Oh my, here we go - The Drop In Quarters Arcade Bar & Theater - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1171Likes
post #61 of 782 Old 04-05-2018, 04:53 PM - Thread Starter
griffindodd's Avatar
Quoted: 285 Post(s)
Liked: 1124
After spending some time thinking about engineering I'm considering a drastic change in direction. The room was starting to feel horribly cramped, and I want to stick to some of the tried and tested rules for speaker layout. I'm playing with this idea to achieve a much wider sound stage with speakers housed behind my screen, a proper 'out of room' A/V closet, a much more social and practical seat layout etc etc...
ID:	2385544   Click image for larger version
Daniel Chaves likes this.
griffindodd is offline
post #62 of 782 Old 04-05-2018, 06:36 PM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
Taped out the space. Helps me get a real world feel. The entrance hall needs to be at least 40" internal width as not to feel cramped. That leaves me with a theater internal width of 19'
Sent from my SM-G955U using Tapatalk
post #63 of 782 Old 04-06-2018, 09:39 AM
Daniel Chaves's Avatar
Quoted: 639 Post(s)
Liked: 502
I like the new design but do you really need a dedicated bar? I mean how much time do you really plan to stand behind there verses lounging with friends? I just feel like that is a bit of wasted space for what is already limited valuable space, I would put small wet bar against the wall adjacent to the kitchen wall so you can tap into the same plumbing and move your pinball machines to where the bar side was so you can fit more of them. Ditch the hallway for the theater and just double wall the main theater wall so you gain all that space to either make the theater larger so the speakers are not so close to the people on the ends. or make the lounge larger for larger seating.
Sorry for the crude drawing, Im at work and had to do this quickly so my boss wouldnt see me lol...
Projector: BenQ w1500 + ES Sable 135" 16:9 Screen AVR: Marantz SR6011 ATMOS/DTSX + Unity 2ch Amp + Darbee 5000s Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), FXiA6 (SL/SR), Monitor40 Series II (RL/RR), TSx110B (Ceiling FL/FR RL/RR) LFE: (2) JL Audio 12" Subs + (2) Dayton 15" Subs + (2) ButtKicker LFE Arrangement: 7.1.4 Source: OPPO UDP-203 4k Bluray Player, HTPC, nVidia Shield TV Pro, Hauppauge OTA DVR
Daniel Chaves is offline
post #64 of 782 Old 04-06-2018, 09:56 AM
Quoted: 639 Post(s)
Liked: 502
Also in your most recent render is your room only 12ft deep? that wont be enough of a distance from projector lens to screen for most projectors unless you are aiming for an 8-9 foot diagonal screen? they need around 13-15ft, unless you plan to get a Ultra Short throw 4k projector or once they decide to make them some short throw 4k projectors???
post #65 of 782 Old 04-06-2018, 10:01 AM
Quoted: 116 Post(s)
Liked: 106
I like the single row better from the social perspective. Just make sure of the aforementioned projector throw question, as well as viewing angles sitting too close:
https://myhometheater.homestead.com/...alculator.html
That link was a very helpful planning tool for my theater. We’re at 35 degrees with about 14.5’ viewing distance from a 125” diagonal 16:9 screen. For my father in law, this is bordering on uncomfortable particularly with sports like hockey etc. For movies it’s about perfect for the family.
THX recommendation is 36 degrees at a 14” distance for this screen. I often see elaborate home theaters posted with much smaller viewing angles..I don’t see the point if you’re building an immersive home theatre experience :-)
dennwood is offline
post #66 of 782 Old 04-06-2018, 10:25 AM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
It's a fair question, but the bar really doesn't take much more floor space than a 3 person couch, and I can sit at least 4 people at the bar (5 with someone behind). The reality is less of a practical reason, I simply like the idea of having a bar, the same way I like the idea of having a movie theater, which I also don't 'need' lol
As for the throw distance, yes it is something I have some concern about. If I stay vigilant and do a little jiggery pokery I can squeeze out about 12'6 - 13ft of throw. I know I'm cutting it close like that but I do have to accept the limits of my space, budget and all the other headaches of building in an existing structure. I solve one headache only top be confronted with another.
post #67 of 782 Old 04-06-2018, 10:27 AM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
Seating for 9 in the bar area, two pins and an arcade cab.
ID:	2385914   Click image for larger version
post #68 of 782 Old 04-06-2018, 11:52 AM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
Hallways details...
ID:	2385936   Click image for larger version
post #69 of 782 Old 04-06-2018, 01:00 PM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
Measuring out the interior width of the theater at 19.5 feet (234") and calculating a curved row of 6 seats with the center 2 as a love seat (I know my renders show 6 individual seats) at 186" wide, gives me 24" either side of the seating. So yes the outermost seats will be quite close to the walls, but not so close that someone couldn't walk by and around the rear of the seats if need be. As the outermost seats will be the least used I'm not too concerned about that, after all I have to base my design choices and compromises on the most frequent use style of the theater which would probably break down as follows...
2 or less viewers - 60% of the time
2-4 viewers - 35% of the time
more than 4 viewers 5% of the time
post #70 of 782 Old 04-06-2018, 03:35 PM
Quoted: 639 Post(s)
Liked: 502
What kind of speakers do you plan to use for the front stage? you may not need that much space behind the screen which will make it easier on your projector selection by giving you that extra 1 or so feet. Especially if you go with in wall speakers to go behind the screen. (Which has come a LONG way in sound quality)
post #71 of 782 Old 04-06-2018, 08:13 PM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
I'm hoping to use 3 identical towers for LCR speakers but yes it would be nice if I could pull some extra inches into the room by decreasing the distance behind the screen a little.
I was also wondering should I be putting the left and right speakers on the far reaches of the rooms width? My screen will probably be 9 - 10ft wide which will leave almost 5ft on each side. In this case should I be trying to make the sound stage really wide or should it be closer to the screen width.
post #72 of 782 Old 04-07-2018, 07:02 AM
Tedd's Avatar
Quoted: 2245 Post(s)
Liked: 958
Have you thought about five seats, and simply bring a seat in, for when a sixth seat is needed?
The advantage is you get that centered time aligned optimal seat, and you don't have quite the large variance in throw distance
for the side surrounds. I also am thinking that maybe a 5.1.4 might be a superior speaker layout, for a single row wide/shallow style layout.
Have you ever seen Waterfall Audio's single row theaters?
Have you considered quality in wall speakers up front? You could adjust the hall area and get some niches for big DIY subs there?
Have you looked at projector throw distances, for various sizes?
Are you a movie poster collector? Have you seen all the various digital movie poster displays being done?
If you put your LR mains in the far reaches of the room, you need to look at what their radiation pattern is. Get that speaker spread too wide,
and you won't have good sound at the outer seats.
Tedd is offline
post #73 of 782 Old 04-07-2018, 09:13 AM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
All good questions and considerations that I need to spend time researching and learning about Tedd. Thanks for bringing them up here, it's nice to have a single place to gather all the thoughts and opinions.
post #74 of 782 Old 04-07-2018, 09:49 AM
Tedd's Avatar
Liked: 958
We do seem to be following the same design thought processes, and design curve.
You might be interested in this: It's part of my small lobby wantitis. Some of the OP's originally pictures are further down in the thread.
https://www.avsforum.com/forum/32-the...ay-got-me.html
Tedd is offline
post #75 of 782 Old 04-07-2018, 10:26 AM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
Cool stuff. I'll be building a digital poster for the outside wall of the theater that is in the bar side of the room. In the hallway I'll just be doing traditional prints.
If I don't need to pull my speakers all the way to the edge of the room I'd like to have a little space to put a life size Boba Fett costume on one side and build an astromech for the other in the future. A friend of mine builds a lot of movie props so it's on the bucket list for years into the future.
Here's me and a friend hanging with my buddy's fully operational R2...
And a special message for my daughter...
post #76 of 782 Old 04-09-2018, 02:30 PM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
Based around the Optoma UHZ65 my installation will be tight and I'll have to watch every inch of the throw distance, but I'll be hitting my 120" diagonal at around 40-49 calibrated FL depending on screen gain 1.0 - 1.3 which will give me the power I need for a strong HDR performance (as far as affordable projectors go).
post #77 of 782 Old 04-10-2018, 04:15 PM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
While I'm waiting for the bigger things to get underway I decided to start on the smaller bits and pieces in the bar area.
The corner where I want to put the bar has some nasty opaque white plastic panel windows...
post #78 of 782 Old 04-10-2018, 04:17 PM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
I'm going to block them in with 3/5 plywood and run some cabling to place a TV and soundboard up there.
Test fit of the panels (nothing in this damn house is straight)
post #79 of 782 Old 04-10-2018, 04:19 PM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
I added extra bracing behind the TV mounting area and routed out channels for 2x 18gbps HDMI cables, power and ethernet
I think I'm going to cover this area in mini stone bricks or reclaimed barn oak slats.
post #80 of 782 Old 04-11-2018, 11:11 AM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
While I was picking up some materials at Lowes yesterday I saw this really cool coffered ceiling effect using a suspended ceiling system. The wow factor is pretty awesome and would add an amazing level of finish to the theater room itself, especially if I also integrated a small section of fiber optic star panels too.
post #81 of 782 Old 04-11-2018, 12:28 PM
BasementHT5's Avatar
Quoted: 93 Post(s)
Liked: 49
ceiling tiles
I looked at Lowe's and Home Depot for ceiling tiles for my build and ended going with ceilume. Much more economical and better options. They were very easy to work with.
https://www.ceilume.com/
Just a thought.
Gear: Visio 70" M701d-A3R LED TV | Denon x2100w AVR | Sony BDPS5100 (blu ray) | SONY PS3 | Polk 265-RT (L/R) | Polk 255C-RT (C) | Polk RC65i (L/R rear Surround) | Polk RC80i (L/R Surround) | SVS PB-2000 (Subwoofer) | Harmony Smart Control (Remote)
My basement reno: https://www.avsforum.com/forum/15-gen...l#post33708177
BasementHT5 is offline
post #82 of 782 Old 04-11-2018, 01:39 PM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
Just a thought.
Ahh very cool, thanks for this tip. Originally I had thought about just using my existing 10ft ceiling, but I love the creative impact that these options create.
post #83 of 782 Old 04-11-2018, 10:17 PM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
Cabling and tv mount done. I've been checking out stacked brick faux finish panels which is probably what I'll go with
post #84 of 782 Old 04-14-2018, 08:51 PM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
Finished up this corner today with a faux stack stone backdrop for the 65" TV that will float above the bar. Pretty happy to have turned this eyesore corner into a nice feature to add to the room.
post #85 of 782 Old 04-16-2018, 05:01 PM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
After spending more time in the space over the weekend finishing up the TV wall, I flip-flopped on my hallway idea and have pulled it out again. Although it's nice, it is indeed taking up too much valuable space, so I ditched the concessions counter as the bar is pretty close anyway, and consolidated the AV closet into the front wall as there is plenty of space for it there. (Maybe I could mirror it on the other side of the screen with a mini concessions bar????)
Anyway this gives more space to both rooms and removes a existing window-blanking issue I would have had to deal with.
ID:	2391796   Click image for larger version
BllDo and Daniel Chaves like this.
post #86 of 782 Old 04-16-2018, 10:03 PM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
Taped out the modest bar area tonight, I'm practicing restraint and keeping it small as not to crowd the room
post #87 of 782 Old 04-16-2018, 10:06 PM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
Figured I better invest in a good miter saw as I'll be doing a lot of chopping. Found this gently used DWS780 at a local pawn shop for $300, it's a beast, can handle up to 2x16, double bevel and has an LED cut guide that uses the actual shadow of the blade rather than a laser which is pretty genius.
post #88 of 782 Old 04-17-2018, 09:41 AM
BllDo's Avatar
Quoted: 675 Post(s)
Liked: 484
Originally Posted by griffindodd View Post
I like this design a lot. It looks like it makes the best use of the space.
BllDo is offline
post #89 of 782 Old 04-17-2018, 10:50 AM - Thread Starter
Quoted: 285 Post(s)
Liked: 1124
Thanks!! Yes using the extended width of the room (now I have shifted through 90 degrees) makes way more sense. That being said I have brought the concessions bar back into the design, having it on this back wall also allows for me to tap into existing plumbing if I wanted to include a small sink which is even better.
ID:	2391994   Click image for larger version
post #90 of 782 Old 04-17-2018, 11:53 AM
BllDo's Avatar
Quoted: 675 Post(s)
Liked: 484
Looks like even bass response will be tricky with the seating positions, but a standard four-corner layout may help even it out. What is the distance between the screen and MLP?
BllDo is offline
