavidK442 View Post
Unfortunately I can not see the pictures in your last post. Prior posts are fine.
Fixed them again.
bluer101 is offline
post #242 of 293 Old 11-19-2018, 11:26 PM
James92TSi's Avatar
Quoted: 123 Post(s)
Liked: 394
The frames on.by the door are masterful. My turn to steal some cues from you for my build. (I've known I wanted to customize the inside of the door to make it blend with the walls, but wasn't quite sure how I'd go about it - no brain waves spent on it since I haven't built my first fabric frame yet. Your way looks like it'll turn out great!)
What will be on the section of wall on the hinge side of the door/above the stage? And will you be able to attach a matching baseboard to the door without interfering with the stage?
Feels like you're getting really close to the finish line!
James
Long-time AVS reader, finally building a small dedicated room.
McTheatre II Build Thread
James92TSi is offline
post #243 of 293 Old 11-20-2018, 04:19 AM - Thread Starter
bluer101's Avatar
Quoted: 634 Post(s)
Liked: 729
The section to the right will be a long black panel from stage to soffit and the same on the other side. I made the other side panels right before I started the door this past weekend. They are ready to be wrapped in fabric. The last panel by the hinges will be made after I wrap the door panels. This will allow me to get the spacing just right with the door swing.
As for the baseboard it will match the rest of the room. Since the baseboard sticks out a little more than the panels it will just pass under the lip of the stage. Talk about careful planning. At the same time I’m doing that I need to install my automatic door sweep at the bottom.
Once I have these finished I will move to the screen and masking system. Then install screen wash lights. Stuff soffits with insulation. Take measurements and play with acustic material behind wall panels.
bluer101 is offline
post #244 of 293 Old 11-22-2018, 03:55 PM - Thread Starter
bluer101's Avatar
Quoted: 634 Post(s)
Liked: 729
Worked on wrapping the door frames. Got 5 done today before going to inlaws for thanksgiving. These panels are a pain because the hinge side and the door edge is visible. Wanted to make them look good. Need to finish the top wall one so I can move onto the black wall panel. Need to wrap the opposite wall panels as those are easy. Hope to start the screen wall by weekends end. Also got the extended door strike and modified the handle to work with the thicker door.
Closeup of door knob area.
Looking good.
bluer101 is offline
post #245 of 293 Old 11-22-2018, 06:54 PM
popalock's Avatar
Quoted: 1495 Post(s)
Liked: 2096
Looking good.
Funny story.
popalock is offline
post #246 of 293 Old 11-27-2018, 06:04 AM - Thread Starter
bluer101's Avatar
Quoted: 634 Post(s)
Liked: 729
Ok more updates.
Got all the door and wall panels done. Made and installed the baseboards too. Cut out the door bottom and installed the automatic door sweep. Just have to wrap the one side screen wall panel then turn to doing the screen wall. I’m trying to make my screen swing out to the right to give access behind the screen. Have some ideas but will see while building.
Baseboard by door jamb.
Installing the door sweep.
bluer101 is offline
post #247 of 293 Old 11-27-2018, 06:06 AM - Thread Starter
bluer101's Avatar
Quoted: 634 Post(s)
Liked: 729
Door complete.
Detail.
Hinge side.
Right side screen wall done.
bluer101 is offline
post #248 of 293 Old 11-27-2018, 07:27 AM
hd0823's Avatar
Quoted: 844 Post(s)
Liked: 1588
Man that door looks flawless. Great work man I still need to do mine didnt do panels like you but have all the hardware to do it just got busy with other things . But the room does look amazing super clean look. I hope you get tons of time to enjoy it.
Sent from my SM-N950U using Tapatalk
bluer101 likes this.
hd0823 is online now
post #249 of 293 Old 11-27-2018, 11:55 AM
James92TSi's Avatar
Quoted: 123 Post(s)
Liked: 394
Really amazing work - will be revisiting when it's time to finish out the door area of my build. Looks great!
James
post #250 of 293 Old 11-28-2018, 09:36 AM
Shape of Grey's Avatar
Quoted: 70 Post(s)
Liked: 52
What is the fabric that you used to wrap the frames along the walls? Also, is there any acoustic material or are they hollow frames?
Living Room-Sony 65" XBR900E, Denon X3300W, Nvidia SHIELD. 5.1.2-Ascend Acoustics CBM-170SE L/R, CMT-340Center, HTM-200SE Surround, RSL C34E Atmos, Sealed UM18-22 Sub.
"Micro Theater"-Optoma UHD51A, DIY 120" Spandex AT Screen, Denon X4400H, Sony UBP-800X, Nvidia SHIELD. 7.2.4 - DIYSG HTM-10 LCR, RSL CG3 Surround, Micca M-8C Atmos , 2 4cuf Sealed 18-22 Ultimax.
Shape of Grey is offline
post #251 of 293 Old 11-28-2018, 09:45 AM - Thread Starter
bluer101's Avatar
Quoted: 634 Post(s)
Liked: 729
DMD acoustical fabric. Grey and Black. Very easy to work with.
https://www.acoustimac.com/dmd-acoustic-fabric
Right now they are empty accept 2 I did a test. I will treat behind the panels as needed while taking measurements. My panels are all friction fitted except the door with French cleats. I did the panels this way so I can easily adjust treatment. I gave 1” duct liner and 1” poly treatment.
Finished the last black panel right if door. Now screen wall time.
NotShorty, luisev and Oklahomie like this.
bluer101 is offline
post #252 of 293 Old 12-10-2018, 05:39 AM - Thread Starter
bluer101's Avatar
Quoted: 634 Post(s)
Liked: 729
Small update.
Removed all the speakers on the stage to do the acoustic foam. Also glued down a 1/8 rubber foam on the stage surface to prevent the speakers and subs from moving around. Plus it helps isolate them from the stage too. Had to add a ir emitter to the rack monitor to work with irule. Now I have all my activities working correctly in irule. Worked on my lighting scenes too like welcome, previews, during movie, intermission (bathroom break, lol), movie over. Now I need to start the screen and electronic masking to wrap this up and paint the back of the rack black.
You can see the black mat in this photo. The cutout is access to the intake air exchange.
bluer101 is offline
post #253 of 293 Old 12-17-2018, 05:09 AM - Thread Starter
bluer101's Avatar
Quoted: 634 Post(s)
Liked: 729
Rained here all day Saturday so got nothing done but Sunday was perfect. Picked up some wood to start the screen frame. Did not take any photos of building seeing it’s pretty straight forward for the frame. My plan is to have it on hinges like a door. The hinges will be right next to the right speaker. This will allow the screen to swing out to the right and about a foot or so to swing backwards into the stage cavity. Next on the list is to start the electric masking system. The screen right now is sitting on a couple of temporary 2x4’s.
Test pattern.
Sound test screen.
bluer101 is offline
post #254 of 293 Old 12-17-2018, 11:20 AM
Ladeback's Avatar
Quoted: 1375 Post(s)
Liked: 505
Send a message via MSN to Ladeback
What material are you using for the screen?
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
https://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is offline
post #255 of 293 Old 12-17-2018, 11:48 AM - Thread Starter
bluer101's Avatar
Quoted: 634 Post(s)
Liked: 729
Spandex.
bluer101 is offline
post #256 of 293 Old 12-17-2018, 12:19 PM
ack_bk's Avatar
Quoted: 1342 Post(s)
Liked: 1501
Wow been awhile since I checked in on your thread and you have made some amazing progress. Almost there, keep it up!
ack_bk is offline
post #257 of 293 Old 12-17-2018, 02:48 PM
Oklahomie's Avatar
Quoted: 228 Post(s)
Liked: 763
Looking Great!! You are inching your way to the finish line.
Aaron H.
Aaron H.
Oklahomie is offline
post #258 of 293 Old 12-30-2018, 01:33 PM - Thread Starter
bluer101's Avatar
Quoted: 634 Post(s)
Liked: 729
Finally got around to figuring out the hinges for the screen. Next I need to start the masking.
Clamping the hinges in place then removing frame to drill. I used wood nuts and bolts this way I can easily unbolt the screen if need be. I’m going to assemble the masking after the screen is hung so it will modular.
bluer101 is offline
post #259 of 293 Old 12-30-2018, 02:57 PM
Liked: 4
Such a great space mate. I love what you have done with the constraints of the room. I plan on doing my room quite similar to yours.
I was just looking at your first post and the changes between them are insane. Looks like you have put a fair bit of effort fixing your whole place.
Keep up the great job champ!!
Nicolas Sole is offline
post #260 of 293 Old 12-30-2018, 03:19 PM - Thread Starter
bluer101's Avatar
Quoted: 634 Post(s)
Liked: 729
Thank you for the comments. I look back at all the photos of the house and it’s hard to believe what I have built, feels really good.
yanksno1 likes this.
bluer101 is offline
post #261 of 293 Old 12-30-2018, 05:32 PM
flynfish's Avatar
Quoted: 91 Post(s)
Liked: 50
The latest pics are broken and not showing
Sent from my iPhone using Tapatalk Pro
brazensol likes this.
flynfish is offline
post #262 of 293 Old 12-30-2018, 05:44 PM
brazensol's Avatar
Quoted: 751 Post(s)
Liked: 571
Not seeing it!
Denali Cinema
JVC-RS540, 124" Wide 2.40:1 DIY Screen, Denon 8500H, Denon 6200W, Panasonic UB820 UHD Player, (3) iNuke 6000DSP; (2) iNuke NX3000D; (3) HTM-12; (14) RSL C34e surrounds; (2) 18" DA RSS460HO-4 Subwoofers; (1) DA UM18-22 18" Ultimax Subwoofer; (4) DA RSS390HO-4 15" Reference HO Subwoofers; BOSS Platform - (12) 12" Subwoofers
brazensol is offline
post #263 of 293 Old 12-30-2018, 05:54 PM - Thread Starter
bluer101's Avatar
Quoted: 634 Post(s)
Liked: 729
Originally Posted by brazensol View Post
Not seeing it!
Sorry guys it’s fixed, damn google.
flynfish and brazensol like this.
bluer101 is offline
post #264 of 293 Old 12-30-2018, 10:23 PM
ack_bk's Avatar
Liked: 1501
Wow looking great!
ack_bk is offline
post #265 of 293 Old 12-31-2018, 07:37 AM
brazensol's Avatar
Quoted: 751 Post(s)
Liked: 571
I really like that hinged screen frame!
Denali Cinema
post #266 of 293 Old 01-04-2019, 06:28 AM - Thread Starter
bluer101's Avatar
Quoted: 634 Post(s)
Liked: 729
Temp screen up to watch a few movies and hear sound. This past weekend I finished installing all the acoustical treatments behind the fabric panels. Between the combination of duct liner and polyester batting it sounds really good so far. All I did was level match speakers to 75db and subs to 85db, 10db hot. So far have watched lots of short demo discs. Last night my son and I watched Fury. Talk about being blown away, no pun intended. Seen the movie plenty of times but in the theater it just draws you into the movie. Then watched oblivion for about 1 hour.
Been playing around with the picture setting on the Epson and fine tuning. I think I got it pretty good dialed in. Between the 4K enhancement on or off has been a battle. Sometime with 1080p I like it off but last night I got the settings really good with it on. I think the spandex screen is making the 4K e shift softer. But doing a bunch of setting it looks pretty sharp now.
impreza276, femi, luisev and 1 others like this.
bluer101 is offline
post #267 of 293 Old 01-04-2019, 09:24 AM
James92TSi's Avatar
Quoted: 123 Post(s)
Liked: 394
Getting the ol' pic-no-worky from google photos again.
James
post #268 of 293 Old 01-04-2019, 05:34 PM
OJ Bartley's Avatar
Quoted: 492 Post(s)
Liked: 583
Definitely keep us updated on the sharpness issue. I thought spandex was supposed to be good for a sharp picture because of the fine weave.
Sent from my SM-A520W using Tapatalk
OJ Bartley is offline
post #269 of 293 Old 01-22-2019, 05:57 AM - Thread Starter
bluer101's Avatar
Quoted: 634 Post(s)
Liked: 729
Not much has been happening as other things are taking time from the theater. But the other night I picked up 8 body pillows from Walmart to stuff the front and left soffits with. I wanted a material that can be removed easily without the mess or itch.
bluer101 is offline
post #270 of 293 Old 02-28-2019, 07:33 AM
Quoted: 12 Post(s)
Liked: 2
This whole build is absolutely amazing!
I'll fly you out to Kansas City and treat you to the best BBQ you've ever had if you help me out making some panels?
mmorriskc is offline
