GoM cloth as speaker cloth - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Nyal Mellor
  • 1 Post By bluer101
post #1 of 17 Old 04-18-2018, 08:05 AM - Thread Starter
dkersten's Avatar
Quoted: 655 Post(s)
Liked: 1140
Has anyone used GoM Anchorage for a speaker grill cover? I like the color choices and texture but the fabric doesn't seem to be terribly breathable. I don't like the texture or color choices of the FR701 which some sites specify can be used for speaker grills, but I don't see much on the Anchorage other than for treatment covers.
Is there a better choice that still has a similar color palette?
dkersten is offline
post #2 of 17 Old 04-18-2018, 08:17 AM
Quoted: 5539 Post(s)
Liked: 5134
Anchorage was used in this theater and was approved by the designer Shawn Byrne who knows a thing or two about acoustics. Room calibrated by Adam Pelz. Professional photographers do crazy things, that ceiling is painted black.
Name:	schlegal front.jpg
ID:	2392212   Click image for larger version
post #3 of 17 Old 04-18-2018, 08:22 AM - Thread Starter
dkersten's Avatar
Quoted: 655 Post(s)
Liked: 1140
dkersten is offline
post #4 of 17 Old 04-18-2018, 01:28 PM
jason4vu's Avatar
Quoted: 131 Post(s)
Liked: 217
All the fabric in my room is gom anchorage as well.
jason4vu is offline
post #5 of 17 Old 04-18-2018, 07:21 PM
frenchfries's Avatar
Quoted: 72 Post(s)
Liked: 38
Supposedly GOM isn't as transparent as they lead you to believe. Floyd Toole posted here recently with his research. Search the forum for his name and you should find it.
Sent from my ASUS_Z017DA using Tapatalk
frenchfries is online now
post #6 of 17 Old 04-19-2018, 07:12 AM
Gouie's Avatar
Quoted: 394 Post(s)
Liked: 241
Great looking room - black ceiling? Wow, can’t trust anything your eyes tell you these days.
Gouie is offline
post #7 of 17 Old 04-19-2018, 08:12 AM - Thread Starter
dkersten's Avatar
Quoted: 655 Post(s)
Liked: 1140
Thanks! I read the thread where Dr. Toole was saying that GoM was not acoustically transparent, and it is interesting information. As speaker cloth, I can see where it would definitely "muffle" the highs to some degree, especially the anchorage fabric which has the lowest NRC rating of pretty much all the AT fabrics that GoM makes (.85)
However, losing a few db at the high end is something that equalization should be able to easily account for just like with an AT screen that shows similar rolloff at higher frequencies. I am not terribly concerned, but I am taking measures so that the GoM will only cover the surround speakers. I will be replacing the Onyx GoM Anchorage fabric planned for the fabric around the screen with something like DMD fabric, which I have used in the past and should work just fine. But that is easy because it is black. There are few colors made in the DMD fabric, but aside from the black none that I am interested in. I don't want the old school purple burgandy, and I don't want fire engine red, I am looking for more of the Mulberry color in the Anchorage fabric. I made a design change to the ceiling as well that will allow me to use basic black grill cloth over the Atmos speakers if I find the GoM is causing any issues.
I only wish there was a little bit of stretchiness in the GoM Anchorage.. I am worried about getting it tensioned right and no having it sag, especially on the ceiling panels.
dkersten is offline
post #8 of 17 Old 05-20-2019, 04:43 PM
dvfx's Avatar
I know this is an old thread but is there a 'recommended' 'best' speaker cloth then other than the GoM.
Thanks in advance!
dvfx is offline
post #9 of 17 Old 05-20-2019, 04:48 PM
Liked: 5134
post #10 of 17 Old 05-20-2019, 04:52 PM
Gouie's Avatar
Quoted: 394 Post(s)
Liked: 241
Hey Big, would you recommend this over the GOM701?
Gouie is offline
post #11 of 17 Old 05-20-2019, 04:58 PM
Liked: 5134
post #12 of 17 Old 05-20-2019, 07:23 PM
Nyal Mellor's Avatar
Quoted: 537 Post(s)
Liked: 382
Anchorage is horrible for use in front of speakers. It's an old standard that people keep using. For sure there are a lot of colors, but acoustically "it sucks". GoM have many better materials now.
Here is some informal recent testing we did on a few materials.
If you like black, we also tested a ton of 120" wide fabrics, we like using these for screen walls with just a perimeter track and losing the black backing behind the AT screen.
appelz likes this.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is online now
post #13 of 17 Old 05-21-2019, 03:59 PM
dvfx's Avatar
Thanks for the fast response! I was hoping for more colors, I have to match a painted/stained Grey shaker door.
So GOM 701 is good, and looks nice, but pricey, and the Parts-Express is possibly more transparent....yes?
any other recommended options? (my enclosure/cab is only apx 5' x 3') (I couldn't make out brands from the chart there.)
dvfx is offline
post #14 of 17 Old 05-21-2019, 04:10 PM
Liked: 5134
Grey? this room is AcousticMac executive. https://www.acoustimac.com/executive...c-by-the-yard/ We used "granite"
ID:	2569894   Click image for larger version
post #15 of 17 Old 05-21-2019, 06:38 PM
bluer101's Avatar
Quoted: 623 Post(s)
Liked: 699
DMD grey on walls and black on columns for speaker grills. Same company as Big posted just cheaper and solid colors. https://www.acoustimac.com/dmd-acoustic-fabric/
BIGmouthinDC likes this.
bluer101 is offline
post #16 of 17 Old 05-21-2019, 07:07 PM
Liked: 5134
be aware that the AcousticMac fabrics do not have the same fire rating as GOM fabrics, if that bothers you. GOM caters to commercial office spaces and public spaces for furniture, wall, and cubicle coverings. As such they are pretty diligent on fire ratings. Home theaters are just silly nuisance that they indirectly tolerate. You can't place an order directly with GOM, but it will ship from one of their distribution centers. You place an order with a distributor who doesn't attempt to maintain an inventory unless they manufacture their own acoustical panels. Fabricmate.com is a popular intermediary. You can order free samples directly on the GOM website.
post #17 of 17 Old 05-21-2019, 08:14 PM
Quoted: 537 Post(s)
Liked: 382
Mel = Mellotone
GoM = Guilford of Maine
AM = Acoustimac
